This chapter discusses these topics:
Section 6.1, "Equipment Work Order Time Entry Mobile Applications Overview"
Section 6.2, "Setting Up the Equipment Work Order Time Entry Mobile Applications"
Section 6.3, "Using the Equipment Work Order Time Entry Mobile Tablet Application (M0511211)"
Section 6.4, "Using the Equipment Work Order Time Entry Mobile Smartphone Application"
Important Note: Before using the mobile applications, Oracle strongly recommends that users have a complete understanding of how to use the associated processes and applications in the JD Edwards EnterpriseOne base software.For additional information about the processes and applications associated with the mobile applications discussed in this chapter, see:
You use the Equipment Work Order Time Entry mobile applications to enter, search, edit, and delete equipment timecards. The smartphone and tablet applications enables you to enter time against a piece of equipment, and also update and review each timecard's work date, employee hours, work order number, pay type, operation sequence, equipment worked and hours. You can use the filters or history to search for equipment timecards.
This table lists the applications that are available to review existing timecard information and to enter new timecard information for employees:
| Type of Application | Additional Information |
| Base EnterpriseOne application | To update existing timecards, and to enter new timecards for equipment work order time entry, use the Speed Time Entry program (P051121) in the JD Edwards EnterpriseOne system. |
| Tablet application | Equipment Work Order Time Entry (M0511211)
To download the application to your tablet, search on the following text in the application store:
| Smartphone application | Equipment Work Order Time Entry (M0511212)
Mobile applications are intended to be a simplified version of the applications that are available in the base software. In most cases, these applications provide a subset of the functionality available in the base software.
The functions of Equipment Work Order Time Entry mobile applications are not different from base EnterpriseOne applications. However, Equipment Work Order Time Entry mobile applications do offer the user a subset of equipment work order timecards information. Not all the work order timecard information available in the base software is available in the mobile applications.
Barcode Scanning (Release 9.1 Update)
The Equipment Work Order Time Entry tablet application (M0511211) and the Equipment Work Order Time Entry smartphone application (M0511212) are designed to scan data from a barcode and populate the equipment number in the Equipment Worked field. To scan barcode data, you can use the native camera on your device or a third-party handheld Bluetooth-enabled scanning device. To use this functionality, you must create barcodes that represent a single field in the JD Edwards EnterpriseOne system. This application does not accept barcodes that consist of data for multiple fields.
You can generate barcodes using services such as those offered by Barcodes Inc.
Note: Oracle is not affiliated with Barcodes, Inc. and does not require or recommend that you use this service to create your barcodes. |
Before using the Equipment Work Order Time Entry mobile applications, verify that the processing options for each application are set correctly. The processing options for both the tablet and the smartphone applications specify which versions of the base EnterpriseOne applications the mobile applications use.
The system administrator must set the processing options for these mobile applications before the applications are made available to end users.
See Setting Processing Options for the Speed Time Entry Program (P051121) in the JD Edwards EnterpriseOne Time and Labor Implementation Guide.
(Release 9.1 Update) You can use one of the following options to scan barcodes of equipment number:
Disable the Bluetooth option in the settings on your device if you want to use the native device camera to scan the barcodes of equipment number.
Enable the Bluetooth option if you want to use a Bluetooth-enabled scanning device to scan the barcodes of equipment number.
To scan barcodes using the Bluetooth scanning device, you must configure the scanning device to the mobile device.
You use processing options to specify default processing information for a program.
The Equipment Work Order Time Entry tablet application (M0511211) and the Equipment Work Order Time Entry smartphone application (M0511212) include the Equipment Worked field in two locations in the application. One is in the Equipment Work Order Time Entry screen for tablet and Details screen for smartphone that display when you select a specific equipment work order timecard. Another is the Equipment Work Order Time Entry screen for tablet and Details screen for smartphone that display when you add a new work order time entry. You can modify the equipment number of a specific equipment work order timecard in the Equipment Worked field. When you enter a new work order time entry using the Equipment Work Order Time Entry tablet and smartphone applications, you must enter the equipment number in the Equipment Worked field.
You can populate the Equipment Worked field (in the specific equipment work order timecard screen, as well as in the add new equipment work order time entry screen) using the following options:
Use the keyboard on your mobile device to manually enter the data.
Use the camera application on your mobile device to scan the data. To use this option, you must disable the Bluetooth option in your device settings.
Use a Bluetooth-enabled scanning device to scan the data. To use this option, you must:
Enable the Bluetooth option in your device settings.
Configure the third-party scanning device to connect to your mobile device.
Note: When you enable the Bluetooth option on your device, the system may disable the device's keyboard. |
The Equipment Work Order Time Entry tablet application enables you to:
Add equipment timecards.
Search and review existing equipment timecards.
Update equipment timecards.
Before you can use the application, you must download and install the application from the application store on your device.
To open the application, tap the icon and log in.
To review and update equipment work order timecards on your tablet:
Open the application by tapping the icon on your device, and then log in.
See Section 3, "Logging Into Mobile Enterprise Applications"
From the Equipment Work Order Time Entry home screen, review the timecards.
Figure 6-1 Equipment Work Order Time Entry
The system displays a list of timecards that were entered during the last seven days since the system date. To refresh the data on the screen, swipe down on the panel with the list of timecards.
Note that the timecards displayed in the list are also graphically displayed on the right side of the screen.
To search for equipment work order timecards, tap the History button at the top right of the Equipment Work Order Time Entry screen.
Note: The History button is available only on the home screen. You can use either the History or the Filter button in the application to search for equipment work order timecards. |
Figure 6-2 Equipment Work Order Time Entry - History
Include Locked Timecards
To include locked timecards, tap the Include Locked Timecards check box.
Work Order Number
To add a work order to your search criteria, you can use the Visual Assist icon to search for a value and return it to the Work Order Number field, or you can manually enter a work order number in the field.
Work Date
To select the work date range to display a specific work order timecard, tap the Work Date dropdown menus.
To continue the search, tap the Apply button.
To discontinue the search, tap the Cancel button.
To delete all the search values you specified, and to enter new search values, tap the Clear button.
To view detailed information of a specific equipment work order timecard, tap the timecard in the left pane, or the bar in the graph that coincides with the timecard that you want to view in the right pane.
To review equipment work order timecards for a specific day, tap the Day dropdown menu in the left pane and select an option from the list.
To review and update an equipment work order timecard, tap the timecard on the left pane.
Figure 6-3 Equipment Work Order Time Entry - Edit
On the Equipment Work Order Time Entry screen, work order number and work order description are non-editable.
Select the work date from the dropdown menu, enter the timecard details, and then tap Save.
Use the Search icons to search for and select values for the Pay Type, Operation Sequence, and Equipment Worked fields.
(Release 9.1 Update) Enter data in the Equipment Worked field using one of these options:
Use the keyboard on your mobile device to manually enter the data. Alternately, you can tap the search and select button to search and select a piece of equipment.
To use this option, tap the QR Code button next to the Equipment Worked field. The system launches the device camera and you can scan the barcode of the equipment.
To use this option, tap the Equipment Worked field to activate the scanning device. Then, scan the barcode of the equipment using the scanning device.
Note: The Equipment Worked field is designed to accept the asset that you identify with an identification symbol in the Fixed Assets Constants program (P001012).See Setting Up Fixed Asset Constants in the JD Edwards EnterpriseOne Applications Fixed Assets Implementation Guide. For example, if the symbol to identify the serial number is "/" and the serial number is "4CE0460D0G"; then you need to enter "/4CE0460D0G" in the Equipment Worked field to search and select a piece of equipment. |
To save an existing timecard, tap the Save button.
After, you save the timecard, the system updates and displays the new timecard in the left pane.
To delete the equipment work order timecard, tap the Delete button.
When you tap Delete button, the system displays a message Confirm Delete Yes or No.
If you select Yes, the system deletes the timecard from the time entry list.
If you select No, the system returns to the Equipment Work Order Time Entry screen.
To enter an equipment work order timecard on your tablet:
See Chapter 2, "Logging Into Mobile Enterprise Applications.”
To add an equipment work order timecard, tap the Add icon at the top right of the Equipment Work Order Time Entry list.
Figure 6-4 Equipment Work Order Time Entry - Add
On the Equipment Work Order Time Entry screen, select the work date from the dropdown menu, and enter the Employee Hours and Equipment Hours details.
Use the Search icons to search for and select values for the Work Order Number, Pay Type, Operation Sequence, and Equipment Worked fields.
Equipment Worked (Release 9.1 Update)
In the Add screen, after you add the timecard, tap the Save button.
The system displays a message Record Created. The system updates and displays the new timecard in the left pane.
To return to the home screen, tap the Charts button.
To log out of the application, tap the menu button at the bottom left of the screen, and then tap Logout.
The Equipment Work Order Time Entry smartphone application enables you to review and update equipment work order timecards.
To review and update equipment work order time entry on your smartphone:
From the Equipment Work Order Time Entry home screen, review the timecards for the past seven days.
To filter timecards, tap the Filters button at the top left of the Work Order Timecard list, and complete any of these fields to narrow your search:
Work Order Number
To add a work order to your search criteria, use the Search icon to search for a value and return it to the Work Order Number field. You can also manually enter a work order number in the field.
Work Date
In the Filters pane, to continue the search using the specified filter values, tap the Apply button. When you tap the Apply button, the system:
Takes you to the list of timecards that are displayed based on your filter values.
Saves the filter values that you entered. The system displays the saved filter values the next time you open the filter screen.
To discontinue the use of filter values in your search, tap the Cancel button. When you tap the Cancel button, the system:
Takes you to the list of work order timecards associated with the last saved filter values, if applicable.
Ignores the filter values that you entered, and restores the last saved filter values to the filter fields.
To delete all filter values you specified, and to enter new filter values, tap the Clear button.
To review and update the timecards, tap the existing work order timecards from the Work Order Time Entry list.
Figure 6-6 Equipment Work Order Time Entry - Edit
The system displays work order number and work order description by default, based on your work order timecard selection. You cannot edit the work order number and the work order description.
In the Details screen, select the work date from the Work Date dropdown menu. Then, enter the employee hours and equipment hours details.
Use the search icons to search and select values for the Pay Type and Operation Sequence fields for a specific work order timecard.
To save the work order timecard information, tap the Save button.
To go back to the home screen, tap the Cancel button.
To delete the timecard, tap the Delete button.
When you tap the Delete button, the system displays a message Confirm Delete Yes or No.
If you select No, the system return to the Equipment Work Order Time Entry screen.
To enter an equipment work order time entry on your smartphone:
To add timecards, tap the Add button at the top right of the Equipment Work Order list.
Figure 6-7 Equipment Work Order Time Entry - Add
On the Details screen, select the work date from the Work Date dropdown menu. Then, enter the Employee Hours and Equipment Hours details.
You can use the Visual Assist buttons to search and select values for the Work Order Number, Pay Type, and Operation Sequence fields.
To use this option, tap the QR Code button next to the Equipment Number field. The system launches the device camera and you can scan the barcode of the equipment.
To use this option, tap the Equipment Number field to activate the scanning device. Then, scan the barcode of the equipment using the scanning device.
On the Details screen, after, you add the timecard, tap the Save button.
To return to the home screen, tap the Cancel button.
