See also Berkeley DB notes on Solaris
Solaris build commands
Normal build command for Solaris using Sun Workshop 64-bit and no options:
bash ./buildall.sh -c cc -x CC \ --with-configure-env="CFLAGS='-xarch=v9' \ CXXFLAGS='-xarch=v9' LDFLAGS='-xarch=v9'"
Normal build command for Solaris using Gnu tools and no options, 32-bit:
bash ./buildall.sh -c gcc -x g++ \ --with-configure-env="CFLAGS='-mcpu=v9' \ CXXFLAGS='-mcpu=v9' LDFLAGS='-mcpu=v9 \ -L$PWD/install/lib'"
Normal build command for Solaris using Gnu tools and no options, 64-bit:
export LD_LIBRARY_PATH=/usr/sfw/lib/64 bash ./buildall.sh -c gcc -x g++ --with-configure-env="CFLAGS='-m64 \ -mcpu=v9' CXXFLAGS='-m64 -mcpu=v9 -L$PWD/install/lib' \ LDFLAGS='-m64 -mcpu=v9 -L$PWD/install/lib
Some Solaris system can't build debug library with -g option, it is a known issue in sun's C++ library. Use -g0 instead.
When building using Sun Workshop there may be a link error indicating that the symbol "pow" or "sqrt" is undefined. If this occurs add "-lm" to LIBS in the build command.
