MySQL Shell 8.4
In addition to specifying connection parameters using a connection string, it is also possible to define the connection data when starting MySQL Shell using separate command parameters for each value. For a full reference of MySQL Shell command options see Section A.1, “mysqlsh — The MySQL Shell”.
Use the following connection related parameters:
The command options behave similarly to the options used with the mysql client described at Connecting to the MySQL Server Using Command Options.
Use the following command options to control whether and how a password is provided for the connection:
--password=
(password-p)
with a value supplies a password (up to 128 characters) to
be used for the connection. With the long form
password--password=, you must use an equal sign and
not a space between the option and its value. With the short
form -p, there must be no space between the
option and its value. If a space is used in either case, the
value is not interpreted as a password and might be
interpreted as another connection parameter.
Specifying a password on the command line should be considered insecure. See End-User Guidelines for Password Security. You can use an option file to avoid giving the password on the command line.
--password with no value and
no equal sign, or -p without a value,
requests the password prompt.
--no-password, or
--password= with an empty
value, specifies that the user is connecting without a
password. When connecting to the server, if the user has a
passwordless account, which is insecure and not recommended,
or if socket peer-credential authentication is in use (for
Unix socket connections), you must use one of these methods
to explicitly specify that no password is provided and the
password prompt is not required.
--password1,
--password2, and
--password3, are the
passwords for accounts that require multifactor
authentication. You can supply up to three passwords. The
options work in the same way as the --password option, and
--password1 is treated as equivalent to that option.
When parameters are specified in multiple ways, for example
using both the --uri option and
specifying individual parameters such as
--user, the following rules
apply:
If an argument is specified more than once the value of the last appearance is used.
If both individual connection arguments and
--uri are specified, the
value of --uri is taken as
the base and the values of the individual arguments override
the specific component from the base URI-like string.
For example to override user from
the URI-like string:
$> mysqlsh --uri user@localhost:33065 --user otheruser
Connections from MySQL Shell to a server can be encrypted, and can be compressed, if you request these features and the server supports them. For instructions to establish an encrypted connection, see Section 4.3.4, “Using Encrypted Connections”. For instructions to establish a compressed connection, see Section 4.3.7, “Using Compressed Connections”.
The following examples show how to use command parameters to specify connections. Attempt to establish an X Protocol connection with a specified user at port 33065:
$> mysqlsh --mysqlx -u user -h localhost -P 33065
Attempt to establish a classic MySQL protocol connection with a specified user, requesting compression for the connection:
$> mysqlsh --mysql -u user -h localhost -C
