This chapter contains the following topics:
A characteristic of today's markets for multi-attribute items is fierce global competition. Every company needs to globalize in order to grow market share and extend its supply chain. Companies outsource production to leverage cost and response-time efficiencies. They may also outsource logistics functions, using the services of partners to manage storage or packaging.
The goal of these models is to improve responsiveness to demand while providing tighter control of the whole business cycle. Business is embracing a truly collaborative approach among partners in the supply chain.
Customer expectations are increasingly volatile and at the same time increasingly specific. To meet these conflicting demands and yet maintain position in the market, manufacturers must both multiply the number of end items and customize the end items. This creates the requirement for style items, which are items assembled from characteristics such as style, fabric, color, length, and other variables. The number of child or end style items available is based on the number of attributes and levels for a parent-level style item.
The JD Edwards EnterpriseOne Apparel Management system from Oracle supports any product produced with differentiated multiple attributes such as sizes, lengths, colors, widths, and materials. The JD Edwards EnterpriseOne Apparel Management system capabilities may apply to such industries as:
Steel
Paper
Furniture
Apparel
Carpets
Linens
Automotive parts
Consumer electronics
Medical
The steel industry manufactures hot-rolled sheet metal, which is stored in rolls that are, for example, 6 feet wide, 5 feet in diameter, and weigh approximately 40,000 pounds. The manufacture of hot-rolled steel includes such characteristics as material, gauge (thickness), and width.
A steel supplier purchases hot-rolled steel from the manufacturer and puts the sheet metal through a leveling process. The leveling process both unrolls and flattens the sheet metal, which the supplier then cuts to length. The sheet metal product is presented in sheets to be used for the manufacture of cabinets, sheet metal parts such as registers or radiator grates, and metal roofing and siding for steel buildings. The product characteristics of the sheet metal sold by the supplier are material, gauge (thickness), width, and length.
An example of a style item in the steel industry is metal roofing. The style item is metal roofing and the style item attributes or levels are 14 gauge rolled steel, 4 feet wide, 10 feet long, and green in color.
The paper industry produces paper products such as printing paper, condenser paper, tea bags, paper towels, and toilet paper. Characteristics of paper include the material, which consists of a chemical composition specifically formulated for usage, color, thickness, and width and can be shipped per customer's roll diameter specifications.
An example of a style item in the paper industry is a paper towel. Characteristics of a roll of paper towels include:
Number of ply sheets, such as 1 or 2.
Size of the ply sheet, such as 11 x 11 inches.
Thickness of each ply sheet.
Number of sheets per roll, such as 90.
Type of core (diameter and material).
The paper is manufactured, plied, cored, and cut to customer specifications. The rolls of paper towels are then packaged on a pallet and shipped to the packaging and distribution warehouse. Paper towels can be packaged and sold in single rolls or packages of 3, 6, or 12.
The furniture industry manufactures furniture in various configurations. For example, in the configuration of a sofa style item, variables may include the frame, feet, arms, back cushions, and bottom cushions.
The apparel industry is a highly competitive market that provides different items for different customers. The diverse profiles of apparel industry customers add complexity to the mix. Each customer has its own set of expectations, which must be met simultaneously.
Buying consumers in the apparel industry include men, women, and children.
An example of a style item in the apparel industry is jeans. Jeans have inside leg measurements, which allow the customer to benefit from a customized item at the price of ready-to-wear.
The apparel manufacturing industry has moved sharply towards a business model of design, marketing, and distribution. The typical time frame for an apparel item from concept to delivery is approximately two years. This diagram illustrates the product life cycle of apparel items:
The product life cycle begins with the design of apparel items. If collections are used, then collection development begins as well. Product and collection development encompass seasonal and permanent items.
The forecast generated for seasonal items is typically defined as a best-guess estimate based upon customer trends. You forecast at the item level and then drive planning down to material requirements planning (MRP) generation at the item level.
An item may start as a seasonal item, but the hope is that it will become a permanent item if possible. An example of a seasonal item is a swimsuit. It may be a seasonal item in one market, but may become a permanent item in a market that sells swimwear year round.
The forecast for permanent items is fairly standard. You forecast at the item level, which also drives MRP at the item level. The delivery of permanent items is in a short time frame. An example of a permanent item is jeans, which are available year round.
Technical and industrial development planning commences soon after apparel item development begins. The technical and industrial development phase entails the development of bills of material and routings required to manufacture items. This phase also includes the specification of machines required for production and determination of subcontracting requirements for outside operations.
Material purchasing activities acquire the necessary fabrics, zippers, buttons, and other items required to manufacture the apparel items. Blanket orders for purchasing are used because you know at the beginning that you will need a specific number of yards of fabric. You enter a blanket order with the supplier to reserve the material quantities needed, and then you release the purchase orders at different times to support the manufacturing process.
Approximately nine months into the development of apparel items, the pilot manufacturing run is performed.
At the end of the first year of development, wholesale selling begins. Manufacturing of the apparel items begins at the end of the development, planning, and purchasing phases. Delivery begins once manufacturing is underway. Delivery may be in a short time frame of four to six weeks to deliver all items.
The last phases involve the sale, manufacture, and delivery of replenishment items. If you have replenishment orders but you do not remanufacture, then you replenish with whatever items you have left.
The life cycle of permanent apparel items works a bit differently than seasonal collections because material is needed all the time.
Ready-to-wear apparel is made in standard sizes and available from merchandise in stock. The customer looks for characteristics such as style, color, and size when purchasing the ready-made items.
Children's ready-to-wear apparel supports a large number of sizes in the same item.
Examples of ready-to-wear apparel products include but are not limited to:
Socks and sockets.
Lingerie and beachwear.
Leather goods.
Costume jewelry.
Sporting attire.
Socks and sockets are ready-made items. Sockets are lining socks or small anklet socks.
The manufacturing process for socks and sockets consists of:
Threading
Dyeing
Knitting
Assembling
The distribution channels imply the packaging, brand, and selling units. The same sock can have different brand names.
Socks have multiple units of measure, which include the weight of the thread, dimensions (knit), and selling units of the end-item. For example, you can sell socks by pairs, and by two or three pairs.
Lingerie and beachwear are multi-attribute items. The number of attributes managed for both items is not the same. Style, color, and size make up various components. Style is differentiated by what is drawn up by the stylist. The style is always the same, but the color and size can be different.
A top consists of style, color, straps, size, and cup. A bottom consists of style, color, and size.
Lingerie and beachwear can be seasonal and permanent items depending on the market area. Color depends on the season, and price may vary by color.
Leather goods for the apparel industry include anything made of leather that can be worn, such as jackets, vests, hats, boots, pants, and belts for any consumer.
Costume jewelry comprises necklaces, earrings, and bracelets. Jewelry may have themes, such as bridal, vintage, and western as examples.
This section discusses:
The JD Edwards EnterpriseOne Apparel Management system.
Industry trades.
The JD Edwards EnterpriseOne Apparel Management system supports style items in distribution and manufacturing industries. The JD Edwards EnterpriseOne Apparel Management system integrates with other JD Edwards EnterpriseOne systems from Oracle to create a complete supply chain solution. Companies can use the JD Edwards EnterpriseOne Apparel Management system to effectively manage complex product assortments and continuous product line innovation throughout their entire supply chain.
The business processes for style items can be more complex than those for standard manufactured items because of the multiple attributes associated with style items.
The JD Edwards EnterpriseOne Inventory Management system integrates with the JD Edwards EnterpriseOne Apparel Management system to define and manage style items. The JD Edwards EnterpriseOne Apparel Management system enables you to view, adjust, issue, and transfer groups of child style items based on their multi level hierarchical definitions.
A collection may be put together by a manufacturer or designer each season to showcase new trends for a particular market. A collection template is a subset of style items from one or more collections. These templates are used during sales order entry, as well as purchase order entry, to simplify the process of entering orders. A collection template contains frequently ordered style items.
JD Edwards EnterpriseOne Sales Order Management for Apparel Management provides a matrix entry form for supporting customer orders. For each style item or collection template, the system displays a matrix entry form on which you can enter item quantities by size, color, or any other attributes. JD Edwards EnterpriseOne Sales Order Management for Apparel Management integrates with Sales Price List, Allocations, Inventory Management, and Collection Management. You can also perform a mass update of sales order style items only.
The JD Edwards EnterpriseOne Apparel Management system facilitates the wholesale allocation and delivery of style items. You use allocation rules to facilitate the effective and efficient distribution of available style items to fill sales orders. You generate allocation and delivery proposals. Allocation proposals enable you to share the available stock among several sales orders in the case of product shortages. Delivery proposals ensure consistent deliveries to customers.
To perform allocations for style items you set up commitment rules, generate allocation proposals, generate delivery proposals, and validate allocation and delivery proposals.
After you set up the style item root level 0 and child style items in the JD Edwards EnterpriseOne Apparel Management system, you can use the JD Edwards EnterpriseOne Product Data Management system to set up bills of material, create routings, and set up outsource operations for the manufacture of style items.
The JD Edwards EnterpriseOne Requirements Planning and JD Edwards EnterpriseOne Apparel Management systems integrate to support material planning for style items. The systems facilitate message review and preserve data consistency by enabling a matrix view of the lowest level child style items. You can process messages, add quantities by size, split messages, group messages, calculate adjustments, and generate transfer orders for style items.
After you enter style items and collections, bills of material, and routings, you can use programs in the JD Edwards EnterpriseOne Shop Floor Management system to complete the manufacture of style items. The JD Edwards EnterpriseOne Shop Floor Management system enables you to manage and track manufacturing work orders. A master work order is a collection of individual standard manufacturing work orders that correspond to the child style items.
The JD Edwards EnterpriseOne Procurement Management system integrates with the JD Edwards EnterpriseOne Apparel Management system to enable you to create purchase prices, enter blanket orders, enter purchase orders, release blanket orders, and print purchase orders for style items and collections.
The JD Edwards EnterpriseOne Apparel Management system supports the manufacture and wholesale distribution of style items.
This diagram illustrates the industry trades for JD Edwards EnterpriseOne Apparel Management:
Figure 2-2 Industry trades for JD Edwards EnterpriseOne Apparel Management
The JD Edwards EnterpriseOne Apparel Management system integrates with JD Edwards EnterpriseOne Manufacturing systems to support the planning and manufacturing of style items. The system also supports the outsourcing of operations.
The JD Edwards EnterpriseOne Apparel Management system integrates with JD Edwards EnterpriseOne Distribution systems to support the sale and distribution of style items. Wholesale distribution involves selling to a distributor.
Note: The JD Edwards EnterpriseOne Apparel Management system does not support consignment and is not a retail solution. |
