This chapter contains the following topics:
Many growers harvest their crop over a period. For example, avocados are continuously harvested over a period of two years. Growers should estimate and schedule how much of the crop to harvest during each time period. An overestimation of the total crop volume may result in a large financial loss to the grower because of the uneven shipment spread. A grower might anticipate a record crop volume and therefore ship large quantities early in the harvest cycle. If the overall estimate is lower than anticipated, not enough crop is available to harvest later on in the harvest cycle.
This diagram represents several blocks of broccoli, and each block has two separate harvest dates and estimated quantities:
The system enables you to update one or more harvest estimate records at a time. The four update methods are by:
Percentage.
Specified value.
Override original amount.
Specified amount per acre.
Use the harvest estimate to adjust the harvest estimate based on the planted area. You can also change the estimate per area to calculate a new harvest estimate. When you change the harvest estimate, the system recalculates the estimate per area by taking the harvest estimation and dividing it by the planted area.
This table shows the calculated values for the harvest estimate and estimate per area based on the planted area:
| Block Code | Harvest Period | Harvest Estimate | Estimate Per Area | Estimate UOM | Planted Area | Planted UOM |
| Block 1 | H1C | 1200 | 120 | TN | 10 | AC |
| Block 1 | H2C | 800 | 80 | TN | 10 | AC |
| Block 2 | H1C | 1100 | 73.3333 | TN | 15 | AC |
| Block 2 | H2C | 700 | 46.6667 | TN | 15 | AC |
Use the mass update functionality to change the estimate for one or more harvest records by the same percentage or value. You can increase or decrease the estimate.
This tables shows the original harvest estimate and the adjusted estimate based on a percentage and a specified value:
| Harvest Name | Original Harvest Estimate | Increase PercentageValue = 10 | Decrease Percentage Value = 5 | Specified ValueValue = 100 | Specified ValueValue = –50 |
| Block 1 H1C | 1200 | 1320 | 1140 | 1300 | 1150 |
| Block 1 H2C | 800 | 880 | 760 | 900 | 750 |
| Block 2 H1C | 1100 | 1210 | 1045 | 1200 | 1050 |
| Block 2 H2C | 700 | 770 | 665 | 800 | 650 |
You can also override the current estimates.
This table shows the original harvest estimate and the adjusted estimate using the override estimate method:
| Harvest Name | Original Harvest Estimate | Override EstimateValue = 1000 |
| Block 1 H1C | 1200 | 1000 |
| Block 1 H2C | 800 | 1000 |
| Block 2 H1C | 1100 | 1000 |
| Block 2 H2C | 700 | 1000 |
The system enables users to freeze harvest estimates at the end-use reservation (EUR) level. If an EUR is not assigned to a harvest, the system assigns an EUR value of UNKNOWN. This provides a snapshot of a harvest estimate for planning and comparison purposes for each EUR. For example, a grape grower may freeze his harvest estimate in early spring with forty percent going to EUR Premium and sixty percent going to EUR Standard. When the crop is harvested in October, if he is short on the Standard EUR, he can plan to meet his expected needs by other means.
Many crops, like bananas and avocados, are harvested continuously over a period. The system enables you to manage estimates by pick date range. You can add multiple pick dates and quantities for each harvest record. The system totals the estimates from the different pick dates and updates the harvest-level estimate. When using continuous harvests, the system enables you to manage one harvest record at a time.
When freezing a continuous harvest estimate, you can freeze the estimate only at the harvest level for each EUR.
The system enables users to push a harvest estimate to future harvest records within the same block. Users can select the harvest records that they want to change.
This diagram illustrates applications that you can use to maintain harvest estimates:
Figure 6-2 Applications used to Maintain Harvest Estimates
The Harvest Workbench program is the only entry point for harvest and continuous harvest applications. However, you can maintain frozen estimates from the Advanced and Technical Operations task view. From the Harvest Workbench you can manage:
Harvest estimates.
You can update harvest estimates by manually making the changes or by using the mass update function to change one or more harvest records. The system also enables you to push a harvest estimate to future harvest records.
Continuous estimates.
As with harvest estimate maintenance, you can enter and edit continuous estimates individually or in batch mode using the mass update functionality.
From the Harvest Workbench program (P40G032), you can revise harvest estimates by accessing the Harvest Estimate program (P40G20) or the Continuous Harvest Estimate program (P40G23). If the Harvest Workbench program (P40G032) uses a version of the Grower Harvest Maintenance program (P40G03) that creates purchase orders, the system creates or updates purchases orders when you revise harvest estimates.
Before you complete the tasks in this section, enter harvest estimates on the harvest record.
This section discusses how to manage harvest estimates.
This diagram illustrates the methods that the system provides for managing harvest estimates:
Figure 6-3 Methods for Managing Harvest Estimates
The system calculates the estimate per area by taking the harvest estimate and dividing it by the planted area. If you enter a new estimate per area, the system calculates a new harvest estimate. You can enter either the harvest estimate or the estimate per area and the system calculates the other value. For example, if you enter a harvest estimate, the system determines the estimate per area using this calculation:
Estimate per area = Harvest estimated/planted area.
If both values are entered, the system uses the harvest estimate. The system stores harvest estimates in the Grower Harvest table (F40G03).
Access the Harvest Estimate - Entry form.
Enter the revised harvest estimate. The system recalculates the estimate per area when you change this value.
The system prevents you from entering a negative estimate.
Enter the revised estimate per area. The system recalculates the harvest estimate when you change this value.
Access the Harvest Estimate - Push Forward form.
Figure 6-5 Harvest Estimate - Push Forward form
Select the records to update, and click this button.
Displays the new harvest estimate.
This section lists prerequisites and discusses how to manage continuous harvest estimates.
This diagram illustrates the methods for managing continuous harvest estimates:
Figure 6-6 Managing Continuous Harvest Estimates
For crops that you harvest continuously over a period, you can manage your estimates by multiple harvest dates. The sum of your continuous harvest estimates are recorded at the harvest level.
The system stores the estimates in the Continuous Harvest Estimate table (F40G033).
Before you complete the tasks in this section:
Select the Use Continuous Estimates check box in the Add/Edit Grower Block program (P40G02).
Add harvest records to the block.
Access the Continuous Harvest Estimate - Entry form.
Figure 6-7 Continuous Harvest Estimate - Entry form
Displays estimates that are past due. Past date estimates are not displayed in the grid area.
Displays the remaining estimates by subtracting the past date estimate from the total continuous estimate.
Displays the total of the Continuous Estimate fields. The system uses this value to update the current estimate on the Grower Harvest table (F40G03).
Enter the harvest date. This value is for the item only and does not include any EUR breakout.
The harvest date must be unique for each harvest period.
Enter the amount that is expected to be harvested for this harvest date. The system prevents you from entering a negative estimate.
Enter the revised estimate per area. The system recalculates the continuous estimate when you change this value.
This section discusses how to perform mass updates on harvest estimates.
Access the Harvest Estimate - Mass Update form.
Select the method to use when updating the harvest estimate. Values are:
By Percentage
By Value
Override Estimate
Enter a value that is used with the update method to calculate the new harvest estimate.
The system displays the new harvest estimate based on the update method and value.
This section discusses how to perform mass updates on continuous harvest estimates.
Access the Continuous Harvest Estimate - Mass Update form.
Select the rows to update.
Figure 6-8 Continuous Harvest Estimate - Mass Update form
By Percentage
By Value
Override Estimate
The system displays the new calculated harvest estimate based on the update method and value.
This section provides and overview of creating frozen harvest estimates, lists a prerequisite, and discusses how to create frozen harvest estimates.
Run the Harvest Estimate Freeze program.
Set processing options for Harvest Estimate Freeze (R40G032).
This diagram illustrates the harvest estimate freeze process:
Figure 6-9 Harvest Estimate Freeze Process
You may want to freeze the harvest estimates, which takes a snapshot of the expected yield of the selected harvest records. During the growing process yields may change due to adverse weather conditions, or be reassigned to another EUR based on supply and demand. Periodically freezing the harvest estimates enables you to compare changes to estimates throughout the entire growing process.
As these harvest estimates change, you periodically revise and freeze harvest estimates to take a snapshot of the expected yields. You can also keep a historical record of changing estimates.
The system enables you to freeze one or more harvest estimates at the EUR level. You can use the freeze to run reports or views to see what the supply looks like on a certain date, and to compare against future supply or actual supply.
You must use a unique freeze name if at least one frozen EUR record exists for that harvest. There are two steps in freezing harvest estimates:1. The first step is to 2.
Take a snapshot of the desired data. To do this you run the R40G032 program.
After you run the R40G032 program, inquire on the snapshot data and, if desired, make updates to the frozen estimates.
Before you complete the tasks in this section, create harvest estimates.
Access the Edit Freeze - Frozen Estimate - Edit form.
Figure 6-10 Edit Freeze - Frozen Estimate - Edit form
Displays the estimated EUR quantity for the frozen harvest records.
Displays the unit price for the frozen harvest item, excluding freight, taxes, discounts, and other factors that might modify the actual price that you record when the blend system receives the item.
Displays the site where the crop is crushed.
Displays the site where the crop is produced.
Enter notes to reference why the estimate is being changed.
Access the Frozen Estimate - Delete form.
Access the Delete By Frozen Estimate Name form.
Figure 6-11 Edit Freeze - Delete By Frozen Estimate Name form
Displays the frozen harvest estimate name to be deleted.
Select Advanced and Technical Operations (G40G131), Harvest Estimate Freeze.
Use these processing options to control system processing and define print options.
These processing options specify the freeze name, control whether the system runs in proof or final mode, and determine whether the system refreshes the Freeze Detail table.
Specify a name, up to 40 characters, that the system uses when freezing EUR distribution quantities during the Harvest Estimate Freeze (R40G032). A harvest estimate can be frozen under a freeze name only once, unless the freeze is being run in refresh mode.
Specify whether the system generates the report in proof mode or final mode. Proof mode does not perform table updates. Final mode updates tables based on the harvest records that are specified in the data selection. Values are:
Blank: Run in proof mode.
1: Run in final mode.
Specify whether the system refreshes data for the freeze name that is specified on this tab. When this processing option is set to refresh freeze data, the system deletes all previous freeze data sharing this freeze name from the Freeze Detail table (F40G032) upon initiation of the Harvest Estimate Freeze (R40G032). Then new freeze data is created for harvest records that match the data selection on this version, using the same freeze name. Values are:
Blank or 0: Create new freeze data.
1: Refresh freeze data.
Use these processing options to specify whether the system prints harvest totals and zero amounts.
Specify whether the harvest totals are printed on the report. Values are:
Blank or 0: Do not print harvest totals.
1: Do print harvest totals.
Specify whether frozen estimates with zero quantities are printed on the report. Values are:
Blank or 0: Do not print zero quantities.
1: Do print zero quantities.
