12 Working With General Ledger Functionality for Peru
This chapter contains the following topics:
12.1 Reviewing Ledgers by Legal Number for Peru
This section lists the forms used to review ledgers by legal numbers and discusses how to set processing options for Journal Entries Inquiry by Legal Number (P76H9002).
12.1.1 Form Used to Review Ledgers by Legal Number
Form Name Form ID Navigation Usage
Journal Entries Inquiry by Legal Number W76H9002A General Accounting (G76P09), Journal Entries Inquiry by Legal Number Review journal entries by legal number.
12.1.2 Setting Processing Options for Journal Entries Inquiry by Legal Number (P76H9002)
Processing options enable you to specify the default processing for programs.
12.1.2.1 General
Ledger Type
Enter the UDC table in which you specified the ledger types to process. If you do not complete this processing option, the system uses UDC table 76H/LL.
12.2 Reviewing Account Balances by Account and Category Code for Peru
This section lists the forms used to review balances by account and category code and discusses how to set processing options for Balance Inquiry by Account/Category Code (P76H9006).
12.2.1 Form Used to Review Account Balances by Account and Category Code
Account Balance Inquire W76H9006A General Accounting (G76H09) or General Accounting (G76P09), Balance Inquiry by Account/Cat. Code Display balances by account and subsidiary or by category code, as well as by business unit with detail or summary information.
12.2.2 Setting Processing Options for Balance Inquiry by Account/Category Code (P76H9006)
Use these processing options to specify how to display cost centers, the level of detail in which to summarize balances, the process method, and so on.
12.2.2.1 Process
1. Cost Center
Specify how to display cost centers. Values are:
Blank: Display detail by cost center.
1: Display all of the cost centers for a legal company and display summary information for the object and subsidiary account.
2. Level of Detail
Specify the level of detail. The system summarizes all general ledger balances by the account level of detail specified. Values are 3–9. The default value is 9.
3. Legal Company
Specify the company number in which to retrieve general ledger balances.
4. Process Method
Specify the process method. Values are:
Blank: Display asset and liabilities according to the operation sign. Asset accounts appear with a positive sign in the Asset column and liabilities appear with a negative sign in the Liability column.
A: Display asset accounts in the Asset column and liability accounts in the Liability column according to AAI items GLG2 (Beginning Assets) and GLG3 (Beginning Liabilities).
5. Business Unit
Specify the business unit in which to display object and subsidiary accounts.
6. Ledger Type
Specify the ledger type code from UDC table 76H/XX. The system uses LL (ledger types to process) as the default value.
7. Category Code
Specify the category code from UDC table 09/21–09/23 in which to group the GL accounts. The system displays the category code description instead of the GL account.
If you leave this processing option blank, balances are grouped and displayed by object and subsidiary account.
12.2.2.2 Print Options
Accounts with Zero Amounts
Specify whether to display accounts with zero amounts.
Blank: Do not display accounts with zero amounts.
1: Display accounts with zero amounts.
2: Do not display accounts with zero amounts and with the same level of detail that is specified in the Level of Detail processing option.
12.2.2.3 Dates
Period Number
Specify the tax period to display on the form.
Fiscal Year
Specify the fiscal year to display on the form.
12.3 Reviewing Debit and Credit Balances by Month for Peru
This section lists the form used to review debit and credit balances by month and discusses how to set processing options for Debit/Credit Inquiry by Month (P76H9007).
12.3.1 Form Used to Review Debit and Credit Balances by Month
Account Balances W76H9007A General Accounting (G76H09) or General Accounting (G76P09), Debit/Credit Inquiry by Month Display debit and credit balances by account number and month.
12.3.2 Setting Processing Options for Debit/Credit Inquiry by Month (P76H9007)
Use these processing options to set default values for the Account Balances form.
12.3.2.1 Defaults
Fiscal Year
Ledger Type
Specify the ledger type code to display from UDC table 76H/XX. The system uses LL (ledger types to process) as the default value.
Subledger and Subledger Type
Specify the subledger and subledger type to display. To display account balances for all subledgers, enter *.
Currency Code
Specify the currency code in which to display debit and credit amounts. To display accounts balances for all currency codes, enter *.
12.4 Reposting the Account Ledger Tag File for Peru
  • Run the Localization Account Repost program.
  • Set processing options for Localization Account Repost.
12.4.1 Running the Localization Account Repost Program
Select General Accounting (G76H09 or G76P09), Localization Account Repost
12.4.2 Setting Processing Options for Localization Account Repost (R76H9102)
Use these processing options to specify the processing mode as well as comparison between tables.
12.4.2.1 Mode
1. Process Mode
Specify the processing mode. Values are:
1: Proof mode.
Prints the report and shows the differences between the F0911 and F76H902T tables.
2: Final mode.
Prints the report and updates the F0902 table. Shows the differences between the F0911 and F76H902T tables and updates the F76H902T table.
2. F0902 Balance
Specify whether to compare the balances in the F76H902T table to the F0902 table:
Blank: Do not compare the balances.
1: Compare the balances.
3. F0911 Entries
Specify whether to check for records that are in the F76H0902T table and are missing in the F0911 table:
Blank: Do not check for missing entries.
1: Check for missing entries.
