Table of Contents
The Berkeley DB XML distribution comprises several libraries: a base C++ library, three third-party libraries, and optional libraries for additional language interfaces such as Java, Perl, Python, PHP, and Tcl. Instructions for building the base libraries as well as Java and Tcl interfaces are included here. Instructions for the other language bindings appear in their respective directories:
dbxml-6.0.xx/dbxml/src/{perl,php,python}
All bindings require the C++ library and third-party libraries. Building for Linux, Mac OS X, and Cygwin (Windows) is the same as building for a conventional UNIX platform.
The Berkeley DB XML distribution uses the Free Software Foundation's
autoconf
and
libtool
tools to build on UNIX platforms. In general, the standard
configuration and installation options for these tools apply to the
Berkeley DB XML distribution. For ease of use Berkeley DB XML uses a
shell script called buildall.sh to drive the build process.
It wraps the configure and make
steps associated with autoconf.
Berkeley DB XML makes use of several third-party libraries. Berkeley DB XML provides a shell program that makes it possible to build all of the libraries in one command. The Berkeley DB XML distribution includes the complete source for compatible versions of the third-party libraries. No additional downloads are required. Use of other versions may not work, and may not be supported.
Each of these packages is freely available and distributed under an Open Source license, although Berkeley DB XML depends on specific versions of each. To build Berkeley DB XML, you will need the following third-party libraries:
Berkeley DB is a general purpose database toolkit. This release of Berkeley DB XML includes Berkeley DB 6.1.x release, and requires the Berkeley DB 4.3.28 release or later.
Xerces is the Apache implementation of XML parsing technology and DOM. The build requires a source release of Xerces, not just a binary release. This release of Berkeley DB XML bundles Xerces-C 3.1.2, and requires the Xerces 3.0.1 release or newer.
XQilla is an open source partial implementation of XQuery 3.0 and XPath 2.0. Berkeley DB XML bundles a specific public release of XQilla which must be used. Later versions of XQilla may work, but are not implicitly supported.
It is necessary to use GNU make (gmake) to build Berkeley DB XML and its third-party libraries. If you do not already have GNU make on your system, you will need to install it. When using gcc/g++, Berkeley DB XML requires at least a 3.x release of gcc.
These instructions assume that you are building in the Berkeley DB XML distribution. The simplest possible build command is the following:
cd dbxml-6.0.xx sh buildall.sh
This will configure, build, and install all of the libraries using default settings, which installs them into the following directory:
dbxml-6.0.xx/install
The default build supports the C++ interface only. The default build also compiles Berkeley DB XML examples, and places them in the following directory:
dbxml-6.0.xx/dbxml/build_unix
The buildall.sh script has a number of configuration
options. You can see them with this command:
sh buildall.sh --help
--enable-debug to build debug libraries
--prefix=path to change the default common
installation path (from ./install)
--enable-java to build the Java API. This also
requires that there is a working javac in your
PATH. The resulting .jar files are created in
the install/lib directory. Java examples are
also built, and put in:
dbxml-6.0.xx/dbxml/build_unix/dbxmlexamples.jar
--enable-perl to build the Perl interface
--disable-compression to disable default
compression
--clean to clean (make clean) the entire build
--distclean to clean (make distclean) the
entire build. This option clears the
configuration state as well as the compilation
state.
There is no option for per-library clean or rebuild in buildall.sh. See Building Individual Berkeley DB XML Libraries for UNIX for information on how to work with each library build.
The buildall.sh script has a number of configuration flags to
handle platform-specific issues, change target and destination
directories, as well as product configuration options. The flags
that start with "--with-" apply to each of the libraries,
depending on the name used. In these examples, "libname" is used to
represent one of "dbxml," "xerces," "xqilla," or "berkeleydb." For
example, a valid flag may be "--with-berkeleydb-prefix=path"
or "--with-xerces-prefix=path." The following is a partial
list of options:
--help
Use this flag to return a help message for buildall.sh.
--enable-debug
Use this flag to build with -g as a compiler
flag and with DEBUG #defined during compilation. This will
create libraries and utilities with debugging
symbols. This argument should not be specified when
configuring to build production binaries.
--enable-java
Use this flag to build with Java support. This
builds Java support for both Berkeley DB and
Berkeley DB XML. It is necessary to ensure that
there is a working javac in your PATH. The resulting
.jar files are created in the install/lib directory.
Java examples are also built, and put in:
--enable-perl
Use this flag to build with Perl support. This builds Perl support for both Berkeley DB and Berkeley DB XML. This option requires a working perl program in your PATH.
--with-tcl=path
Use this flag to build with Tcl support.
path is the directory in which
the Tcl tclConfig.sh file may be found. See
Loading Berkeley DB with Tcl in the Berkeley DB Programmer's Reference Guide for
information on sites from which you can download Tcl
and which Tcl versions are compatible with Berkeley
DB XML.
Disables default compression. Compression is turned on by default. Default compression requires the library ZLIB. --with-zlib can by used to specify the path to the ZLIB installation.
--enable-static-zlib
Causes the ZLIB library to be linked statically instead of dynamically.
--with-zlib=path
Default compression requires the ZLIB library. If ZLIB is not installed in the directory /usr/local then use this argument to specify the directory in which it is installed. If no ZLIB installation can be found then default compression is disabled automatically.
--enable-test
Enables test suite support. This option requres --with-tcl and --enable-debug, and if using --enable-java it also requires --with-junit.
--with-junit
Path to a JUnit (4) .jar file. This option is required if both --enable-test and -enable-java are specified.
-p platform
To specify a platform type to the Xerces runConfigure script, use -p platform. For most platforms, configure guesses the type correctly. Use this option only if there are configuration errors without it.
-c C compiler name
To build with C compiler other than gcc, specify the name of the compiler, for example, -c cc.
-x C++ compiler name
To build with C++ compiler other than g++, specify the name of the compiler, for example, -x cxx.
-m make_command
To build with make program other than make, specify
the name of the program. For example, -m gmake.
--no-configure
To build without re-running the configure step for each library, enter --no-configure as an argument to buildall.sh.
--clean
To clean compilation and linking object from all libraries, use --clean.
--distclean
To clean configuration state from all libraries, use --distclean. After this is done, configuration must be run again in order to build.
--build-one=library
To build, or clean only one of the libraries, use --build-one=library, where library is one of berkeleydb, xerces, xqilla or dbxml.
--prefix=path
To change the common installation directory prefix from the default (./install), specify an alternate path.
--with-libname=path
To use library sources from a location other than the default, specify a path to the source. For example, if Xerces source were located in /home/xerces-c-src_3_1_1, specify, --with-xerces="/home/xerces-c-src_3_1_1"
--with-libname-prefix=path
To change the installation directory for only a
single library, specify the path using
--with-libname-prefix=path. For example, if Berkeley
DB is to be installed in /usr/local/BerkeleyDB.6.1,
specify:
--with-berkeleydb-prefix="/usr/local/BerkeleyDB.6.0"
--with-libname-conf=configure flags
All of the library configurations use the configure program. Use --with-libname-conf=configure flags to pass library-specific configuration flags.
If buildall.sh does not provide enough control for your
environment, or if you have trouble with any of these commands,
please see the next section, which goes into more detail on build
options. At the end of that section, there is
information on what to do if build problems persist.
