This appendix describes how the conversion service flows map data from bank flat files to fields in the JD Edwards EnterpriseOne staging tables.
This appendix contains the following topics:
Section C.1, "Mapping BAI2 Fields to the F09610 and F09611 Tables"
Section C.2, "Mapping SWIFT Fields to the F09610 and F09611 Tables"
This section describes how the Process Automatic Bank Statements Flat File Program (R09600) maps fields for the BAI2 bank format from the bank flat file to the EnterpriseOne bank statement staging header (F09610) and detail (F09611) tables.
These rules apply to the BAI2 bank format:
A comma (,) delimits fields within records.
A slash (/) indicates the end of the logical record, except for record 16.
The comma and slash characters are not allowed in any fields except for record 16 text.
Adjacent delimiters (, ,) identify a default or unspecified field value.
Amount fields do not contain decimals.
The decimal places are implied, based on the currency code.
The default currency code is USD (2 decimal places).
The information in the BAI2 bank flat file is grouped by record. The tables in this section are organized by record and contain information about whether a field is required (R) or optional (O) according to BAI2 requirements, whether the conversion flow maps the field in a record to an EnterpriseOne field, and so on.
This is an example of a BAI2 text file:
Record 01 is the header record that indicates the beginning of the table. This record identifies the sender and receiver and describes the table structure. Record 01 ends with the file trailer record (99).
| Required or Optional | Field Description | Field Position | EnterpriseOne Table and Field | Field Type and Length | Description |
| R | Record Code | 1 | Not applicable | Numeric 2 | The value for this field is always 01. |
| R | Sender Identification | 2 | F09610.SGBSSID | String 9 | The company or bank that sends the flat file. |
| R | Receiver Identification | 3 | F09610.SGBSRID | String 9 | The company or bank that receives the flat file. |
| R | File Creation Date | 4 | F09610.SGSTMD
F09611.BGSTMD |
Numeric 6 | The date of the bank statement, in the YYMMDD format. |
| R | File Creation Time | 5 | Not applicable | Numeric 4 | This field does not map to an EnterpriseOne table. |
| R | File Identification Number | 6 | F09610.SGBSTN
F09611.BGBSTN |
Numeric 15 | The bank statement number. Each flat file with the same creation date must have a different bank statement number. |
| O | Physical Record Length | 7 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
| O | Block Size | 8 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
| R | Version Number | 9 | Not applicable | Numeric 1 | The value for this field is always 2. |
Record 02 is the group header record. This record identifies the group of bank statements with the same as of date and time. Record 02 ends with the group trailer record (98).
| R | Record Code | 1 | Not applicable | Numeric 2 | The value in this field is always 02. |
| O | Ultimate Receiver ID | 2 | Not applicable | String 9 | This field does not map to an EnterpriseOne table. |
| R | Originator ID | 3 | Not applicable | String 9 | This field does not map to an EnterpriseOne table. |
| R | Group Status | 4 | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| R | As-Of Date | 5 | F09611
BGVLDT |
Numeric 6 | The date of the transaction, in YYMMDD format. |
| O | As-Of Time | 6 | Not applicable | Numeric 4 | This field does not map to an EnterpriseOne table. |
| O | Currency Code | 7 | F09610
SGOCRCD |
String 3 | The currency of the amount in record 03. The currency code must exist in the F0013 table. |
| O | As-Of-Date Modifier | 8 | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
Record 03 is the account identifier and summary status. This record identifies the account number and shows account activity and status. Record 03 ends with the account trailer record (49).
| R | Record Code | 1 | Not applicable | Numeric 2 | The value in this field is always 03. |
| R | Customer Account Number | 2 | F09610
SGBAN F09611 BGBAN |
String 29 | The commercial account number. This number should include significant leading zeros. |
| O | Currency Code | 3 | Not applicable | String 3 | This field does not map to an EnterpriseOne table. |
| O | Type Code | 4 | Not applicable | String 3 | This field does not map to an EnterpriseOne table. |
| O | Amount - Summary | 5 | F09610
SGOPBAA |
Numeric 15, 2 | The opening and closing balances. Summary amounts are positive and do not include a sign. |
| O | Item Count | 6 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
| O | Funds Type | 7 | Not applicable | Character 1 | This field does not map to an EnterpriseOne table. |
| O | Value Date | 8A | Not applicable | Numeric 6 | This field does not map to an EnterpriseOne table. |
| O | Value Time | 9A | Not applicable | Numeric 4 | This field does not map to an EnterpriseOne table. |
| O | Amount - Immediate Availability | 8B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Amount - 1 Day Availability | 8B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Amount - 2 or more Day Availability | 10B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Number of Distributions | 8C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 1 | 9C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 1 | 10C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 2 | 11C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 2 | 12C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 3 | 13C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 3 | 14C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
Record 16 contains transaction detail with accompanying text and reference numbers. All type 16 records correspond to the account number in the Record 03.
| R | Record Code | 1 | Not applicable | Numeric 2 | The value in this field is always 16. |
| R | Type Code | 2 | F09611
BGTRANT |
Numeric 3 | The type code for the detail transaction. The value for this field must exist in UDC table 09/BA. |
| O | Amount - Transaction Detail | 3 | F09611
BGAA |
Numeric 15, 2 | Unsigned. The type code for the transaction amount indicates whether the amount is a debit or credit. |
| O | Funds Type | 4 | Not applicable | Character 1 | This field does not map to an EnterpriseOne table. |
| O | Value Date | 5A | Not applicable | Numeric 6 | This field does not map to an EnterpriseOne table. |
| O | Value Time | 6A | Not applicable | Numeric 4 | This field does not map to an EnterpriseOne table. |
| O | Amount - Immediate Availability | 5B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Amount - 1 Day Availability | 6B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Amount - 2 or more Day Availability | 7B | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Number of Distributions | 5C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 1 | 6C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 1 | 7C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 2 | 8C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 2 | 9C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Day Availability 3 | 10C | Not applicable | Numeric 1 | This field does not map to an EnterpriseOne table. |
| O | Amount Available 3 | 11C | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| O | Bank Reference Number | 5 | F09611
BGBANKREF |
String 16 | A number defined by the bank. This number cannot include a comma or a slash. |
| O | Customer Reference Number | 6 | F09611
BGCUSTREF |
String 16 | A number defined by the bank. Typically, this is the deposit or payment number. |
| O | Text | 7 | F09611
BGINFO1 |
String 360 | An informational field used for references purposes only. |
Record 88 is the continuation record for record 16. If the data in record 16 exceeds the maximum physical record length or if dividing the record is necessary for any reason, the continuation record allows the data to continue in the same format.
| R | Record Code | 1 | Not applicable | Numeric 2 | This field does not map to an EnterpriseOne table. |
| R | Format of continued record type | 2 | Not applicable | Not applicable | This field does not map to an EnterpriseOne table. |
Record 49 is the account trailer record. It provides account level control totals and includes the sum of all amount fields in record type 03 as well as the total number of records associated with an account from records 16 and 88. A record 49 exists for each record 03. Although the fields in record 49 do not map to EnterpriseOne fields, the system uses the information in the record to identify the end of the transactions and balances for an account.
| R | Record Code | 1 | Not applicable | Numeric 2 | The value in this field is always 49. |
| R | Account Control Total | 2 | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| R | Number of Records | 3 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
Record 98 is the group trailer record. It provides group control totals and corresponds to the group header in record type 02. Although the fields in record 98 do not map to EnterpriseOne fields, the system uses the information in the record to identify the end of the bank statement.
| R | Record | 1 | Not applicable | Numeric 2 | The value in this field is always 98. |
| R | Group Control Total | 2 | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| R | Number of Accounts | 3 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
| R | Number of Records | 4 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
Record 99 is the file trailer record. It provides file control totals and corresponds to the file header in record type 01. Although the fields in record 99 do not map to EnterpriseOne fields, the system uses the information in the record to identify the end of the text file. Each text file has one record 99 and one record 01. Record 01 identifies the beginning of the text file.
| R | Record Code | 1 | Not applicable | Numeric 2 | The value in this field is always 99. |
| R | File Control Total | 2 | Not applicable | Numeric 15, 2 | This field does not map to an EnterpriseOne table. |
| R | Number of Groups | 3 | Not applicable | Numeric 5 | This field does not map to an EnterpriseOne table. |
This section describes how the Process Automatic Bank Statements Flat File Program (R09600) maps fields for the SWIFT (Society for Worldwide Interbank Financial Telecommunications) bank format from the bank flat file to the EnterpriseOne bank statement staging header (F09610) and detail (F09611) tables.
These rules apply to the SWIFT bank format:
A } delimits the beginning of a block and a -} delimits the end of the block.
Fields within a block are enclosed with : :
If a delimiter is required between fields, a slash (/) is used.
A comma (,) is used instead of a decimal.
The amount is always in the currency of the bank account.
The information in the SWIFT bank flat file is grouped by block. This section contains field information for blocks 2 and 4. It does not contain information for blocks 1 (basic header), 3 (user header), and 5 (trailers) because the fields in those blocks do not map to EnterpriseOne fields.
The tables in this section are organized by block and contain information about whether a field is required (R) or optional (O) according to SWIFT requirements, whether the conversion flow maps the field in a record to an EnterpriseOne field, and so on.
Because fields can be optional according to SWIFT requirements, the field positions listed in the tables in this section may not reflect the actual field positions in the text file. For example, assume that field positions 1–6 are required, positions 7–10 are optional, and positions 11–12 are required. If your bank text file does not contain values for positions 7–10, then positions 11–12 will become positions 7–8. Any subsequent field positions would be adjusted accordingly.
This is an example of a SWIFT text file:
Block 2 contains messages and bank statement information.
| SWIFT | Field Description | Field Position | EnterpriseOne Table and Field | Field Type and Length | Description |
| R | File Input/Output | 1 | F09610
SGFIO |
Character 1 | The value in this field is always 2. |
| R | Message Type | 2–4 | F09610
SGMESST |
String 4 | Only message type 940 is processed. |
| R | Time of Message | 5–8 | Not applicable | Numeric 4, 0 | This field does not map to an EnterpriseOne table. |
| R | Bank Statement Date | 9–14 | F09610
SGSTMD F09611 BGSTMD |
Date 6 | The date of the bank statement. |
| R | Description | 15–60 | F09610
SGDESC04 |
String 46 | A description of bank information. |
Block 4 contains opening balances, transactions amounts and dates, closing balances, and forecasting amounts. Fields 61 and 86 can be repeated, but they must always occur before field 62.
| SWIFT | Field Description | Field | Field Position | EnterpriseOne Table and Field | Field Type and Length | Description |
| R | Transaction Reference Number | 20 | 1–16 | F09610
SGETRN |
String 16 | The reference number of electronic statement. |
| R | Account Identification | 25 | 1–35 | F09610
SGBAN |
String 35 | The account number. |
| R | Statement Number | 28C | 1–5 | F09610
SGBSTN F09611 BGBSTN |
Numeric 15 | The bank statement number. |
| O | Separator | 28C | / | Not applicable | Character 1 | This field is required only if there is a sequence number.
| O | Sequence Number | 28C | 7–11 | F09610
SGBSSEQ F09611 BGBSSEQ |
Numeric 5 | The sequential number for each transaction. |
| R | Opening Balance Debit/Credit Indicator | 60m or 60f | 1 | F09610
SGOBDBCR |
Character 1 | The debit (D) or credit (C) indicator for the opening balance. |
| R | Opening Booking Date | 60m or 60f | 2–7 | F09610
SGOLVDT |
Date 6 | The value date for the opening balance, in YYMMDD format. |
| R | Opening Balance Currency Code | 60m or 60f | 8–10 | F09610
SGOCRCD F09611 BGTCRCD |
String 3 | The 3-character ISO currency code associated with the opening balance amount. |
| R | Opening Balance Amount | 60m or 60f | 11–25 | F09610
SGOPBAA |
Numeric 15, 2 | The opening balance amount. |
| R | Value Date | 61 | 1–6 | F09611
BGVLDT |
Date 6 | The date that the transaction clears the bank, in YYMMDD format. |
| O | Booking Date | 61 | 7–10 | Not applicable | Date 4 | This field does not map to an EnterpriseOne table. |
| R | Detail Debit/Credit Indicator | 61 | 11–12 | F09611
BGDDBCR |
String 2 | The indicator for debit (D), credit (C), reversal of credit (RC), or reversal of debit (RD). |
| O | Type of Currency | 61 | 13 | F09611
BGCURRT |
Character 1 | The third character of the ISO currency code. |
| R | Transaction Amount | 61 | 14–28 | F09611
BGAA |
Numeric 15, 2 | The amount of the transaction. |
| R | Transaction Type | 61 | 29–32 | F09611
BGTRANT |
String 4 | The transaction type identification code. |
| O | Reference | 61 | 33–48 | F09611
BGCUSTREF |
String 16 | The customer reference, such as payment or receipt. |
| R | Separator | 61 | 49–50 | Not applicable | / | If an external bank reference exists, this field is required.
| O | External Bank Reference | 61 | 51–66 | F09611
BGBANKREF |
String 16 | The account servicing institution's reference. |
| R | Separator | 61 | 67–70 | Not applicable | / | If detail (positions 71-102) exists, this field is required.
| O | Detail | 61 | 71–102 | F09611
BGSUBF9 |
String 34 | The supplementary details. |
| R | Informational line | 86 | All | F09611
BGINFO1 |
String 390 | An informational line that can contain 65 characters. There are six informational lines. |
| R | Closing Balance Debit/Credit Indicator | 62m or 62f | 1 | F09610
SGCBDBCR |
Character 1 | The indicator debit (D) or credit (C) for the closing balance amount. |
| R | Closing Booking Date | 62m or 62f | 2–7 | F09610
SGCBDBCR |
Date 6 | The date of the closing balance, in YYMMDD format. |
| R | Closing Currency Code | 62m or 62f | 8–10 | F09610
SGCCRCD |
String 3 | The 3-character ISO currency code for the closing balance. |
| R | Closing Balance Amount | 62m or 62f | 11–25 | F09610
SGCLBAA |
Numeric 15, 2 | The closing balance amount. |
| R | Closing Available Balance Debit/Credit Indicator | 64 | 1 | F09610
SGCADBCR |
Character 1 | Field 64 is optional, but if it is used all subfields are required. |
| R | Closing Available Value Date | 64 | 2–7 | F09610
SGCAVLDT |
Date 6 | The value date for the closing available balance, in YYMMDD format. |
| R | Closing Available Currency Code | 64 | 8–10 | F09610
SGCACRCD |
String 3 | The 3-character ISO currency code for the closing available balance. |
| R | Closing Available Balance | 64 | 11–25 | F09610
SGCAVAA |
Numeric 15, 2 | The closing available balance amount. |
| R | Forward Available Balance Debit/Credit Indicator | 65 | 1 | F09610
SGFADBCR |
Character 1 | Field 65 is optional, but if it is used all subfields are required. |
| R | Forward Available Value Date | 65 | 2–7 | F09610
SGFVLDT |
Date 6 | The value date for the forward available balance, in YYMMDD format. |
| R | Forward Available Currency Code | 65 | 8–10 | F09610
SGFACRCD |
String 3 | The 3-character ISO currency code for the forward available balance. |
| R | Forward Available Balance | 65 | 11–25 | F09610
SGFAVAA |
Numeric 15, 2 | The forward available balance amount. |
