This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Accounts Payable Payment business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Real-Time Events | This list includes the real-time events for the Accounts Payable Payment business object: |
| Batch Export Programs | This list includes the batch export programs for the Accounts Payable Payment business object: |
Note: You can find additional techincal information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Accounts Payable Payment business object which include:
RTRAOUT is a container event that provides AP Payment Remittance information to third-party system. RTRAOUT is an aggregate event that contains these single events:
RTRAHDR - contains AP Payment Remittance Advice header information that can be used by another system.
RTRADTL - contains AP Payment Remittance Advice detail information that can be used by another system.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code |
| RTRAOUT | Accounts Payable Payment | RTE | Container
Container event for:
04 |
Please see the appropriate real-time events that are contained by this event for information about the event fields.
Conceptual Approach
An payment made in the JD Edwards EnterpriseOne system updates new records in the Accounts Payable - Matching Document (F0413) and Accounts Payable Matching Document Detail (F0414) tables. A real-time notification event is triggered in the payments system after this payment is made in JD Edwards EnterpriseOne tables.
The Send Method field (A6CRMD) in the Supplier Master (F0401) table controls whether JD Edwards EnterpriseOne sends a RemittanceAdviceNotify real-time event notification when RTRAOUT is enabled. A real-time event notification is sent only if the supplier has a value of 5 in the Send Method field.
Objects that Can Initiate the Event
These objects can initiate the RTRAOUT event, and the single events contained within it:
N0400061 - Remittance Advice Notification For Manual Payments
Suppliers who want to receive remittance advice notification must be set up to receive external events. To receive external events, set Send Methods equal to 5 (External Events) on the EDI information tab in the Supplier Master program (P04012).
RTRAHDR is a single event that contains payment remittance advice header information that can be used by another system.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
| RTRAHDR | AP Payment Header | RTE | Single | 04 | D0400169A: Remittance Advice - Header | Included in container event RTRAOUT. |
Conceptual Approach
A payment made in the JD Edwards EnterpriseOne system updates new records in the Accounts Payable - Matching Document (F0413) and Accounts Payable Matching Document Detail (F0414) tables. A real-time notification event is triggered in the payments system after payment is made in JD Edwards EnterpriseOne tables.
RTRADTL is a single event that contains payment remittance advice detail information that can be used by another system.
| RTRADTL | AP Payment Details | RTE | Single | 04 | D0400169B: Remittance Advice - Detail | Included in container event RTRAOUT. |
Conceptual Approach
A payment made in the JD Edwards EnterpriseOne system updates new records in the Accounts Payable - Matching Document (F0413) and Accounts Payable Matching Document Detail (F0414) tables. A detailed real-time notification event is triggered in the payments system after a payment is made in JD Edwards EnterpriseOne tables.
You use batch export programs to retrieve and format data from the JD Edwards EnterpriseOne database so that it can be used by an external software system.
This table lists and describes the available batch export programs that are associated with the Accounts Payable Payment business object:
