This chapter contains the following topics:
Section 7.7, "Multiple Percentages Complete with No Schedule of Values on the T and M Billing Line"
Section 7.8, "Multiple Percentages Complete with a Schedule of Values on the T and M Billing Line"
Section 7.11, "Retainage on a Partially Complete Contract with a Discount"
Note: For all examples in this chapter, the retainage rules are set up to calculate retainage on only cost billing line types. |
This section discusses:
Example setup
Invoice generation
Retainage calculations
Populated tables
A/R entries
Customer ledger inquiry
In this example, three retainage rules are set at change order levels 000 and 001 and at the billing line level. The calculation is based on 100 percent completion of the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes.
Draw and rated draw billing lines are excluded from the calculations.
These retainage rules are set up in the Retainage Rules Table program (P5204):
| Retainage Rule | Description |
| A | 10 percent retainage until 100 percent complete. |
| B | 15 percent retainage until 100 percent complete. |
| C | 5 percent retainage until 100 percent complete. |
This contract is set up in the Contract Master Revisions program (P5201):
| Contract Part | Retainage Rule | Offset | Control Flag | Tax Explanation | Tax Rate/Area |
| Contract | A | RETN | S | D1 = 3.5 percent | |
| Change Order 000, Billing Line 001 | B | RETN | S | D1 = 3.5 percent | |
| Change Order 001 | C | RETN | S | D1 = 3.5 percent |
Running Invoice Generation (R52121) produces these values:
| Billing Line | Billing Line Descr. | Change Order | Schedule of Values | Net Amount Current | Tax Amount Current | Total Amount Current | Retainage Amount Current |
| 001 | Lump Sum | 000 | 12,000.00 | 3,000.00 | 105.00 | 3,105.00 | 450.00 |
| 002 | Units | 000 | 15,000.00 | 78.00 | 2.73 | 80.73 | 7.80 |
| 003 | Milestone | 000 | 2,500.00 | 275.00 | 9.63 | 284.63 | 27.50 |
| 004 | Progress | 000 | 3,500.00 | 455.00 | 15.93 | 470.93 | 45.50 |
| 005 | Draw | 000 | 1,500.00– | 275.00- | 9.63– | 284.63– | |
| 006 | Rated Draw | 000 | 1,000.00– | 130.00– | 4.55– | 134.55– | |
| 007 | T and M | 000 | 750.00 | 26.25 | 776.25 | 75.00 | |
| Change Order 000 Total | 30,500.00 | 4,153.00 | 145.36 | 4,298.36 | 605.80 | ||
| 001 | Lump Sum | 001 | 6,000.00 | 100.00 | 3.50 | 103.50 | 5.00 |
| Change Order 001 Total | 6,000.00 | 100.00 | 3.50 | 103.50 | 5.00 | ||
| Contract Total | 36,500.00 | 4,253.00 | 148.86 | 4,401.86 | 610.80 |
Note: The draw billing line is cross-referenced to a milestone billing line.The rated draw billing line is cross-referenced to a progress billing line. |
This equation shows how the system calculated retainage amounts for change order 000, billing line 001:
| Billing Line | (Net Amount) × (Retainage Table B) = (Retainage Amount) |
| 001 | 3,000.00 × 0.15 = 450.00 |
These equations illustrate how the system calculated retainage amounts for change order 000, billing lines 002 through 004 and 007:
| Billing Line | (Net Amount) × (Retainage Table A) = (Retainage Amount) |
| 002 | 78.00 × 0.10 = 7.80 |
| 003 | 275.00 × 0.10 = 27.50 |
| 004 | 455.00 × 0.10 = 45.50 |
| 007 | 750.00 × 0.10 = 75.00 |
This equation shows how the system calculated retainage amounts for change order 001:
| Billing Line | (Net Amount) × (Retainage Table C) = (Retainage Amount) |
| 001 | 100.00 × 0.05 = 5.00 |
This table lists fields in the Billing Detail Workfile table (F4812) that relate to retainage and that are populated when you run Invoice Generation (R52121) with Journal Generation (R48131):
| COCH | OPIM | TCLS | JTAX | ITOL | ITXA | ITAM | RGLC |
| 000 | 001 | 8 | 105.00 | 3,105.00 | 3,000.00 | 105.00 | RETN |
| 000 | 002 | 8 | 2.73 | 80.73 | 78.00 | 2.73 | RETN |
| 000 | 003 | 8 | 9.63 | 284.63 | 275.00 | 9.63 | RETN |
| 000 | 004 | 8 | 15.93 | 470.93 | 455.00 | 15.93 | RETN |
| 000 | 005 | 8 | 9.63– | 284.63– | 275.00– | 9.63– | RETN |
| 000 | 006 | 8 | 4.55– | 134.55– | 130.00– | 4.55– | RETN |
| 000 | 007 | Blank | 26.25 | 776.25 | 750.00 | 26.25 | RETN |
| 001 | 001 | 8 | 3.50 | 103.50 | 100.00 | 3.50 | RETN |
This table lists fields in the Invoice Summary Work File table (F4822) that relate to retainage and that are populated when you run Invoice Generation (R52121) with Journal Generation (R48131):
| COCH | OPIM | THPD | STAM | ATXA | RTNG | RGLC | RTNR |
| 000 | 001 | 3,105.00 | 105.00 | 3,000.00 | 450.00 | RETN | B |
| 000 | 002 | 80.73 | 2.73 | 78.00 | 7.80 | RETN | Blank |
| 000 | 003 | 284.63 | 9.63 | 275.00 | 27.50 | RETN | Blank |
| 000 | 004 | 470.93 | 15.93 | 455.00 | 45.50 | RETN | Blank |
| 000 | 005 | 284.63– | 9.63– | 275.00– | RETN | Blank | |
| 000 | 006 | 134.55– | 4.55– | 130.00– | RETN | Blank | |
| 000 | 007 | 776.25 | 26.25 | 750.00 | 75.00 | RETN | Blank |
| 001 | 001 | 103.50 | 3.50 | 100.00 | 5.00 | RETN | Blank |
This table lists fields in the Billing Detail Journal Workfile table (F48S910) that relate to retainage and that are populated when you run Invoice Generation (R52121) with Journal Generation (R48131):
| COCH | LNID | TCLS | AA |
| 000 | .100 | 8 | 3,105.00– |
| 000 | .200 | 8 | 80.73– |
| 000 | .300 | 8 | 284.63– |
| 000 | .400 | 8 | 470.93– |
| 000 | .500 | 8 | 284.63 |
| 000 | .600 | 8 | 134.55 |
| 000 | .700 | Blank | 776.25– |
| 001 | .100 | 8 | 103.50– |
The AA field in the Summarized Journal Workfile table (F48S911) relates to retainage and is populated with 4,401.86– when you run Invoice Generation (R52121) with Journal Generation (R48131):
| AA |
| 4,401.86– |
The system creates these entries in the A/R ledger when you run Create A/R Entries (R48199) from the Batch Review program (P48221):
| Account | Debit | Credit |
| Trade Accounts Receivable | 3,791.06 | |
| Revenue | 4,401.86– | |
| Retainage | 610.80 |
This table shows the partial results of inquiring on the contract customer's account in the Customer Ledger Inquiry program (P03B2002) after running Create A/R Entries:
| Doc Type | Pay Item | Invoice Date | Gross Amount | Open Amount | Pay Status | Remark |
| RI | 001 | November 15, 2005 | 3,105.00 | 3,105.00 | A | Application 1 Adjust. 0 |
| RI | 002 | November 15, 2005 | 450.00– | 450.00– | A | Retainage |
| RI | 003 | November 15, 2005 | 450.00 | 450.00 | H | Retainage |
| RI | 004 | November 15, 2005 | 80.73 | 80.73 | A | Application 1 Adjust. 0 |
| RI | 005 | November 15, 2005 | 7.80– | 7.80– | A | Retainage |
| RI | 006 | November 15, 2005 | 7.80 | 7.80 | H | Retainage |
| RI | 007 | November 15, 2005 | 284.63 | 284.63 | A | Application 1 Adjust. 0 |
| RI | 008 | November 15, 2005 | 27.50– | 27.50– | A | Retainage |
| RI | 009 | November 15, 2005 | 27.50 | 27.50 | H | Retainage |
| RI | 010 | November 15, 2005 | 470.93 | 470.93 | A | Application 1 Adjust. 0 |
| RI | 011 | November 15, 2005 | 45.50– | 45.50– | A | Retainage |
| RI | 012 | November 15, 2005 | 45.50 | 45.50 | H | Retainage |
| RI | 013 | November 15, 2005 | 284.63– | 284.63– | A | Application 1 Adjust. 0 |
| RI | 014 | November 15, 2005 | 134.55– | 134.55– | A | Application 1 Adjust. 0 |
| RI | 015 | November 15, 2005 | 776.25 | 776.25 | A | Application 1 Adjust. 0 |
| RI | 016 | November 15, 2005 | 75.00– | 75.00– | A | Retainage |
| RI | 017 | November 15, 2005 | 75.00 | 75.00 | H | Retainage |
| RI | 018 | November 15, 2005 | 103.50 | 103.50 | A | Application 1 Adjust. 0 |
| RI | 019 | November 15, 2005 | 5.00– | 5.00– | A | Retainage |
| RI | 020 | November 15, 2005 | 5.00 | 5.00 | H | Retainage |
| 4,401.86 | 4,401.86 |
Example setup
Invoice generation
Tax calculations
The Journal Edit Register (R48300)
Populated tables
A/R entries
In this example, only one retainage rule is set at the contract level. The calculation is based on 100 percent completion of the contract. The control flag is set to 1 to create retainage in A/R with deferred taxes.
This retainage rule is set up in the Retainage Rules Table program (P5204):
| A | 10 percent Retainage ÷ 100 percent Complete |
| Contract | A | RETN | 1 | S | D1 - 3.5 percent |
| Billing Line | Billing Line Descr. | Change Order | Schedule of Values | Net Amount Current | Tax Amount Current | Total Amount Current | Retainage Amount Current | Tax Amount Deferred |
| 001 | T and M | 000 | 2,000.00 | 63.00 | 2,063.00 | 200.00 | 7.00 | |
| 002 | Lump Sum | 000 | 12,000.00 | 1,000.00 | 31.50 | 1,031.50 | 100.00 | 3.50 |
| Change Order Total | 12,000.00 | 3,000.00 | 94.50 | 3,094.50 | 300.00 | 10.50 | ||
| Contract Total | 12,000.00 | 3,000.00 | 94.50 | 3,094.50 | 300.00 | 10.50 |
These equations illustrate how the system calculated retainage amounts for change order 000:
| 001 | 2,000.00 × 0.10 = 200.00 |
| 002 | 1,000.00 × 0.10 = 100.00 |
These equations illustrate how the system calculated the taxable amounts:
| Billing Line | (Net Amt) × (Tax Rate) = (Taxable Amt) |
| 001 | 2,000.00 × 0.035 = 70.00 |
| 002 | 1,000.00 × 0.035 = 35.00 |
These equations illustrate how the system calculated the deferred tax amounts:
| Billing Line | (Tax Amt) × (Retainage percent) = (Deferred Tax) |
| 001 | 70.00 × 0.10 = 7.00 |
| 002 | 35.00 × 0.10 = 3.50 |
These equations illustrate how the system calculated the current tax amounts:
| Billing Line | (Tax Amt) - (Deferred Amt) = (Tax Amt Current) |
| 001 | 70.00 – 7.00 = 63.00 |
| 002 | 35.00 – 3.50 = 31.50 |
The system creates these entries in the A/R ledger when you run the Journal Edit Register program (R48300):
| Account | Debit | Credit | Offset Amt |
| Trade Accounts Receivable | 2,749.50 | ||
| Revenue | 3,105.00– | ||
| Retainage | 300.00 | 10.50 |
This table lists fields in the Billing Detail Workfile table (F4812) that relate to retainage and that are populated during Invoice Generation with Invoice Journal Generation:
| 001 | 70.00 | 2,070.00 | 2,000.00 | 70.00 | RETN | |
| 002 | 8 | 35.00 | 1,035.00 | 1,000.00 | 35.00 | RETN |
This table lists fields in the Invoice Summary Work File table (F4822) that relate to retainage and that are populated during Invoice Generation with Invoice Journal Generation:
| OPIM | THPD | STAM | ATXA | RTNG | RGLC | RCTL | DDTR |
| 001 | 2,063.00 | 63.00 | 2,000.00 | 200.00 | RETN | 1 | 7.00 |
| 002 | 1,031.50 | 31.50 | 1,000.00 | 100.00 | RETN | 1 | 3.50 |
This table lists fields in the Billing Detail Journal Workfile table (F48S910) that relate to retainage and that are populated during Invoice Generation with Invoice Journal Generation:
| LNID | TCLS | AA |
| 001 | 2,070.00– | |
| 002 | 8 | 1,035.00– |
The AA field in the Summarized Journal Workfile table (F48S911) relates to retainage and is populated with 3,105.00– during Invoice Generation with Invoice Journal Generation:
| AA |
| 3,105.00– |
| Trade Accounts Receivable | 2,794.50 | |
| Retainage | 310.50 |
| RI | 001 | November 15, 2005 | 1,863.00 | 1,863.00 | A | Application 1 Adjust. 0 |
| RI | 002 | November 15, 2005 | 200.00 | 200.00 | H | Retainage |
| RI | 003 | November 15, 2005 | 7.00 | 7.00 | H | Retainage |
| RI | 004 | November 15, 2005 | 931.50 | 931.50 | A | Application 1 Adjust. 0 |
| RI | 005 | November 15, 2005 | 100.00 | 100.00 | H | Retainage |
| RI | 006 | November 15, 2005 | 3.50 | 3.50 | H | Retainage |
Example setup
Invoice generation
Tax calculations
Populated tables
A/R entries
In this example, one retainage rule is set at the contract level. The calculation is based on 100 percent completion of the contract. The control flag is set to 2 to create retainage in G/L with no deferred taxes.
| A | 10 percent Retainage until 100 percent Complete |
| Contract | A | RETN | 2 | S | D1 = 3.5 percent |
| 001 | T and M | 000 | 2,000.00 | 70.00 | 2,070.00 | 200.00 | |
| 002 | Lump Sum | 000 | 12,000.00 | 1,000.00 | 35.00 | 1,035.00 | 100.00 |
| Change Order Total | 12,000.00 | 3,000.00 | 105.50 | 3,105.00 | 300.00 | ||
| Contract Total | 12,000.00 | 3,000.00 | 105.50 | 3,105.00 | 300.00 |
| Billing Line | (Net Amount) × (Tax Rate) = (Taxable Amount) |
| Trade Accounts Receivable | 2,805.00 | |
| 001 | R | 200.00– | 200.00– | RETN | ||
| 002 | R | 100.00– | 100.00– | RETN |
This tables list fields in the Invoice Summary Work File table (F4822) that relate to retainage and that are populated during Invoice Generation with Invoice Journal Generation:
| 001 | 2,070.00 | 70.00 | 2,000.00 | 200.00 | RETN | 2 |
| 002 | 1,035.00 | 35.00 | 1,000.00 | 100.00 | RETN | 2 |
| LNID | TCLS | AA |
| .100 | 2,070.00– | |
| .200 | 8 | 1,035.00– |
| .100 | R | 200.00 |
| .200 | R | 100.00 |
This table lists the field in the Summarized Journal Workfile table (F48S911) that relates to retainage and that is populated during Invoice Generation with Invoice Journal Generation:
| AA | Account |
| 3,105.00– | Revenue |
| 300.00 | Retainage |
| RI | 001 | November 15, 2005 | 2,070.00 | 2,070.00 | A | Application 1 Adjust. 0 |
| RI | 002 | November 15, 2005 | 200.00– | 200.00– | A | Retainage |
| RI | 003 | November 15, 2005 | 1,035.00 | 1,035.00 | A | Application 1 Adjust. 0 |
| RI | 004 | November 15, 2005 | 100.00– | 100.00– | A | Retainage |
| 2,805.00 | 2,805.00 |
Example setup
Invoice generation
Tax calculations
Populated tables
A/R entries
In this example, one retainage rule is set at the contract level. The calculation is based on 100 percent completion of the contract. The control flag is set to 3 to create retainage in G/L with deferred taxes. The AAI for deferred taxes is RTVATD.
| Contract | A | RETN | 3 | S | D1 = 3.5 percent |
| Billing Line | (Tax Amount) × (Retainage percent) = Deferred Tax |
| Billing Line | (Tax Amount) – (Deferred Tax) = (Tax Amount Current) |
| Deferred Taxes | 10.50 | |
| 001 | R | 7.00– | 207.00– | 200.00– | 7.00– | RETN |
| 002 | R | 3.50– | 103.50– | 100.00– | 3.50– | RETN |
| 001 | 2,063.00 | 63.00 | 2,000.00 | 200.00 | RETN | 3 | 7.00 |
| 002 | 1,031.50 | 31.50 | 1,000.00 | 100.00 | RETN | 3 | 3.50 |
| LNID | TCLS | AA |
| .100 | R | 200.00 |
| .100 | R | 7.00 |
| .200 | R | 100.00 |
| .200 | R | 3.50 |
This table lists a field in the Summarized Journal Workfile table (F48S911) that relates to retainage and that is populated during Invoice Generation with Invoice Journal Generation:
| AA | Account |
| 10.50 | Deferred Tax |
| RI | 002 | November 15, 2005 | 931.50 | 931.50 | A | Application 1 Adjust. 0 |
| 2,794.50 | 2,794.50 |
Example setup
Invoice generation
Tax calculations
In this example, one retainage rule is set at the contract level. The calculation is based on 30 percent completion of the contract. The control flag is set to blank to create retainage in A/R and no deferred taxes. The T and M line has no schedule of values.
| D | 10 percent Retainage until 30 percent Complete |
| Contract | D | RETN | S | D1 = 3.5 percent |
| 001 | T and M | 000 | 1,200.00 | 42.00 | 1,242.00 | 60.00 | |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 300.00 |
| Change Order Total | 12,000.00 | 7,200.00 | 252.00 | 7,452.00 | 360.00 | ||
| Contract Total | 12,000.00 | 7,200.00 | 252.00 | 7,452.00 | 360.00 |
This equation shows how the system calculated the percent complete:
| (Net Amount) ÷ (Schedule of Values) = (Percent Complete) |
| 7,200.00 ÷ 12,000.00= 0.6 |
This equation shows how the system calculated the total retainage:
| (Schedule of Values) × (Retainage Completion) × (Retainage Percentage) = (Retainage Amount) |
| 12,000.00 × 0.30 × 0.10 = 360.00 |
This table shows how the system calculated the retainage for each billing line:
| Billing Line | (Net Amount) ÷ (Total Net Amount) × (Retainage Amount) = Billing Line Retainage Amount |
| 001 | 1,200.00 ÷ 7,200.00 × 360.00 = 60.00 |
| 002 | 6,000.00 ÷ 7,200.00 × 360.00 = 300.00 |
| 001 | 1,200.00 × 0.035 = 42.00 |
| 002 | 6,000.00 × 0.035 = 210.00 |
Example setup
Invoice generation
Tax calculations
In this example, one retainage rule is set at the contract level. The calculation is based on 30 percent completion of the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has a schedule of values.
| 001 | T and M | 000 | 5,000.00 | 1,200.00 | 42.00 | 1,242.00 | 85.00 |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 425.00 |
| Change Order Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 510.00 | ||
| Contract Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 510.00 |
| 7,200.00 ÷ 17,000.00 = 0.423529411 |
| 17,000.00 × 0.30 × 0.10 = 510.00 |
| Billing Line | (Net Amount) ÷ (Total Net Amount) × (Retainage Amount) = (Billing Line Retainage Amount) |
| 001 | 1,200.00 ÷ 7,200.00 × 510.00 = 85.00 |
| 002 | 6,000.00 ÷ 7,200.00 × 510.00 = 425.00 |
| 002 | 6,00.00 × 0.035 = 210.00 |
Example setup
Invoice generation
Tax calculations
In this example, one retainage rule is set at the contract level. The calculation is based on two different percent completions on the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has no schedule of values.
This table shows how retainage rule E (Multi RETN Percentages on Completion) is set up in the Retainage Rules Table program (P5204):
| Percent Retainage | Percent Complete |
| 10 percent | 20.00 |
| 15 percent | 38.00 |
| Contract | E | RETN | S | D1 = 3.5 percent |
| 001 | T and M | 000 | 1,200.00 | 42.00 | 1,242.00 | 94.00 | |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 470.00 |
| Change Order Total | 12,000.00 | 7,200.00 | 252.00 | 7,452.00 | 564.00 | ||
| Contract Total | 12,000.00 | 7,200.00 | 252.00 | 7,452.00 | 564.00 |
| (Net Amount) ÷ (Schedule of Values) = Percent Complete |
| 7,200.00 ÷ 12,000.00 = 0.60 |
These equations illustrate how the system calculated the total retainage:
| Percent Complete | (Schedule of Values) × (Retainage Completion) × (Retainage Percentage) = (Retainage Amount) |
| 20 percent | 12,000.00 × 0.20 × 0.10 = 240.00 |
| 38 percent - 20 percent = 18 percent remaining to be calculated | 12,000.00 × 0.18 × 0.15 = 324.00 |
| Total | 240.00 + 324.00 = 564.00 |
| 001 | 1,200.00 ÷ 7,200.00 ×564.00 = 94.00 |
| 002 | 6,000.00 ÷ 7,200.00 × 564.00 = 470.00 |
Example setup
Invoice generation
Tax calculations
In this example, one retainage rule is set at the contract level. The calculation is based on three different completion percentages on the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has a schedule of values.
This table shows how retainage rule F (Multi RETN Percentages on Completion) is set up in the Retainage Rules Table program (P5204):
| 25 percent | 60.00 |
| Contract | F | RETN | S | D1 = 3.5 percent |
| 001 | T and M | 000 | 5,000.00 | 1,200.00 | 42.00 | 1,242.00 | 164.00 |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 820.00 |
| Change Order Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 984.00 | ||
| Contract Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 984.00 |
| 20 percent | 17,000.00 × 0.20 × 0.10 = 340.00 |
| 38 percent – 20 percent = 18 percent remaining to be calculated | 17,000.00 × 0.18 × 0.15 = 459.00 |
| Percent complete on the contract is 0.423529411 – 0.38 = 0.043529411 percent complete remaining to be calculated. | 17,000.00 × 0.043529411 × 0.25 = 185.00 |
| Total | 340.00 + 459.00 + 185.00 = 984.00 |
| 001 | 1,200.00 ÷ 7,200.00 × 984.00 = 164.00 |
| 002 | 6,000.00 ÷ 7,200.00 × 984.00 = 820.00 |
| Total | 164,00 + 820.00 = 984.00 |
Example setup
Invoice generation
Tax calculations
In this example, a retainage rule is set both at the contract level and on both billing lines on the contract. The calculation is based on three different completion percentages on the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has a schedule of values.
| Contract | F | RETN | S | D1 = 3.5 percent | |
| Billing Line 001 | F | RETN | S | D1 = 3.5 percent | |
| Billing Line 002 | F | RETN | S | D1 = 3.5 percent |
| 001 | T and M | 000 | 5,000.00 | 1,200.00 | 42.00 | 1,242.00 | 130.00 |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 924.00 |
| Change Order Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 1,054.00 | ||
| Contract Total | 17,000.00 | 7,200.00 | 252.00 | 7,452.00 | 1,054.00 |
This table shows how the system calculated the percent complete for each billing line:
| Billing Line | (Net Current Amount) ÷ (Schedule of Values) = Percent Complete |
| 001 | 1,200.00 ÷ 5,000.00 = 0.24 |
| 002 | 6,000.00 ÷ 12,000.00 = 0.50 |
This table shows how the system calculated the retainage for billing line 001:
| Billing Line | (Schedule of Values) × (Percent Complete) × (Retainage Percentage) = Billing Line Retainage Amount |
| 001 | 5,000.00 × 0.20 ×.10 = 100.00 |
| 001 | 5,000.00 × 0.04 ×.15 = 30.00 |
| Total | 100.00 + 30.00 = 130.00 |
This table shows how the system calculated the retainage for billing line 002:
| Percent Complete | (Schedule of Values) × (Percent Complete) × (Retainage Percentage) = Billing Line Retainage Amount |
| 20 percent | 12,000.00 ×.20 × 0.10 = 240.00 |
| 38 percent – 20 percent = 18 percent remaining to be calculated | 12,000.00 ×.18 × 0.15 = 324.00 |
| 50 - 0.38 (retainage completion already calculated) = 12 percent complete on billing line | 12,000.00 ×.12 × 0.25 = 360.00 |
| Total | 240.00 + 324.00 + 360.00 = 924.00 |
Example setup
Invoice generation
Tax calculations
In this example, payment terms with discounts and one retainage rule are set at the contract level. The calculation is based on 100 percent completion of the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has no schedule of values, but does have a markup of 25.00 on the T and M line.
| Contract Part | Retainage Rule | Offset | Control Flag | Tax Explanation | Tax Rate/Area | Payment Terms |
| Contract | A | RETN | S | D1 = 3.5 percent | 1/10 Net 30 |
| 001 | T and M | 000 | 1,225.00 | 42.88 | 1,267.88 | 122.50 | |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 600.00 |
| Change Order Total | 12,000.00 | 7,200.00 | 252.88 | 7,477.88 | 722.50 | ||
| Contract Total | 12,000.00 | 7,225.00 | 252.88 | 7,477.88 | 722.50 |
This table shows how the system calculated the taxable amounts:
| Billing Line | ((Cost Amount) + (Markup Amount)) × (Tax Rate) = (Taxable Amount) |
| 001 | (1,200.00 + 25.00) × 0.035 = 42.88 |
| 002 | (6,000.00 + 0.00) × 0.035 = 210.00 |
| Billing Line | ((Cost Amount) + (Markup)) × (Retainage Amount) = (Billing Line Retainage Amount) |
| 001 | (1,200.00 + 25.00) × .10 = 122.50 |
| 002 | (6,000.00 + 00.00) × .10 = 600.00 |
This table shows how the system calculated the discount for each billing line:
| Billing Line | ((Cost Amount) + (Markup) – (Retainage)) × (Discount Percent) = (Discount Amount) |
| 001 | (1,200.00 + 25.00 – 122.50) × .01 = 11.03 |
| 002 | (6,000.00 + 00.00 – 600) × .01 = 54.00 |
Example setup
Invoice generation
Tax calculations
In this example, payment terms with discounts and one retainage rule are set at the contract level. The calculation is based on 30 percent completion of the contract. The control flag is set to blank to create retainage in A/R with no deferred taxes. The T and M line has no schedule of values, but has a markup of 25.00 on the T and M line.
| Contract | D | RETN | S | D1 = 3.5 percent | 1/10 Net 30 |
| 001 | T and M | 000 | 1,225.00 | 42.88 | 1,267.88 | 61.04 | |
| 002 | Lump Sum | 000 | 12,000.00 | 6,000.00 | 210.00 | 6,210.00 | 298.96 |
| Change Order Total | 12,000.00 | 7,200.00 | 252.88 | 7,477.88 | 360.00 | ||
| Contract Total | 12,000.00 | 7,225.00 | 252.88 | 7,477.88 | 360.00 |
| 001 | (1,200.00 + 25.00) × .035 = 42.88 |
| 002 | (6,000.00 + .00) × .035 = 210.00 |
| 7,200.00 ÷ 12,000.00= .6 |
This equation shows how the system calculated the retainage amount:
| 12,000.00 × .30 × .10 = 360.00 |
| Billing Line | ((Net Amount) + (Markup)) ÷ ((Total Net Amount) + (Markup)) × (Total Retainage Amount) = (Billing Line Retainage Amount) |
| 001 | (1,200.00 + 25.00) ÷ (7,200.00 + 25.00) × 360 = 61.04 |
| 002 | (6,000.00 + 00.00) ÷ (7,200.00 + 25.00) × 360 = 298.96 |
| Billing Line | ((Cost Amount) + (Markup) - (Retainage)) × (Discount Percent) = (Discount Amount) |
| 001 | (1,200.00 + 25.00 - 67.27) × .01 = 11.64 |
| 002 | (6,000.00 + 00.00 - 329.48) × .01 = 57.01 |
