This chapter contains the following topics:
Role-based workspaces provide a simplified, configurable front end to JD Edwards EnterpriseOne Capital Asset Management (CAM). Role-based components that can be deployed to a workspace are essential for improving visibility into maintenance effectiveness and efficiency. The workspace provides an easy way for equipment personnel (maintenance planners, managers, equipment technicians, equipment operators, and so on) to view JD Edwards EnterpriseOne CAM-related information. For example, an equipment operator can enter a case, view the repair history of a piece of equipment, or view upcoming corrective or preventive maintenance orders.
Three main portal entry points for the JD Edwards EnterpriseOne CAM workspace are available:
Manage Equipment
Manage Work Order
Manage Cases
The entry points can be considered a workbench, from which you can access detailed information about equipment, work orders, or cases. You can configure the entry points by role, such as by the Maintenance Planner role, which can provide an enterprise-wide view of all maintenance and operational activities. You can determine the functionality that is provided to the user through processing options.
The portal entry points are intended to be simple and not to provide the same full functionality as the traditional JD Edwards EnterpriseOne CAM applications. The entry points are additional front-end forms that access and update the same tables.
The following mobile application is available, and can be used to update meter readings for a piece of equipment on a mobile device:
Manage Equip (Tablet)
Service Equip (Tablet)
This application requires system administrator configuration before it is available to individual users. Contact your system administrator to determine whether this application is available for use.
Additionally, see the topics Manage Equipment Mobile Applications and Manage Customer Equipment Mobile Applications in the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide.
This section provides an overview of managing equipment and discusses how to:
Search for equipment records.
Set processing options for the Equipment Search program (P1701E).
View equipment information detail.
Set processing options for the Equipment Detail program (P1702E).
View equipment status information.
Set processing options for the Status History program (P1307E).
Create and update equipment messages.
Set processing options for the Equipment Messages program (P1205E).
View equipment PM backlog.
Set processing options for the Equipment PM Backlog program (P12071E).
View equipment specification data.
View and update meter readings.
Set processing options for the Meter Readings program (P12120E).
You can inquire on many different programs to find all of the information that is required to efficiently manage the equipment. The Managing Equipment entry point enables you to link to a variety of equipment information from a single form. This feature reduces the amount of time spent searching for equipment information by equipment operators, technicians, planners, managers, and so on.
The Manage Equipment shortcut is a link to the Equipment Search program (P1701E). From this workspace, you can:
Search for equipment.
View equipment status history.
View the PM backlog.
The View Equipment Information form appears when you access Manage Equipment.
Many of the daily tasks that you perform require the ability to locate a specific equipment record quickly. To locate an equipment record or group of records, you can use a variety of criteria. Here are some of the available fields that can be used to search for equipment:
Equipment Number
Description
Business Unit
Location
To search for equipment information, you use the Equipment Search program (P1701E). Once the desired equipment is found, you can go to other equipment-related applications (equipment detail, status history, and so on) by using the link columns in the grid.
The grid columns provide links to the detail information and applicable programs to view, add, or update records.
If you want to see detail information on a piece of equipment, and the detail does not exist, the system displays a message stating that no data exists for the selected equipment.
Processing options enable you to specify the default processing for programs and reports.
Use these processing options to specify the information that populates into the form when searching for a piece of equipment.
Specify the default business unit.
The system assigns this value to the business unit search field on the equipment search form when the form opens.
Specify the default location.
The system assigns this value to the location search field on the equipment search form when the form opens.
Use these processing options to determine whether the system displays certain types of information.
Specify whether to display child (component) equipment in the equipment search form. Values are:
Blank: Do not display children.
1: Display both parent and children.
Specify whether to display disposed equipment in the equipment search form. Values are:
Blank: Do not display disposed equipment.
1: Display disposed equipment.
Specify whether to display the Meter Readings column in the equipment search form. Values are:
Blank: Do not display Meter Readings column.
1: Display Meter Readings column.
Specify whether to display the PM Backlog column in the equipment search form. Values are:
Blank: Do not display PM Backlog column.
1: Display PM Backlog column.
Specify whether to display the Repair History column in the equipment search form. Values are:
Blank: Do not display Repair History column.
1: Display Repair History column.
Specify whether to display the Parts List column in the equipment search form. Values are:
Blank: Do not display Parts List column.
1: Display Parts List column.
Specify whether to display the Specification Data column in the equipment search form. Values are:
Blank: Do not display Specification Data column.
1: Display Specification Data column.
Specify whether to display the Messages column in the equipment search form. Values are:
Blank: Do not display Messages column.
1: Display Messages column.
Specify whether to display the Attachments column in the equipment search form. Values are:
Blank: Do not display Attachments column.
1: Display Attachments column.
Use these processing options to specify the version that the system uses when you select the associated program.
Specify the version of the Equipment Detail program (P1702E) that you access from the equipment search form.
Blank: ZJDE0001
Specify the version of the Status History program (P1307E) that you access from the equipment search form.
Blank: ZJDE0001.
Specify the version of the Equipment Messages program (P1205E) that you access from the equipment search form.
Blank: ZJDE0001.
Specify the version of the Meter Readings program (P12120E) that you access from the equipment search form.
Blank: ZJDE0001.
Specify the version of the Equipment PM Backlog program (P12071E) that you access from the equipment search form.
Blank: ZJDE0001.
Specify the version of the Equipment Parts List program (P13017E) that the system uses from the Equipment Search form.
Blank: ZJDE0001.
Specify the version of the Work Order Search program (P48201E) that the system uses from the Equipment Search form.
Blank: ZJDE0001.
Equipment Master information is the primary data that is associated with each piece of equipment in the system. The Edit Equipment Detail form enables you to view a subset of the Equipment Master information. You can see key information, such as:
Identification numbers
A description
Location information
Acquired and Installation dates
A status
To view detail information for selected equipment, select the link in the Equipment Description column from the View Equipment Information form. The only field that can be updated is the equipment status, depending on the processing option settings. The rest of the information is for viewing only.
Determine how the system processes information.
Specify whether to enable equipment status change from this program. Values are:
Blank: Do not allow equipment status change.
1: Allow equipment status change.
To inquire on the status history of a specific piece of equipment, click the Status link on the Equipment Search form. The status history for the piece of equipment appears in a grid format where you can see past, current, and future status information.
To update the status of a piece of equipment, click the Change Status link. You can update the start effective date, time, or both, and indicate whether the equipment's children should be updated with the status change.
Alternatively, this form automatically displays when you change the equipment status and click OK on the Edit Equipment Detail form. The date and time fields are populated with the current date, time, or both; however, you can change these values.
You should review equipment messages periodically to ensure that you have the most current information about a piece of equipment. This program is primarily used by maintenance planners, managers, equipment technicians, or operators to let each person know specific information about the equipment.
To view or edit equipment messages, select the link in the Messages column on the Equipment Search form. Additional filter fields are provided on the header to search by message type and tickler date. The grid displays equipment number, message, message type, tickler date, and other related information for the selected piece of equipment.
You can then view, update, or delete existing messages or add new messages for the selected equipment. To display the details of the message, click the link for the selected message.
Specify the default value.
Enter a value from UDC 12/EM (Equipment Message Type) that specifies the default equipment message type.
The Equipment PM Backlog program enables you to review the PM schedule for each piece of equipment that you maintain. To determine when a piece of equipment is due for maintenance, you must quickly obtain the status of the equipment and its maintenance cycle. Equipment PM Backlog provides the necessary information to determine when a piece of equipment needs to be serviced.
To view equipment preventive maintenance records for a selected piece of equipment, click the link in the PM Backlog column on the Equipment Search form. Using this application, you can view maintenance records for the selected equipment. This application is primarily used by maintenance planners, managers, equipment technicians, or operators.
You can use the additional filter fields to further refine the search. Some of the fields available are:
Service type
Maintenance status
Scheduled date
Maintenance due %
The grid displays the service type, PM status, completed date, assigned WO number, and other related information.
Use these processing options to specify the default values.
Enter a value from the UDC 12/ST (Service Types).
The system uses this default when searching for preventive maintenance schedules.
Enter a value from UDC 12/MS (Maintenance Status) that specifies the beginning maintenance status in a range of maintenance statuses.
Enter a value from UDC 12/MS (Maintenance Status) that specifies the ending maintenance status in a range of maintenance statuses.
Specify the scheduled beginning date in a range of scheduled dates.
Specify the scheduled ending date in a range of scheduled dates.
Specify the beginning completion date in a range of completion dates.
Specify the ending completion date in a range of completion dates.
Specify the planned beginning start date in a range of planned start dates.
Specify the planned ending start date in a range of planned start dates.
Specify the beginning maintenance-due percent in a range of maintenance-due percents.
Specify the ending maintenance-due percent in a range of maintenance-due percents.
Specification data is used to enter static information about a piece of equipment.
To view equipment specification data for a selected piece of equipment, select the link in the Specification Data column on the Equipment Search form. This form is for inquiry only; it has no add or update functionality.
This form displays the list of the existing specification data pages for the equipment number. The equipment number appears on the header; the grid displays only one column called Page Number. When you click the page numbers, you can view the information on the selected page.
Once you select a page, the specification detail data for the equipment number and page number appear. The equipment number and page number appear in the header portion of the form, while the detail section displays the specification data (up to 16 fields).
You use meter readings when you need to enter or update meter information about the equipment. You use meter readings to monitor equipment use and initiate maintenance tasks. The meter readings program is a simple application that enables you to view current readings, enter new readings, and enter or view the net increase for a single piece of equipment.
To view and enter meter readings for a selected piece of equipment, select the link in the Meter Readings column on the Equipment Search form. This provides similar functionality to the Meter Readings program (P12120); however, it does not provide access to meter rollover or meter change. When entering a meter reading, the entry date always uses the current date and cannot be manually changed.
You can determine the meters that you want to display and update, based on the processing option settings.
Use these processing options to control the information that the system displays.
Specify whether the program displays the current odometer reading and enables the odometer fields for entry. Values are:
Blank: Do not display odometer reading.
1: Display odometer reading.
Specify whether the program displays the current fuel meter reading and enables the fuel meter fields for entry. Values are:
Blank: Do not display fuel meter reading.
1: Display fuel meter reading.
Specify whether the program displays the current hour meter reading and enables the hour meter fields for entry. Values are:
Blank: Do not display hour meter reading.
1: Display hour meter reading.
Specify whether the program displays the current meter 4 reading and enables the meter 4 fields for entry. Values are:
Blank: Do not display meter 4 reading.
1: Display meter 4 reading.
Specify whether the program displays the current meter 5 reading and enables the meter 5 fields for entry. Values are:
Blank: Do not display meter 5 reading.
1: Display meter 5 reading.
Specify whether the program displays the current meter 6 reading and enables the meter 6 fields for entry. Values are:
Blank: Do not display meter 6 reading.
1: Display meter 6 reading.
Specify how the system processes information.
Specify whether the system automatically updates the current meters of child assets when updating the parent's current meter. Values are:
Blank: Do not update current meters of child assets.
1: Update current meters of child assets.
Specify the version that the system uses when you select the associated program.
Specify which version of the Update PM Schedule Status program (R12807) the system uses when updating PM schedules. Values are:
Blank: Do not update PM schedules.
A specific version.
Determine the information that the system verifies.
Specify whether the system displays a tolerance level warning.
Enter the specific percentage difference in meter readings that the system uses to signal the warning.
For example, if you enter 5 in this field, then the system issues a warning if the new net increase amount differs more than 5 percent from the net increase amount of the last meter entry. Values are:
Blank: Do not check for tolerance levels but do display a tolerance level warning.
A specific percent.
This section provides an overview of managing work orders and discusses how to:
View work orders.
Set processing options for the Work Order Search program (P48201E).
View work order detail information.
Set processing options for the Work Order Detail program (P17714E).
Print work orders.
View resource assignments.
Set processing options for the Resource Assignments program (P48331E).
View related purchase orders.
Set processing options for the Related Purchase Orders program (P134310E).
Use work orders to manage the work flow of the maintenance tasks and projects. The Managing Work Orders entry point enables you to link to a variety of work order information so that you can manage the work orders more efficiently. This feature reduces the time that is spent searching for information because it is available on a single form.
The Manage Work Orders shortcut is a link to the Work Order Search program (P48201E). From this workspace, you can:
View work orders.
Print a work order.
The following mobile applications are available, and can be used to manage work orders on a mobile device:
Review Team Work Orders (Smartphone and Tablet)
These applications require system administrator configuration before they are available to individual users. Contact your system administrator to determine whether these applications are available for use.
Additionally, see the following topics in the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide:
You must be able to locate a specific work order quickly. To locate a work order or group of work orders, you can use a variety of criteria. Some of the available fields to search for work orders are:
Order Number
Equipment Number
Order Type
Originator
Priority
Status
To search for equipment work orders, you use the Work Order Search program (P48201E). Once the work order is found, you can access work order-related applications, and either view or update the information. Only work orders that are defined as equipment work orders (in document type maintenance) appear. The grid columns provide links to the applicable program to view, add, or update records.
If you want to see detail information on the work order, and the detail does not exist, the system displays a message to inform you that no data exists for the selected work order.
Use these processing options to specify the default values for the system.
Enter a value from the user-defined code (UDC) table 00/DT (Document Type - All Documents).
The system uses this value when searching for work orders.
The document type used here must be defined as Equipment Work Order document type in the Document Type Maintenance (P40040) program.
Enter a value from UDC 00/TY (Work Order/ECO Type).
Enter a value from UDC 00/SS (Work Order Status) that specifies the beginning status code for a range of work orders.
Enter a value from UDC 00/SS (Work Order Status) that specifies the ending status code for a range of work orders.
Specify whether the system enters the user's address book number as the default originator.
The system uses this value when searching for work orders. Values are:
Blank: Do not enter the user's address book number as the default originator.
1: Enter the user's address book number as the default originator.
Specify whether the system enters the user's address book number as the default Assigned To value.
Blank: Do not enter the user's address book number as the default Assigned To value.
1: Enter the user's address book number as the default Assigned To value.
Specify whether the system displays model work orders. Values are:
Blank: Do not display model work orders.
1: Display model work orders.
Specify whether the system displays work orders for child assets.
This option applies when you search for work orders for a specific asset. If this option is on, and you search for work orders by entering an asset (equipment) number in the search field, the program displays work orders for that asset and any of its children. Values are:
Blank: Do not display work orders for child assets.
1: Display work orders for child assets.
Use these processing options to specify the criteria that the system uses to search for work orders.
Enter a value from UDC 00/W1 (Phase/System Codes) that specifies the current stage or phase of development for work orders that the system uses to search for work orders.
Enter a value from UDC 00/W2 (Work Order Category Code 2) that specifies the type or category of work orders that the system uses to search for work orders.
Enter a value from UDC 00/W3 (Work Order Category Code 3) that specifies the type or category of work orders that the system uses to search for work orders.
Use these processing options to specify the versions that the system uses when you select the associated program.
Specify the version of the Work Order Detail program (P17714E) that the system accesses from the work order search form.
Blank: ZJDE0001.
Specify the version of the Maintenance Work Order Report program (R48425) that the system uses to generate maintenance work orders.
Blank: XJDE0001.
Specify the version of the Resource Assignments program (P48331E) that you access from the work order search form.
Blank: ZJDE0001.
Specify the version of the Equipment Search/Select program (P17012S) that the system accesses from the work order search form.
Blank: ZJDE0001.
Specify the version of the Related Purchase Orders program (P134310E) that the system accesses from the work order search form.
Blank: ZJDE0001.
Work Order information includes basic data that defines the work order, such as the work order number, description, business unit to be charged, and dates to perform the work. You can view the information on work orders previously created, or you can create new equipment work orders.
To view additional information on the work order, click the link in the Work Order Description column on the View Work Orders form. You can review the information in the work order header and all attached text; the parts list and labor steps do not appear. Additionally, you can update a limited amount of information in the work order, such as status, priority, category codes, and text information.
To add a new equipment work order, click Add on the View Work Order form. When you create a work order, only the most basic information is required by the system, such as a description and business unit. You can use the remainder of the fields to classify and prioritize the work order. In addition, you can assign responsible people, such as a manager, supervisor, or others, to the work order. From this form, you cannot add the parts list or the labor steps that are used to complete the equipment work order.
Enter a value from UDC 00/DT (Document Type - All Documents) that specifies the default document type that the system uses when you enter a work order.
This code also indicates the origin of the transaction. The document type used here must be defined as an equipment work order document type in the Document Type Maintenance (P40040) program.
Enter a value from UDC 00/TY (Work Order/ECO Type) that specifies the order type that the system uses when you enter a work order.
The order type indicates the type classification of a work order.
Enter a value from UDC 00/PR (Work Order Priority) that specifies the default work order priority that the system uses when you enter a work order.
This code indicates the priority of a work order in relation to other orders.
Specify the address book number of a manager or a planner. The system uses this value as the default when you enter a work order.
Specify the address book number of the supervisor that the system uses as a default value when you enter a work order.
Specify the address book number of a person to whom the system assigns the work when you enter a work order.
Specify the default responsible business unit that system uses when you enter a work order.
Specify the default branch that the system uses when you enter a work order.
Specify the information type that the system uses as a default value for the failure description when you enter a work order. Values are:
Blank: Do not supply a default value for the failure description.
1: Use the service type description for the default failure description.
2: Use the work order description for the default failure description.
Determine the information that the system requires.
Specify whether the system requires you to enter an equipment number when you create a work order. Values are:
Blank: Do not require an equipment number.
1: Require the equipment number. If you do not enter an equipment number, the system generates an error and stops processing until you correct the error.
Use these processing options to specify how the system processes information.
Specify whether the system supplies default values for manager and supervisor fields on the work order. Values are:
Blank: The system does not supply default values for the manager and supervisor addresses.
1: The system uses default values for the manager and supervisor addresses, based on hierarchy:
Here's the order that the system uses:
The values for the manager and supervisor from the processing options.
The manager value from the equipment record.
The values for the manager and supervisor from the Work Order Default Coding File table (F48001), based on category codes 1, 2, and 3 from the work order.
Note: For the Assigned To field, the system uses the value from the processing options first and information from the equipment record second. |
Specify whether the system automatically displays the Work Order Status form when you add a work order.
This option applies when you add a new work order. When you update an existing work order, the status window always appears, regardless of how this option is set. Values are:
Blank: Do not display the Work Order Status form when adding a work order.
1: Display the Work Order Status form when adding a work order.
Specify a value to automatically create individual resource assignments based on the Assigned To (ANP) address book number on the work order
The system verifies the address book number using the Resource Master table (F48310). Values are:
Blank: Do not automatically create assignments.
1: Create assignments for Assigned To.
Enter a value from UDC 48/AP (Approval Type) that specifies the approval type that the system uses for the work order approval process.
The approval type indicates the type of approval path that a work order follows.
Specify the work order cross-reference.
The system uses this information to determine the equipment number that is assigned to the Reference field on the work order. Values are:
Blank: Immediate parent of the equipment.
1: Top-level parent of the equipment.
Specify whether the system performs entitlement checking.
The system uses entitlement to retrieve response time and general ledger category codes. If this information is not found through entitlement, or if this processing option is turned off, the system retrieves those values from the Service Contract Services table (F1725) by service type. Values are:
Blank: Bypass entitlement checking.
1: Check entitlement.
Specify the version of the Maintenance Work Order Report (R48425) program that the system uses to print maintenance work orders.
Blank: XJDE0001.
Specify the version of the Failure Analysis Tree Search and Select program (P17763S) that you access from the Work Order Revisions form.
Blank: ZJDE0001.
Specify the version of the Failure Analysis Search and Select program (P17768) that you access from the Work Order Revisions form.
Blank: ZJDE0001.
Specify the version of the Equipment Search/Select (P17012S) program that you access from the Work Order Revisions form.
Blank: ZJDE0001.
Specify the version of the Resource Assignments (P48331E) program that you access from the Work Order Revisions form.
Blank: ZJDE0001.
Use these processing options to specify the default values that the system uses when creating work orders.
Enter a value from UDC 00/W1 (Phase/System Codes) that the system uses as a default when you enter a work order.
This category code indicates the current stage or phase of development for a work order. You can assign a work order to only one phase code at a time.
Enter a value from UDC 00/W2 (Work Order Category Code 2) that the system uses as a default when you enter a work order.
This category code indicates the type or category of a work order.
Enter a value from UDC 00/W3 (Work Order Category Code 3) that the system uses as a default when you enter a work order.
You can print work orders when you need a hard copy of a work order or group of work orders.
To print a work order, select the selected piece of equipment from the View Work Order form. You can print from the View Work Order form, or you can select the record and print from the Edit Work Order form. The printed work order displays the details of the work order, header information, and attached text information (if specified in the processing options).
To plan the work order appropriately, you must be able to view the resources that have already been assigned to the work order.
To view the resources assigned to a particular work order, select the work order on the View Work Order form and click the link in the Resource Assignment column. Additionally, you can access the resource assignments view from the Edit Work Order form. You can view both the employees and equipment resources that are related to the equipment work order in the grid area of the form. The grid displays the resources, regardless of assignment level (either header or labor step detail). If no resources have been assigned to the work order, the system displays a message in the header stating that no resources were found.
Specify the number of periods that the system uses to calculate availability and assigned workloads.
Periods are expressed as days or weeks, based on the value in the Period Type processing option. Enter a value within a range of 1 to 52.
Blank: 14.
Enter a value from the UDC 48/PT (Period Type) that the system uses to group the display of assigned hours and capacity hours for a resource.
Blank: Days.
Enter a value from the UDC 40/RV (Inclusion Version) that the system uses to calculate availability.
For assignments at the work order level, the system determines if the assignment is included in availability calculations by using the rule in this processing option, the work order document type (DCTO), and the work order status (SRST). For assignments at the labor detail level, the system determines if the assignment is included in availability calculations by using the rule in this processing option, the work order document type, and the operation status (OPST).
Blank: The system calculates availability by using all assignments that have been identified for inclusion.
Specify whether the system calculates and displays the total lines for resource assignments. Values are:
Blank: Do not display total lines.
1: Display (calculate) total lines.
Note: Enabling this option might cause performance degradation. |
You often need to inquire on the status of a purchase order that is tied to an equipment work order.
To view a purchase order that is related to an equipment work order, click the link in the Related Purchase Order column on the View Work Order form. The system displays the details of the purchase order for view only; no changes to the purchase order are allowed. If no purchase order records are found, the system displays a message in the header.
Use this processing options to specify the default value that the system uses to search for purchase orders.
Enter a value from UDC 00/DT (Document Type - All Documents) that specifies the document type for purchase orders.
The system uses this value when searching for purchase orders.
Enter a value from UDC 40/AT (Activity/Status Codes) that specifies the beginning code in the range of status codes that the system uses when searching for purchase order detail lines.
This processing option works in conjunction with the Status to Use processing option.
Enter a value from UDC 40/AT (Activity/Status Codes) that specifies the ending code in the range of status codes that the system uses when searching for purchase order detail lines.
Specify whether the system applies the From and To status range to the last status or the next status when searching for purchase order detail lines.
This processing option works in conjunction with the From Status Code and the To Status Code processing options. Values are:
Blank: The system applies the From and To status range to the Next Status code.
1: The system applies the From and To status range to the Last Status code.
Specify whether the system displays kit component lines or only the parent line. Values are:
Blank: The system displays only the parent line.
1: The system displays kit component lines.
Specify whether the system displays the suppler cross-reference item number. Values are:
Blank: Do not display the supplier cross-reference item number.
1: Display the supplier cross-reference item number.
This section provides an overview of managing cases and discusses how to:
View cases.
Set processing options for the Work with Cases program (P17500E).
Create and update cases.
Set processing options for the Case Entry program (P17501E).
Cases enable an organization to create a central point-of-contact for all maintenance issues. The Managing Cases entry point enables you to link to a variety of case information from one single form. This feature reduces the time that you spend calling and following up with the maintenance group.
The Manage Cases shortcut is a link to the Work with Cases program (P17500E). From this workspace, you can:
View cases.
You must be able to inquire and respond to a case quickly. To locate a case or a group of cases, you can use a variety of criteria. Here are some of the available fields that can be used to search for requests:
Originator
Equipment number
Date
Status
To search for a case, you use the Work with Case program (P17500E). Once the desired records are located, you can access other request information by using the links in the grid columns.
If you want to see detail information on the case and no detail exists, the system displays a message to inform you that no data exists for the selected case.
The following mobile applications are available, and can be used to manage cases on a mobile device:
Quick Case Entry (Smartphone)
Manage Cases (Smartphone)
Review Cases (Tablet)
These applications require system administrator configuration before these are available to individual users. Contact your system administrator to determine whether these applications are available for use.
Use these processing options to specify default values for the system.
Specify whether the system enters the user as the default value in the Originator field.
The system displays cases that are originated by the user. Values are:
Blank: Do not enter the user as the default value in the Originator field.
1: Enter the user as the default value in the Originator field.
Enter a value from UDC 17/ST (Case Status) that specifies the from status.
The system displays only those cases that match the status specified in the processing options for the from status and to status.
Enter a value from UDC 17/ST (Case Status) that specifies the to status.
The system displays only those cases that match the status specified in the processing options for from status and to status.
Specify the number of days that the system uses to calculate the from date and to date.
The system displays cases only within this date range.
Blank: From/To Date are not populated.
Control the information that the system displays.
Specify whether the system displays attachments. Values are:
Blank: Display attachments.
1: Do not display attachments.
Specify the version of the Case Entry program (P17501E) that the system uses when you add a new case or select a specific request to review.
Blank: ZJDE0001.
Case information includes basic data, such as equipment number, description, and the originator, that defines the issue. You can also provide additional information to help identify issues. You can view and update the information on cases previously created, or you can create new cases.
To view or update an existing case, click the link in the Failure Description column on the View Case Records form. The detail information for the selected maintenance appears. You can review the information or update the text information that is attached to the case.
To create a new case, click Add on the View Case Records form. When you create a case, only the basic information is required by the system.
Specify whether the system displays attachments when you update case records. Values are:
Blank: Display attachments when you update records.
1: Do not display attachments when you update records.
Note: The system always displays attachments when you add case records. |
Specify the version of the Case MBF (P1700140) that the system uses to process the data.
Blank: ZJDE0001.
