| C H A P T E R 5 |
Using the Remote Console Application |
This chapter describes how to use the remote console application. It includes the following sections:
The remote console application, which is started using the web GUI, enables you to control your server’s operating system remotely using the screen, mouse and keyboard, and to redirect local CD and diskette drives as if they were connected directly to the server.
A compatible browser and a minimum of JRE
1.6.0 are required to operate the remote console application. See TABLE 5-1.
| Note - You do not need to install any OS-specific drivers or helper applications on client systems to run the remote console application. |
| Note - You can download the JRE 1.6 at http://java.com. |
When you redirect the local client CD drive or diskette drive to a remote host server, the following rules apply:
The information in TABLE 5-2 describes different case scenarios in which the remote console application and CD drive and diskette drive redirection operate.
Use this procedure to start the remote console application from the web GUI. You may be presented with a series of questions. In each case, select Run.
2. In the address bar, enter the IP address of the SP that you obtained in: To Set Up the Service Processor with the WebGUI.
3. Type user name and password for an account with administrator privileges.
5. Click the Remote Control tab.
The screen displays a Launch Redirection button.
A screen identifies your current host name, IP address, and user name. The Launch button opens the remote console.
| Note - For systems using Firefox and Mozilla browsers, the required version of JRE must be at least version 1.6 or later. |
The browser downloads the embedded remote control application automatically, and the Remote Console screen appears.
| Note - If the remote console does not display, it might be blocked by browser security controls (pop-up blocker). Reduce security configuration to allow the remote console to display. |
The remote console application supports the redirection of the following types of devices:
Use the following procedure to redirect your local workstation or laptop keyboard and mouse to a remote Sun Blade X6250 server module.
1. Start the remote console application as described in Starting the Remote Console Application.
2. From the system management software opening screen select the Remote Control tab.
3. Select the Hotkey Setup tab.
The Control Mode section of the Hotkey Setup screen enables mouse redirection.
4. Select Hardware Cursor to enable a variety of cursor movements.
FIGURE 5-1 Keyboard, Video, and Mouse Selections
You can click Submit to enable your options after each choice to observe the consequences, or continue directly to Step 5.
5. When you have completed your selections, click Submit to enable your options.
Use the following procedure to enable a storage device attached to your local workstation or laptop to serve as a storage device for a server module. You can use this option to install software from a local CD/DVD drive to multiple remote servers.
You can also redirect a CD image file or a diskette image file stored on your hard drive.
The Remote Console screen is displayed.
2. Select Storage from the drop-down list and click Mount Device.
This enables the corresponding local storage device to connect to the remote server as though it were a storage device attached directly to that remote server.
3. Select a source device from the drop-down list.
| Note - You cannot select two CD-ROM devices or two diskette devices. For example, you cannot select CD-ROM and CD-ROM image. Use the browser to navigate to the corresponding file, then click Submit. |
After successfully mounting a storage device a green check mark is displayed in the lower left corner of the Remote Console window.
| Note - Use the web GUI to disable the session time out, or to set the session timeout to a long enough period of time to allow you to work without the system automatically logging you out. |
This method includes using a CD or DVD drive or image of the operating system on a remote networked system to install the operating system, for example, onto the Sun Blade X6250 server module.
Requirements for Remote KMVS Over IP installation include:
| Note - Disable the timeout function when installing remotely from the virtual CD-ROM. |
1. On your laptop or local terminal, open a browser, and enter the IP address of the Sun Blade X6250 server module service processor for the target system.
This is the Sun Blade X6250 server module on which you want to install the operating system.
2. Enter the user name and password in the login screen.
3. In the main ELOM screen, click the Remote Control tab, then click Launch Redirect to open a remote console screen.
4. Insert the operating system CD/DVD to be installed on the Sun Blade X6250 server module into your laptop or local CD/DVD drive.
5. In the remote console screen, choose Storage ->Mount devices.
The Device Configuration screens appears.
6. Under Storage 1, in the drop-down list, select the local CD/DVD that you will be using for the installation.
Command-line options that are available to address many of these tasks include IPMI tools (Chapter 7), CLI (Chapter 6), and SSH (Secure Shell).
Copyright © 2008, Sun Microsystems, Inc. All Rights Reserved.
