This appendix contains the following topics:
Section A.1, "Mapping Fields in the Batch Invoices Table (F03B11Z1)"
Section A.2, "Mapping Fields in the Journal Entry Transactions — Batch File Table (F0911Z1)"
This section contains a list of the fields in the F03B11Z1 table. Some of the fields are required to run the Batch Invoice Processor program (R03B11Z1A). For some fields, blank is a value. Not all fields are displayed on the Accounts Receivable forms or are used by the JD Edwards EnterpriseOne Accounts Receivable system.
The field names in these tables correspond to the field names on interactive forms.
See Also:
These fields in the F03B11Z1 table are required for processing batch invoices:
| Field Name | Alias | Type | Length | Values to Enter/Definition |
| EDI - User ID | VJEDUS | Alpha | 10 | Enter the user ID of the person running the process or the person who receives messages in the Employee Work Center.
This field, and the EDI - Transaction Number (VJEDTN), the EDI - Batch Number (VJEDBT), and the EDI - Line Number (VJEDLN) fields, uniquely identifies an invoice. |
| EDI - Transaction Number | VJEDTN | Alpha | 22 | Enter the source system's document number so that the transaction can be cross-referenced.
This field, and the EDI - Line Number field (VJEDLN), uniquely identifies each transaction. Each new transaction number identifies a new invoice. You cannot have more than one transaction with the same number in a batch unless the line number is different. |
| EDI - Line Number | VJEDLN | Number | 7 | Enter the pay item number only if a transaction has multiple pay items. If a transaction has only one pay item, you can leave this field blank.
This field, and the EDI - Transaction Number field (VJEDTN), identifies each pay item of the invoice. |
| EDI - Successfully Processed | VJEDSP | Alpha | 1 | Leave this field blank.
The system populates this field to indicate whether the batch processor successfully processed the transaction. 0 (zero) indicates that the transaction was not processed or was processed in error. After the transaction is successfully processed, the system changes the value of the field to 1. |
| EDI - Transaction Action | VJEDTC | Alpha | 1 | Enter A in this field. No other values are valid. |
| EDI - Transaction Type | VJEDTR | Alpha | 1 | Enter I (for invoices) in this field.
A code that identifies a particular kind of transaction. |
| EDI - Batch Number | VJEDBT | Alpha | 15 | Enter a number to group transactions for processing.
This field, and the EDI - Transaction Number (VJEDTN), the EDI - User ID (VJEDUS), and the EDI - Line Number (VJEDLN) fields, uniquely identifies a transaction within a specific batch. This field also specifies a level break and causes the assignment of a new batch number each time the value changes. To increase performance, assign one batch number for each group of transactions processed at one time. |
| Address Number | VJAN8 | Number | 8 | Enter the address book number of the customer associated with the invoice transaction.
The number you enter must exist in the Address Book Master table (F0101). |
| G/L Date | VJDGJ | Date | 6 | Enter the G/L date in the format that the database accepts. Some databases enable you to enter the date in a Gregorian date format (mmddyy), while others might require a Julian date format.
The Julian date format is cyyddd (where c = century). Enter 0 (zero) for transactions in the 20th century and enter 1 for transactions in the 21st century. For example, the date 6/1/99 corresponds to the Julian date 099152, and the date 6/01/00 corresponds to the Julian date 100153 (because the year 2000 has a leap day, 2/29/00). Alternatively, you can leave this field blank and complete the fields VJDGM (mm), VJDGD (dd), VJDGY (yy), VJDG# (cc) in the month/day/year/century format. Enter the prefix of the year in the Century field (VJDG#). For example, enter 19 for 1999, or enter 20 for 2008. |
| Invoice Date | VJDIVJ | Date | 6 | Enter the invoice date in the format that the database accepts.
If you leave this field blank, the system uses the G/L date. See the data item for G/L Date (VJDGJ) for examples. Alternatively, you can leave this field blank and complete the fields VJDIVM (mm), VJDIVD (dd), VJDIVY (yy), and VJDIV# (cc) in the month/day/year/ century format. Enter the prefix of the year in the Century field (VJDIV#). For example, enter 19 for 1999 and 20 for 2008. |
| Company | VJCO | Number | 5 | A number that identifies the organization to which the invoice belongs. This number must exist in the Company Constants table (F0010) and must identify a reporting entity that has a complete balance sheet. |
| G/L Offset | VJGLC | Alpha | 4 | The value of this field, and the Company Number (VJCO) field, specifies the A/R trade (offset) account to which the transaction posts. The account established in the AAI item RCxxxx (where xxxx is the value in the G/L Offset field) is used in the post process. You can establish the AAI for each company or for company 00000 (as the default).
Do not complete this field unless you want to direct different transactions to different offset accounts. |
| Gross Amount | VJAG | Number | 15 | Enter the transaction amount in the format that the database accepts. Some databases accept a decimal identifier while others do not.
If you enter the transaction in a foreign currency (Currency Mode F), leave this field blank and use the Currency Amount field (VJACR) instead. |
| Account Mode - G/L | VJAM | Alpha | 1 | For all records, enter 2 in this field. |
| Business Unit | VJMCU | Alpha | 12 | The value that you enter in this field must exist in the Business Unit Master table (F0006). If you leave this field blank, the system uses the value of the Security Business Unit field (MCU) in the customer's address book record. |
To process batch invoices with discounts, you must complete these fields in the F03B11Z1 table in addition to those listed in the previous table:
| Payment Terms Code | VJPTC | Alpha | 3 | Enter a payment terms code or leave this field blank.
The value that you enter in this field must exist in the Payment Terms table (F0014). If the payment term is defined to calculate a discount, the Discount Available (VJADSC), Discount Due Date (VJDDNJ), and Net Due Date (VJDDJ) fields in the Customer Ledger table (F03B11) are updated accordingly. If you leave this field and the Discount Available field (VJADSC) blank, and the customer has a payment term in the Customer Master by Line of Business table (F03012), the system uses the payment term from the Customer Master table to determine the discount and the discount due date. |
| Discount Available | VJADSC | Number | 15 | If you entered a payment terms code, leave this field blank.
If you did not enter a payment term code, enter the amount of the discount in a format that the database accepts. Some databases accept a decimal identifier, while others do not. If you enter a discount amount, you must also enter a value in the Discount Due Date field (VJDDNJ). If you leave this field blank, the system calculates the discount amount and discount due date based on the value in the Payment Terms Code field (VJPTC). If the Payment Terms Code field is blank and the customer has a payment term in the F03012 table, the system uses the payment term from the F03012 table to calculate the discount amount and the discount due date. You cannot specify the value in this field as a percent. For example, if you use USD currency, and you enter a value of .05, the system reads this as a 5 cent discount. |
| Net Due Date | VJDDJ | Date | 6 | Leave this field blank, if you complete the Payment Terms Code field (VJPTC). The system automatically calculates the net due date when the invoice is processed.
If you do not use a payment term, enter the net due date in a format that the database accepts. See the data item for G/L Date (VJDGJ) for more information. Alternatively, leave this field blank and complete the VJDDM (mm), VJDDD (dd), VJDDY (yy), and VJDD# (cc) fields in the month/day/year/century format. Enter the prefix of the year in the Century field (VJDD#). For example, enter 19 for 1999 and 20 or 2008. This field identifies the due date of the invoice regardless of whether a discount is available. If you leave the Payment Terms Code field blank, and the customer has a payment term in the F03012 table, the system uses the payment term from the F03012 table to determine the net due date. |
| Discount Due Date | VJDDNJ | Date | 6 | Leave this field blank, if you complete the Payment Terms Code field (VJPTC). The system automatically calculates the discount due date when the invoice is processed.
If you do not use a payment term, but you do use the discount available, enter a date in the format that the database accepts. See the data item for G/L Date (VJDGJ) for more information. Alternatively, leave this field blank and complete the VJDDNM (mm), VJDDND (dd), VJDDNY (yy), and VJDDN# (cc) fields in the month/day/year/century format. Enter the prefix of the year in the Century field (VJDDN#). For example, enter 19 for 1999 and 20 for 2008. This field identifies the date through which a discount can be taken after the receipt is received. When invoices are processed, this field is automatically updated based on the definition of the payment term. If you leave the Payment Terms Code (VJPTC) and Discount Available (VJADSC) fields blank, and the customer has a payment term in the F03012 table, the system uses the payment term from the F03012 table to determine the values for the Discount Available (VJADSC) and Discount Due Date (VJDDNJ) fields. |
| Batch File Discount Handling Flag | VJEDDH | Alpha | 1 | Leave this field blank. When the invoice is processed, this field is automatically updated based on the value of the Payment Terms (VJPTC) and the Discount Available (VJADSC) fields. |
| Discount Taken | VJADSA | Number | 15 | Leave this field blank. When the receipt is applied and the discount is taken, this field is updated in the F03B11 table. |
These fields in the F03B11Z1 table are optional for batch invoice processing. You can use the fields to provide additional information about invoices.
We recommend that you leave specific fields blank so that the system updates them.
| EDI - Detail Lines Processed | VJEDDL | Number | 5 | The number of detail lines included in a specific transaction. For user verification only. |
| Document Number | VJDOC | Number | 8 | The number that identifies the transaction in the F03B11 table. If you leave this field blank, the system uses next numbers for system 03B to generate a document number.
If you enter a value in this field, the value cannot exist in the F03B11 table or the transaction is considered a duplicate and is not processed. If you enter a value in this field, you must enter the same value in the corresponding field in the Journal Entry Transactions - Batch File table (F0911Z1). It is recommended that you leave this field blank. |
| Document Type | VJDCT | Alpha | 2 | A code that specifies the type of transaction. If you leave this field blank, the value is specified by a processing option in the Invoice Entry MBF Processing Options program (P03B0011).
If you enter a value in this field, the value must exist in both UDC tables 00/DT (Document Type - All Documents) and 00/DI (Document Type - Invoices Only). If you enter a value in this field, you must enter the same value in the corresponding field in the F0911Z1 table. It is recommended that you leave this field blank. |
| Document Company | VJKCO | Alpha | 5 | A code that specifies the company of the transaction. This field is used only to differentiate transaction numbers by company. If you leave this field blank, the system uses the value that you entered in the Company field (VJCO).
If you enter a value in this field, the value must exist in the F0010 table. If you enter a value in this field, but do not enter a value in the corresponding field (VNKCO) in the F0911Z1 table, the value entered here is passed to that field. It is recommended that you leave this field blank. |
| Document Pay Item | VJSFX | Alpha | 3 | A code that specifies the pay item number of the invoice. If you leave this field blank, the system assigns the pay item beginning with 001. Use the Line Number field (VJEDLN) to specify transactions that have multiple pay items.
If the transaction number (VJEDTN) and the line number (VJEDLN) combination are duplicated, the next and all subsequent transactions is ignored regardless of whether the Pay Item field (VJSFX) is used. If the tax constant Balance GL Distribution by Pay Item and Taxis enabled for the invoice company, this field is required. |
| Batch Type | VJICUT | Alpha | 2 | A code that specifies the type of transaction being processed, such as invoice, voucher, and so on. If you complete this field, you must enter IB (Invoice Batch). If you leave this field blank, the system updates the field with IB when processing the invoices. |
| Batch Number | VJICU | Number | 8 | A number used to group invoices that are processed simultaneously. If you leave this field blank, the system uses next numbers for system 00 to generate a batch number.
| Batch Date | VJDICJ | Date | 6 | The date the batch was entered.
If you leave this field blank, the system uses the date that the batch process program is run. If you complete this field, enter the date in a format that the database accepts. See the field definition for G/L Date (VJDGJ) for more information. Alternatively, you can leave this field blank and complete the fields VJDICM (mm), VJDICD (dd), VJDICY (yy), and VJDIC# (cc) in the month/day/year/ century format. Enter the prefix of the year in the Century field (VJDIC#). For example, enter 19 for 1999, or enter 20 for 2008. |
| Fiscal Year | VJFY | Number | 2 | We recommend that you leave this field blank. The system updates this field based on the G/L date and company. |
| Century | VJCTRY | Number | 2 | We recommend that you leave this field blank. The system updates this field based on the G/L date and company. |
| Period Number | VJPN | Number | 2 | We recommend that you leave this field blank. The system updates this field based on the G/L date and company. |
| Account ID | VJAID | Number | 8 | The short account ID that corresponds to the A/R trade account.
When the invoice is processed, the system updates this field with the account ID associated with the account number retrieved for the AAI item RCxxxx (where xxxx is the value of the G/L Offset field). The account ID is stored in the Account Master table (F0901). It is recommended that you leave this field blank. |
| Address Number - Parent | VJPA8 | Number | 8 | The parent number of the customer.
The value that you enter must exist in the Address Book Master table (F0101). If you leave this field blank, the parent number assigned to the customer in the F03012 table is used. If a parent number does not exist in the F03012 table, the system uses the customer address book number. |
| Address Number - Alternate Payee | VJAN8J | Number | 8 | The alternate payor for the customer.
If the invoice is to be paid by another party, complete this field with the address book number of the payor. If you leave this field blank, the system updates it with the value in the Send Statement To field for the customer in the F03012 table. If you enter a value in this field, the value that you enter must exist in the Address Book Master table (F0101). |
| Payor Address Number | VJPYR | Number | 8 | The alternate payor for the customer.
If the invoice is to be paid by another party, complete this field with the address book number of the payor. The system validates this field against the Address Book Master table (F0101). Any value that you enter must exist as an address book record in the system. If you leave this field blank, the system uses the value from the Alternate Payee field (VJAN8J). |
| G/L Posted Code | VJPOST | Alpha | 1 | A code to specify the posting status of the transaction.
Leave this field blank. Run the General Ledger Post Report program (R09801) to update this field. If you previously processed historical data as a journal entry, it is recommended that you create an associated Journal Entry Transactions - Batch File (F0911Z1) transaction and use the A/R trade account as the G/L distribution account. Then, when the transaction is posted, it does not affect accounting. If you process posted invoice transactions out of balance (that is, without corresponding entries in the Journal Entry Transactions - Batch File table), enter D in this field. However, by doing this, you compromise the ability to void these transactions in the future, and you create discrepancies in the A/R Batch Integrity reports. |
| A/R Post Status | VJISTR | Alpha | 1 | You must leave this field blank. This field indicates that a change record for the invoice exists in the Invoice Revisions table (F03B112). Changes to invoices cannot be processed using the Batch Invoice Processor (R03B11Z1A). You must use Standard Invoice Entry (P03B2002) to make changes to posted invoices. |
| Balanced - Journal Entries | VJBALJ | Alpha | 1 | This field indicates whether the amounts of the journal entries associated with the transaction are in balance with the gross amount of the invoice.
| Pay Status Code | VJPST | Alpha | 1 | This field indicates whether the invoice is open, paid, or on hold. The value of this field must exist in UDC 00/PS (Payment Status Codes).
If you leave this field blank, the system updates it according to the value in the processing option of the Invoice Entry MBF Processing Options program (P03B0011). If you did not assign a value in the processing option, the default value of the data dictionary item PST is used. |
| Amount Open | VJAAP | Number | 15 | The system updates the Amount Open field (VJAAP) with the value in the Gross Amount field (VJAG), regardless of whether a value exists. Processing partially paid invoices is not supported by this application.
| Object Account | VJOBJ | Alpha | 6 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Subsidiary | VJSUB | Alpha | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Subledger Type | VJSBLT | Alpha | 1 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Subledger - G/L | VJSBL | Alpha | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Number of Sent Reminders - Total | VJRMDS | Number | 3 | Enter the total number of notices that were sent to a customer. If you leave this field blank, the system updates it each time a delinquency notice is generated for an invoice. |
| Collection Report (Y/N) | VJCOLL | Alpha | 1 | This field specifies whether a customer is eligible to be placed on the Collection report.
If you leave this field blank, the system updates it with the value from the policy assigned to the customer in the F03012 table. |
| Collection Reason Code | VJCORC | Alpha | 2 | The system updates this field when the Collection Report (R03B461) is run.
| Apply Finance Charges - Y/N | VJAFC | Alpha | 1 | If you leave this field blank, the system uses the value that is assigned to the customer in the F03012 table. |
| Document - Original | VJODOC | Alpha | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this fields
If you leave this fields blank, the system updates it with the value assigned to the Document Number field from the F03B11 table. |
| Document Type - Original | VJODCT | Alpha | 2 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this fields
If you leave this fields blank, the system updates it with the value assigned to the Document Type field from the F03B11 table. |
| Document Company (Original Order) | VJOKCO | Alpha | 5 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this fields
If you leave this fields blank, the system updates it with the value assigned to the Document Company field from the F03B11 table. |
| Document Pay Item - Original | VJOSFX | Alpha | 3 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field.
If you leave this field blank, the system updates it with the value assigned to the Pay Item field from the F03B11 table. |
| Supplier Invoice Number | VJVINV | Alpha | 25 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Purchase Order | VJPO | Alpha | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Document Type - Purchase Order | VJPDCT | Alpha | 2 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Document Company (Purchase Order) | VJPKCO | Alpha | 5 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Order Type | VJDCTO | Alpha | 2 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Line Number | VJLNID | Number | 6 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Sales Document Number | VJSDOC | Number | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Sales Document Type | VJSDCT | Alpha | 2 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Document Company (Sales Order) | VJSKCO | Alpha | 5 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Order Suffix | VJSFXO | Alpha | 3 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Commission Code 1 | VJCMC1 | Number | 8 | You can enter the address book number of the sales person who should receive a commission. Typically, this is tracked in the Sales Order system. The value that you enter is passed and no validation is performed. |
| Reference | VJVR01 | Alpha | 25 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Unit | VJUNIT | Alpha | 8 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Business Unit 2 | VJMCU2 | Alpha | 12 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Remark | VJRMK | Alpha | 30 | This field describes the invoice pay item. This field is user defined and appears on the Standard Invoice Entry form. |
| Alpha Name | VJALPH | Alpha | 40 | If you leave this field blank, the system uses the alpha name that is associated with the address book number in the Address Book Master table (F0101).
If you enter a value in this field and it differs from the value in the Address Book Master, undesirable results might occur. |
| Frequency - Recurring | VJRF | Alpha | 2 | See the Note after the table. |
| Recurring Frequency # of Payments | VJDRF | Number | 3 | See the Note after the table. |
| Control/ Statement Field | VJCTL | Alpha | 13 | Enter the statement number of the last statement generated for this invoice.
| Item Number - Short | VJITM | Number | 8 | Enter the inventory item number.
| Units | VJU | Number | 15 | Any value that you enter in this field is passed to the F03B11 table. The system does not validate this field. |
| Unit of Measure | VJUM | Alpha | 2 | This field describes the type of units. The value that you enter must exist in UDC 00/UM (Unit of Measure). |
| G/L Posting Code - Cash Basis Acct | VJALT6 | Alpha | 1 | This field must be left blank. The system updates this field during receipt processing. |
| Payment Instrument | VJRYIN | Alpha | 1 | Any value that you enter in this field must exist in UDC 00/PY (Payment Instrument). If you leave this field blank, the system updates it with the corresponding value from the F03012 table when the invoice is processed. |
| Void Date - For G/L - Julian | VJVDGJ | Date | 6 | This field must be left blank. The system updates this field when invoices are voided. |
| Void Reason Code | VJVRE | Alpha | 3 | This field must be left blank. The system updates this field when invoices are voided. |
| A/R - A/P Miscellaneous Code 1 | VJRP1 | Alpha | 1 | This field must be left blank. The Sales Order Processing System updates this field. |
| A/R - A/P Miscellaneous Code 2 | VJRP2 | Alpha | 1 | This field must be left blank. The Sales Order Processing System updates this field. |
| A/R - A/P Cash Rcpts/Inv Reg Code | VJRP3 | Alpha | 1 | This field must be left blank. The Sales Order system updates this field. |
| A/R Reporting Codes 1-10 | VJAR01, VJAR02, VJAR03, VJAR04, VJAR05, VJAR06, VJAR07, VJAR08, VJAR09, VJAR10 | Alpha | 3 | If you leave this field blank, the system uses the values from the address book category codes (AC01 - AC10) for this customer.
If you enter a value into this field and a value already exists in the address book category codes for this customer, the system uses the value that you enter in the F03B11Z1 table. The system does not validate this field. |
| Transaction Originator | VJTORG | Alpha | 10 | This field should be left blank. The system updates this field when the transaction is processed. |
| User ID | VJUSER | Alpha | 10 | This field should be left blank. The system updates this field when the transaction is processed. |
| Program ID | VJPID | Alpha | 10 | This field should be left blank. The system updates this field when the transaction is processed. |
| Date - Updated | VJUPMJ | Date | 6 | This field should be left blank. The system updates this field when the transaction is processed. |
| Time - Last Updated | VJUPMT | Number | 6 | This field should be left blank. The system updates this field when the transaction is processed. |
| Work Station ID | VJJOBN | Alpha | 10 | This field should be left blank. The system updates this field when the transaction is processed. |
Complete the Frequency - Recurring (VJRF) and Recurring Frequency # of Payments (VJDRF) fields only if the invoice is a recurring invoice that will be recycled. Documents generated with recurring information have the Document Type RR. The value that you enter in the Frequency - Recurring field (VJRF) must exist in UDC H00/RF (Recurring Frequency).The number of payments corresponds to the number of times the invoice will be recycled. If the number of payments is equal to 1, the system does not generate a new invoice.
These fields in the F03B11Z1 table are ignored by the system. The system does not pass any values entered.
| Type Record | VJEDTY | Alpha | 1 |
| Record Sequence | VJEDSQ | Number | 2 |
| EDI - Document Type | VJEDCT | Alpha | 2 |
| EDI - Transaction Set Number | VJEDTS | Alpha | 6 |
| EDI - Translation Format | VJEDFT | Alpha | 10 |
| EDI - Transmission Date | VJEDDT | Date | 6 |
| EDI - Send/Receive Indicator | VJEDER | Alpha | 1 |
| Batch File Create G/L Record | VJEDGL | Alpha | 1 |
| User Address Number | VJEDAN | Number | 8 |
| G/L Bank Account | VJGLBA | Alpha | 8 |
| Account ID | VJAID2 | Alpha | 8 |
| Account Mode - G/L | VJAM2 | Alpha | 1 |
| Date of Last Sent Reminder | VJRDDJ | Date | 6 |
| Date - Reminder Stop Until Date | VJRDSJ | Date | 6 |
| Date - Statement | VJSMTJ | Date | 6 |
| Number of Reminders to Send | VJNBRR | Alpha | 1 |
| Level of Last Sent Reminder | VJRDRL | Alpha | 1 |
| Write-Off Reason Code | VJRSCO | Alpha | 2 |
| Receipt Number | VJCKNU | Alpha | 25 |
| Date - Cleared Value | VJVLDT | Date | 6 |
| Closed Item - As Of Processing | VJFNLP | Alpha | 1 |
| Date - Statement - MO | VJSMTM | Number | 2 |
| Date - Statement - DA | VJSMTD | Number | 2 |
| Date - Statement - YR | VJSMTY | Number | 2 |
| Date - Statement - CTRY | VJSMT# | Number | 2 |
| Date of Last Sent Reminder - MO | VJRDDM | Number | 2 |
| Date of Last Sent Reminder - DA | VJRDDD | Number | 2 |
| Date of Last Sent Reminder - YR | VJRDDY | Number | 2 |
| Date of Last Sent Reminder - CTRY | VJRDD# | Number | 2 |
| Date - Reminder Stop Until Date - MO | VJRDSM | Number | 2 |
| Date - Reminder Stop Until Date - DA | VJRDSD | Number | 2 |
| Date - Reminder Stop Until Date - YR | VJRDSY | Number | 2 |
| Date - Reminder Stop Until Date - CTRY | VJRDS# | Number | 2 |
| Historical Currency Conversion Rate | VJHCRR | Number | 15 |
| Historical Date - Julian | VJHDGJ | Date | 6 |
| Historical Date - MO | VJHDGM | Number | 2 |
| Historical Date - DA | VJHDGD | Number | 2 |
| Historical Date - YR | VJHDGY | Number | 2 |
| Historical Date - CTRY | VJHDG# | Number | 2 |
These fields in the F03B11Z1 table are reserved for users. These fields are not updated by any program nor are they displayed on any form in the JD Edwards EnterpriseOne Accounts Receivable system.
| User Reserved Code | VJURC1 | Alpha | 3 | Enter any alphanumeric value up to three characters in length. |
| User Reserved Date | VJURDT | Date | 6 | Enter any date in this field. Use a format that the database accepts.
See the data item for G/L Date (VJDGJ) for more information. |
| User Reserved Amount | VJURAT | Number | 15 | Enter any amount in this field. Use a format that the database accepts. |
| User Reserved Number | VJURAB | Number | 8 | Enter any number up to eight digits in length. |
| User Reserved Reference | VJURRF | Alpha | 15 | Enter any alphanumeric value up to 15 characters in length. |
This table lists the corresponding fields that you must complete in the F0911Z1 table for processing batch invoices. All other required fields are updated by the system when the record is processed. The system populates the remaining required fields based on information in the F03B11Z1 table for the transaction.
These fields in the F0911Z1 table are required for processing batch invoices:
| EDI - User ID | VNEDUS | Alpha | 10 | See the important note after the table. |
| EDI - Transaction Number | VNEDTN | Alpha | 22 | See the important note after the table. |
| EDI - Successfully Processed | VNEDSP | Alpha | 1 | See the important note after the table. |
| EDI - Transaction Action | VNEDTC | Alpha | 1 | See the important note after the table. |
| EDI - Transaction Type | VNEDTR | Alpha | 1 | See the important note after the table. |
| EDI - Batch Number | VNEDBT | Alpha | 15 | See the important note after the table. |
| EDI - Line Number | VNEDLN | Number | 7 | This field is increased by one for every line of account distribution for the invoice. For example, if one invoice has 10 lines of account distribution, the line number begins with 1 and is increased by 1 for each line. If the Transaction Number field (VNEDTN) is the same, all lines of the account distribution for the invoice are processed together. |
| Document Company | VNKCO | Alpha | 5 | If you enter a value in this field, it must be the same value that is entered in the corresponding field in the F03B11Z1 table.
If you leave this field blank, the system uses the value entered in the corresponding field in the F03B11Z1 table (VJKCO). |
| Document Type | VNDCT | Alpha | 2 | See the important note after the table. |
| Document Number | VNDOC | Number | 8 | See the important note after the table. |
| Batch Number | VNICU | Number | 8 | See the important note after the table. |
| Batch Type | VNICUT | Alpha | 1 | See the important note after the table. |
| G/L Date | VNDGJ | Date | 6 | The value that you enter in this field must exactly match the value that you entered in the corresponding field in the F03B11Z1 table. |
| Account Number | VNANI | Number | 29 | Enter the account number in the format BU.OBJ.SUB. |
| Account Mode | VNAM | Number | 1 | Enter 2 in this field to correspond to the account number that you entered in the Account Number field (VNANI). |
| Ledger Type | VNLT | Alpha | 2 | Enter AA in this field. This value must be set up in UDC 09/LT (Ledger Types). |
| Amount | VNAA | Number | 15 | Enter the amount that corresponds to the account number that you entered. Use a format that the database accepts. Some databases accept a decimal identifier, while others do not. |
| Explanation | VNEXA | Alpha | 30 | Enter the Alpha Name of the customer.
If you leave this field blank, the system retrieves the alpha name from the Address Book Master table (F0101). By completing this field, you improve performance of the process. |
The values that you enter in these fields must exactly match the values that you entered in the corresponding fields in the F03B11Z1 table:EDI - User ID (VNEDUS)
EDI - Transaction Number (VNEDTN)
EDI - Successfully Processed (VNEDSP)
EDI - Transaction Action (VNEDTC)
EDI - Transaction Type (VNEDTR)
EDI - Batch Number (VNEDBT)
If you complete these fields, the values that you enter must be the same as the values that you entered in the corresponding fields in the F03B11Z1 table:
Document Type (VNDCT)
Document Number (VNDOC)
Batch Number (VNICU)
Batch Type (VNICUT)
If you leave these fields blank, you must also leave the corresponding fields blank in the F03B11Z1 table.
If you use the Advanced Cost Accounting system (System 16), you must complete additional fields in the F0911Z1 table. The system processes these fields and stores them in the Account Ledger table (F0911).
| Cost Object Type 1-4 | VNABT1, VNABT2, VNABT3, VNABT4 | Alpha | 1 | Enter up to four cost object types. The system uses these fields to validate the values that you enter in the corresponding Cost Object fields (VNABR1 - VNABR4). If you enter a value in one of the Cost Object Type fields, you must enter a value in the corresponding Cost Object field. The values in the Cost Object Type fields must exist in the Cost Object Types table (F1620). |
| Cost Object 1-4 | VNABR1, VNABR2, VNABR3, VNABR4 | Alpha | 12 | Enter up to four cost objects. The value in each Cost Object field must adhere to the edit rules for the corresponding Cost Object Type (VNABT1 - VNABT4). |
| Posting Code 1-10 | VNPM01 - VNPM10 | Alpha | 1 | Leave these fields blank. |
| Item Number | VNITM | Number | 8 | If you enter a value in this field, the system validates it against the Item Master table (F4101). |
