Warning: the following information is intended to be generic and is likely to be correct for most UNIX systems. Unfortunately, dynamic shared libraries are not standard among UNIX systems, so there may be information here that is not correct for your system. If you have problems, consult your compiler and linker manual pages, or your system administrator.
The Berkeley DB XML dynamic shared libraries are created with the
name libdbxml-major
.minor
.so,
where major
is the major version number and
minor
is the minor version number. Other shared
libraries are created if Java and Tcl support are enabled:
specifically,
libdbxml_java-major
.minor
.so
and
libdbxml_tcl-major
.minor
.so.
On most UNIX systems, when any shared library is created, the linker
stamps it with a "SONAME". In the case of Berkeley DB XML, the
SONAME is
libdbxml-major
.minor
.so. It is
important to realize that applications linked against a shared
library remember the SONAMEs of the libraries they use and not the
underlying names in the filesystem.
When the Berkeley DB XML shared library is installed, links are
created in the install lib directory so that
libdbxml-major
.minor
.so,
libdbxml-major
.so, and libdbxml.so all refer to
the same library. This library will have an SONAME of
libdbxml-major
.minor
.so.
Any previous versions of the Berkeley DB XML libraries that are present in the install directory (such as libdbxml-2.7.so or libdbxml-2.so) are left unchanged. (Removing or moving old shared libraries is one drastic way to identify applications that have been linked against those vintage releases.)
Once you have installed the Berkeley DB XML libraries, unless they are installed in a directory where the linker normally looks for shared libraries, you will need to specify the installation directory as part of compiling and linking against Berkeley DB XML. Consult your system manuals or system administrator for ways to specify a shared library directory when compiling and linking applications with the Berkeley DB XML libraries. Many systems support environment variables (for example, LD_LIBRARY_PATH or LD_RUN_PATH), or system configuration files (for example, /etc/ld.so.conf) for this purpose.
Warning: some UNIX installations may have an
already existing /usr/lib/libdbxml.so
, and this
library may be an incompatible version of Berkeley DB XML. They also
may have installed, incompatible versions of Berkeley DB (libdb*.so),
Xerces-C (libxerces*.so) and XQilla (libxqilla*.so). Odd errors can
result from mixing/matching such versions.
We recommend that applications link against libdbxml.so (for example,
using -ldbxml). Even though the linker uses the file named
libdbxml.so, the executable file for the application remembers the
library's SONAME
(libdbxml-major
.minor
.so).
This has the effect of marking the applications with the versions
they need at link time. Because applications locate their needed
SONAMEs when they are executed, all previously linked applications
will continue to run using the library they were linked with, even
when a new version of Berkeley DB XML is installed and the file
libdbxml.so
is replaced with a new version.
Applications that know they are using features specific to a particular Berkeley DB XML release can be linked to that release. For example, an application wanting to link to Berkeley DB XML major release "3" can link using -ldbxml-3, and applications that know about a particular minor release number can specify both major and minor release numbers; for example, -ldbxml-3.5.
If you want to link with Berkeley DB XML before performing library
installation, the "make" command will have created a shared library
object in the .libs
subdirectory of the build
directory, such as
build_unix/.libs/libdbxml-major.minor.so
. If you
want to link a file against this library, with, for example, a major
number of "3" and a minor number of "5", you should be able to do
something like the following:
cc -L BUILD_DIRECTORY/.libs -o testprog testprog.o -ldbxml-3.5 env LD_LIBRARY_PATH="BD/.libs:$LD_LIBRARY_PATH" ./testprog
where BD
is the full directory path
to the directory where you built Berkeley DB XML.
The libtool program (which is configured in the build directory) can be used to set the shared library path and run a program. For example, the following runs the gdb debugger on the db_dump utility after setting the appropriate paths:
libtool gdb db_dump
Libtool may not know what to do with arbitrary commands (it is hardwired to recognize "gdb" and some other commands). If it complains the mode argument will usually resolve the problem:
libtool --mode=execute my_debugger db_dump
On most systems, using libtool in this way is exactly equivalent to setting the LD_LIBRARY_PATH environment variable and then executing the program. On other systems, using libtool has the virtue of knowing about any other details on systems that don't behave in this typical way.
