Name | Description | Files | Attributes | See Also
The fcoet driver is a pseudo device driver which encapsulates the raw Fibre Channel frames into FCoE Ethernet frames, or decapsulates FC frames from FCoE Ethernet frames. The supported FC frames contain extended/basic link services, common transport frames and target mode FCP frames.
The fcoet driver interfaces with COMSTAR FC transport driver,fct, and FCoE transport driver, fcoe(7D).
32-bit ELF kernel module (x86)
64-bit ELF kernel module (x86)
64-bit ELF kernel module (SPARC)
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
SPARC, x86 |
Availability |
SUNWfcoet |
driver.conf(4), attributes(5), fcoe(7D)
ANSI X3.269-1996, Fibre Channel Protocol for SCSI (FCP)
