This chapter contains the following topics:
This table lists the country-specific setup and functionality for Australia.
| Setup or Process | Description |
| UDCs (user-defined codes) | There is no country-specific setup for UDCs for Australia. |
| AAIs (automatic accounting instructions) | Set up AAIs to account for GST (goods and service tax). |
| Goods and service tax setup | To work with GST in Australia, set up:
| Goods and service tax setup (continued) | Before processing GST for Australia:
| Goods and service tax (processing) | When working with GST, you can:
See Using Additional Reports for Australia. Use these inquiry programs to view information about the reports run previously:
| Payment formats | Use the Create Australia EFT Payment File program (R04572OZ) to generate EFT files for Australia in the standardized format. |
| Oracle Business Accelerator | The JD Edwards EnterpriseOne Oracle Business Accelerator solution is available for Australia, as well as other countries. The preconfigured data that is part of the Oracle Business Accelerator solution is based on business processes that have been designed according to the best business practices for a specific country and industry. |
| Payroll | See JD Edwards EnterpriseOne Applications Australia/New Zealand Payroll Implementation Guide. |
