Name | Description | Files | Attributes | See Also
The fcoe driver is a pseudo nexus driver which supports the transportation of FCoE encapsualted frames. FCoE Ethernet frame will encapsulate the raw Fibre Channel frame.
The fcoe driver interfaces with FCoE target mode device driver, fcoet(7D).
32-bit ELF kernel module (x86)
64-bit ELF kernel module (x86)
64-bit ELF kernel module (SPARC)
See attributes(5) for a description of the following attribute:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SPARC, x86 |
Availability |
SUNWfcoe |
driver.conf(4), attributes(5), fcoet(7D)
ANSI X3.269-1996, Fibre Channel Protocol for SCSI (FCP)
