This chapter discusses how to:
Process retroactive payments.
Enter additional pay group information.
Enter additional calendar information.
Define triggers and segmentation events for Australia.
Identify proration rules for Australia.
Identify rounding rules for Australia.
Note. The PeopleSoft system delivers a query that you can run to view the names of all delivered elements designed for Australia. Instructions for running the query are provided in the PeopleSoft Enterprise Global Payroll 9.1 PeopleBook.
See Also
Understanding How to View Delivered Elements
Processing Retroactive Payments
The default retro method and the on conflict retro method for Australia are both forwarding. You set this on the Country Setup page.
The core retro functionality suits all Australian requirements except the requirement to apply a different tax rate to retro payments that relate to periods more than 12 months before the date the forwarded retro payment is made.
Determining Retro Pay Over 12 Months
To meet this requirement, the PeopleSoft system provides the formula RTO FM SET OVRDSET, which uses the duration RTO DR MTH ARREARS to determine if a period of more than 12 months has elapsed between any of the periods being retroactively paid and the payment date of the retro. If any elapsed period is greater than 12 months, the system selects a new override set—also provided by the PeopleSoft system—to forward all the processed earnings to the single new earning, RETRO12MTH, that the system taxes at the lower rate.
These are lump sum E payments, so the RETRO12MTH earning contributes to accumulator PD LUMP E as well as AUS GROSS, PAYROLL TAX PROV (Provision for Payroll Tax) and its own automatically assigned calendar and fiscal period, month, quarterly, and yearly accumulators.
The system provides one retro processing definition, AU RETRO (which is set to forwarding) and two override sets.
Note. If you add any earnings that can be retrospectively paid, you need to add them to both override sets and to the appropriate accumulators.
Calculating the Months Exceeding 12 Months
The following diagram shows how the duration calculation result determines which override set to use. The system calculates the duration for each period, and when it exceeds 12 months, the second override set applies.
Application of override sets 1 and 2
Processing Retro Over 12 Months
Here are the processing steps:
Formula RTO FM SET OVRDSET—the formula specified on the Retro Process Overrides AU RETRO page—is called for each pay period identified for retro processing.
The formula uses duration RTO DR MTH ARREARS to calculate the months between the pay date of each pay period identified for retro processing (the duration From date—system element PAYMENT DATE) and the date the retro is to be paid (the duration To date—system element CURR PRD PYMT DT).
If the duration is 12 months or less, the formula returns 1, and the system uses override set 1 for forwarding retro; if the duration is greater than 12 months, the formula returns 2, and the system uses override set 2 for forwarding retro.
For each period that's more than 12 months before the retro payment date, the system forwards all the retro earnings to the single earning element RETRO12MTH.
The sum of the earnings forwarded to the single earning RETRO12MTH represents a lump sum E payment, and the tax calculation uses the appropriate rate on the earning.
Entering Additional Pay Group Information
To enter additional pay group information, use the Pay Groups AUS (GPAU_PYGRP_DTL) component.
To accommodate local requirements, the Pay Groups AUS page enables you to specify payslip templates, salary packaging frequency, and leave paid in advance options.
This section discusses how to enter additional information.
Page Used to Enter Additional Pay Group Information|
Page Name |
Definition Name |
Navigation |
Usage |
GPAU_PYGRP_EXT |
Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Framework, Organizational, Pay Groups AUS, Pay Groups AUS |
Specify payslip template, salary packaging frequency, and leave paid in advance options. |
Entering Additional InformationAccess the Pay Groups AUS page (Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Framework, Organizational, Pay Groups AUS, Pay Groups AUS).
Enter the name of the payslip template that the system uses for this pay group.
Select the default pay frequency for the salary-packaged employees in the pay group. An equivalent field exists in Human Resources in case an organization uses Human Resources but not Global Payroll. The pay frequency that you enter here appears by default as the pay frequency on the Salary Packing Pay Calendar Table page.
Within the general structure of Global Payroll calendars, periods, and calendar groups, the system has to determine the calendar group in which an advance should be paid. To determine the appropriate calendar group, the system looks for a calendar that uses the organization's regular run type, which you identify in the Regular Run Type field on this page. A calendar group can contain multiple calendars, each with potentially different periods and payment dates. In determining the calendar group in which to include an advance, the system also looks at the calendars in the group to see when they are being paid.
The following diagram illustrates the selection of the correct calendar. In this example, a leave begins on January 18, 2001. In the January calendar group, the Q4BONUS calendar with a January 15 payment date cannot be used because its run type is Bonus rather than Regular, and the JANPAY calendar with a January 30 payment date cannot be used because the system is configured to make the payment before the absence begins. Therefore, the system must go back to December and look at the DECPAY calendar in the December calendar group. This calendar has a Regular run type and a pay date of December 12, 2000, so it is used to make the advance payment.
Note. In the example, the Advance Type page shows that the Advance Calendar Group for the advance type is Payment Prior to Absence Begin (PPAB). This refers to a payment date that is prior to the absence begin date—not a payment period that is prior to the absence begin date. For the prior payment period, you use the Period Prior to Absence option.
Determination of the calendar group in which to pay a leave advance
Entering Additional Calendar Information
To set up additional calendar information, use the Calendar Groups AUS (GPAU_CAL_RUN) component.
To comply with local requirements, the Australian Information page enables you to mark a calendar group's calendars that can be advanced.
Page Used to Enter Additional Calendar Information|
Page Name |
Definition Name |
Navigation |
Usage |
GPAU_CAL_RUN_DTL |
Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Framework, Calendars, Calendar Groups AUS, Calendar Group AUS |
Mark a calendar group's calendars that can be advanced. The page displays the pay entities, pay groups, and calendars entered on the Calendar Group ID page. (You can add to them if necessary.) To enable the system to advance a calendar, select the Include in Advance check box. |
See Also
Defining Triggers and Segmentation EventsThese tables list triggers and segmentation events for Australia.
TriggersThe following table lists triggers for Australia:
Record (Table) Name |
Type |
Trigger Event ID |
ADDRESSES |
Iterative |
Not applicable (NA) |
COMPENSATION |
Iterative |
NA |
COMPENSATION |
Retro |
COMPENSATI |
CONTRACT_DATA |
Iterative |
NA |
EMPLOYMENT |
Iterative |
NA |
GPAU_ABSADV_SEG |
Segmentation |
AU_ABSADV |
GPAU_EE_TAX_DTL |
Iterative |
NA |
GPAU_GARN_DTLS |
Iterative |
NA |
GPAU_LSL_HISTRY |
Iterative |
NA |
GP_ABSEVT_SGPAU |
Iterative |
NA |
GP_ABS_EVENT |
Iterative |
NA |
GP_ABS_EVENT |
Retro |
GPABSEVENT |
GP_ABS_OVRD |
Iterative |
N/A |
GP_ABS_OVRD |
Retro |
GPABSOVRD |
GP_PI_MNL_DATA |
Iterative |
NA |
GP_PI_MNL_DATA |
Retro |
GPPIMNLDAT |
GP_PI_MNL_OSVR |
Iterative |
NA |
GP_PI_MNL_OSVR |
Retro |
GPPIMNLSOV |
GP_PYE_OVRD |
Iterative |
NA |
GP_PYE_OVRD |
Retro |
GPPYEOVRD |
GP_PYE_OVR_SOVR |
Iterative |
NA |
GP_PYE_OVR_SOVR |
Retro |
GPPYEOVRSO |
GP_PYE_SECT_DTL |
Iterative |
NA |
GP_PYE_SECT_DTL |
Retro |
GPPYESECTD |
GP_RTO_TRGR |
Iterative |
NA |
GP_RTO_TRGR_CTRY |
Iterative |
NA |
GP_SEG_TRGR |
Iterative |
NA |
JOB |
Iterative |
NA |
JOB |
Retro |
JOB |
JOB |
Segmentation |
NA |
JOB_JR |
Iterative |
NA |
PERSON |
Iterative |
NA |
PERS_DATA_EFFDT |
Iterative |
NA |
PERS_ORG_INST |
Iterative |
NA |
SCH_ASSIGN |
Iterative |
NA |
SCH_ASSIGN |
Retro |
SCHASSIGN |
SCH_MNG_SCH_TBL |
Iterative |
NA |
TL_PAYABLE_TIME |
Iterative |
NA |
WKF_CNT_TYPE |
Iterative |
NA |
Segmentation EventsThe following is a list of segmentation events for Australia.
Name |
Description |
Segment Type |
AU_ABSADV |
Pay Absence in Advance |
Period |
COMPRATE |
Comp Rate Segmentation |
Element (Slice) |
JOB |
Job Segmentation |
Period |
Identifying Proration Rules
The Australian extension includes two proration rules in addition to the fourteen rules supplied for all countries. The following table shows the key information about them:
Name |
Description |
Numerator |
Denominator |
AUS PO ANNL WRKDYS |
Percent of Annual - Workdays |
Count GP WORK DAY COUNT |
Formula AUS FM PRD WRKDAYS |
AUS PO ANNL CALDYS |
Percent of Annual - Cal Days |
Duration GP CAL DAYS SEG |
Formula AUS FM PRD CALDAYS |
Identifying Rounding Rules
The Australian extension includes seven rounding rules in addition to the sixty rules supplied for all countries. The following table shows the key information about them. In the last column, R, U, or T indicates:
R: Round up if greater than or equal to the listed value; otherwise, round down.
U: Round up.
T: Truncate down.
Name |
Description |
Rounding (R) or Increment (I) |
Size |
R, U, or T |
AUS RR RND NR 3DEC |
Round Near 3 Decimals |
R |
03 |
R 5 |
AUS RR RND UP 3DEC |
Round Up to 3 Decimals |
R |
03 |
R 5 |
AUS RR RND DN 3DEC |
Round Down to 3 Decimals |
R |
03 |
R 5 or T |
AUS RR INC NR 0.05 |
Increment to Near 5 Cents |
I |
0.05 |
R 0.025 |
AUS RR INC UP 0.05 |
Increment Up to 5 Cents |
I |
0.05 |
R 0.025 or U |
AUS RR INC DN 0.05 |
Increment Down to 5 Cents |
I |
0.05 |
R 0.025 or T |
AUS RR RND UP 5DEC |
Round Up 5 Decimal Places |
R |
05 |
U |
