Oracle GlassFish Server 3.1 Section 1: asadmin Utility Subcommands
create-connector-connection-pool(1)
create-connector-security-map(1)
create-connector-work-security-map(1)
create-jdbc-connection-pool(1)
create-message-security-provider(1)
create-resource-adapter-config(1)
delete-connector-connection-pool(1)
delete-connector-security-map(1)
delete-connector-work-security-map(1)
delete-message-security-provider(1)
delete-resource-adapter-config(1)
disable-http-lb-application(1)
disable-secure-admin-internal-user(1)
disable-secure-admin-principal(1)
enable-secure-admin-internal-user(1)
enable-secure-admin-principal(1)
list-connector-connection-pools(1)
list-connector-security-maps(1)
list-connector-work-security-maps(1)
list-message-security-providers(1)
list-resource-adapter-configs(1)
list-secure-admin-internal-users(1)
list-secure-admin-principals(1)
list-supported-cipher-suites(1)
unfreeze-transaction-service(1)
update-admin-server-coordinates(1)
update-admin-server-local-coordinates(1)
update-connector-security-map(1)
update-connector-work-security-map(1)
Oracle GlassFish Server 3.1 Section 1M: Utility Commands
Oracle GlassFish Server 3.1 Section 5ASC: GlassFish Server Concepts
- removes the specified JDBC connection pool
delete-jdbc-connection-pool [--help]
[--cascade={false|true}]
[--target target]
jdbc_connection_pool_idThe delete-jdbc-connection-pool subcommand deletes a JDBC connection pool. Before running this subcommand, all associations to the JDBC connection pool must be removed.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
If the option is set to true, all the JDBC resources associated with the pool, apart from the pool itself, are deleted. When set to false, the deletion of pool fails if any resources are associated with the pool. Resources must be deleted explicitly or the option must be set to true. The default value is false.
Do not specify this option. This option is retained for compatibility with earlier releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and displays a warning message that the option is ignored.
The name of the JDBC resource to be removed.
Example 1 Deleting a JDBC Connection Pool
This example deletes the sample_derby_pool JDBC connection pool.
asadmin> delete-jdbc-connection-pool --cascade=false sample_derby_pool Command delete-jdbc-connection-pool executed correctly.
subcommand executed successfully
error in executing the subcommand
create-jdbc-connection-pool(1),list-jdbc-connection-pools(1)
