An object that contains a set of instructions for BI Publisher to retrieve and structure data for a report. Data models reside as separate objects in the catalog. It includes the sample grid data, form level information, and the reference to the data source.
A template file and a set of properties for rendering the template file that define how data is presented in the report. BI Publisher supports templates created from a variety of sources including Microsoft Word, Adobe Reader, Microsoft Excel, Adobe Flash, and BI Publisher's own layout editor. A report can include multiple layouts.
A report that consists of a reference to the BI Publisher data model, BI Publisher layouts, properties, and translations.
An integrated report that contains a JD Edwards EnterpriseOne report definition and a BI Publisher data model and report.
A One View report that is located in a user's personal folder and owned by that person.
The JD Edwards EnterpriseOne meta data about the One View report. The report definition contains information about which columns are selected in the data model, the naming conventions, rowset setting, and the name of the report.
