Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> void mlib_ImageDelete(mlib_image *img);
The mlib_ImageDelete() function deletes the mediaLib image data structure and frees the memory space of the image data only if it is allocated through mlib_ImageCreate(). The data type of the image can be MLIB_BIT, MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, MLIB_INT, MLIB_FLOAT, or MLIB_DOUBLE.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageCreate(3MLIB), mlib_ImageCreateStruct(3MLIB), mlib_ImageCreateSubimage(3MLIB), attributes(5)
