This appendix contains the following topics:
This section provides an overview and discusses the JD Edwards EnterpriseOne Quality Management workflow.
This section discusses the Test Definitions Approval workflow.
The system sends a workflow message to a specified approver when you enter or change a test definitions. The test remains at a status of P (pending) and cannot be used until the approver changes the test status to A (Approved).
When workflow is turned on in the processing options and a test definition changes or is entered.
The approver receives a message in the workcenter to approve the test definition. When the approver selects the message in the workcenter, the system displays the Quality Management Approvals Workbench, where the approver can review the test definition and select Approve from the Row menu to approve the test.
37
JDEQMAPRV1
N3700070
F3701ProcessTestMasterData
572, 603, 703
This section provides an overview and discusses the Specification Definitions Approval workflow.
The system sends a workflow message to a specified approver when a they enter or change a specification definition. The specification remains at a status of P (Pending) and the specification cannot be used until the approver changes the specification status to A (Approved).
When workflow is turned on in the processing options and entered or changed in a specification definition.
The approver receives a message in the work center to approve the specification definition. When the approver selects the message in the work center, the system displays the Quality Management Approvals Workbench, where the approver can review the specification definition and select Approve from the Row menu to approve the specification.
37
JDEQMAPRV2
N3700100
F3702ProcessSpecDefinitionMast
216, 250, 298
This section provides and overview and discusses the Quality Preference Approval workflow.
The system sends a workflow message to a specified approver when they enter or change a quality preference. The preference remains at a status of P (Pending) and the preference cannot be used until the approver changes the preference status to A (Approved).
When workflow is turned on in the processing options and is entered or changes a quality preference.
The approver receives a message in the work center to approve the quality preference. When the approver selects the message in the workcenter, the system displays the Quality Management Approvals Workbench, where the approver can review the preference and select Approve from the Row menu to approve the preference.
37
JDEQMAPRV3
N3700340
F40318UpdateQualityPreferences
53
