Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_image *mlib_ImageCreate(mlib_type type, mlib_s32 channels, mlib_s32 width, mlib_s32 height);
The mlib_ImageCreate() function creates a mediaLib image data structure and allocates memory space for image data. The data type of the image can be MLIB_BIT, MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, MLIB_INT, MLIB_FLOAT, or MLIB_DOUBLE.
To obtain the best performance, it is recommended that you use this function to create a mediaLib image whenever possible, as this guarantees alignment.
The function takes the following arguments:
Image data type.
Number of channels in the image.
Width of image in pixels.
Height of image in pixels.
The function returns a pointer to the mlib_image data structure.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageCreateStruct(3MLIB), mlib_ImageCreateSubimage(3MLIB), mlib_ImageDelete(3MLIB), mlib_ImageSetPaddings(3MLIB), attributes(5)
