The following sample scenarios provide summaries of the major steps required to install Sun Management Center 3.5 for the first time, and to upgrade previous versions of Sun Management Center to Sun Management Center 3.5.
To install, upgrade, and set up Sun Management Center, you must log in as root on each machine.
In this example, the Sun Management Center server, agent, console, and the Advanced System Monitoring (ASM) add-on are to be installed on three machines as follows:
The console is to be installed on machine A. The ASM add-on is to be installed machine A.
The server is to be installed on machine B. The ASM add-on is to be installed machine B.
The agent is automatically installed with the server.
The agent is to be installed on machine C. The ASM add-on is to be installed machine C.
Sun Management Center has not been installed on any of the machines.
The following procedure summarizes the major steps required to install Sun Management Center and ASM.
Make sure each machine is a supported platform.
See Supported Platforms.
Make sure each machine has the required resources.
Determine whether you will install from the CDs or from a CD image.
Install the server on machine B as described in Installing Sun Management Center 3.5 on the Solaris Platform.
During installation:
Select the production environment.
Select the server layer only. The agent layer is automatically selected.
Select the Advanced System Monitoring add-on.
Advanced System Monitoring enables advanced monitoring capabilities for the server machine. For further information, see Additional Add-on Products.
When installation is finished, you are informed that the /etc/system file has been updated, and that the system must be rebooted. Exit the installation process, and reboot the system.
Set up the Sun Management Center server on machine B.
When the system has rebooted, type the command /opt/SUNWsymon/sbin/es-guisetup to set up the Sun Management Center server.
When setting up the server:
Provide a password to generate the security key.
The password must be the same for all Sun Management Center machines.
Provide an SNMPv1 security string.
The security string must be the same for all Sun Management Center machines.
When server setup is finished, the Advanced System Monitoring setup is performed.
When Advanced System Monitoring setup is finished, you are given the option to start Sun Management Center components. Start all components.
Install the agent on machine C as described in Installing Sun Management Center 3.5 on the Solaris Platform.
Select the agent layer only.
Advanced System Monitoring enables advanced monitoring capabilities for the agent machine. For further information, see Additional Add-on Products.
If you need to install the agent on several machines, you can create an agent-update image and install the agent using the image as described in Using Agent-Update to Upgrade Agents to Sun Management Center 3.5.
When the agent installation is finished, you are given the option to run setup. Run setup.
Set up Sun Management Center agent on machine C.
When setting up the agent:
Provide the same security key password that you provided in Step 5.
Provide the same SNMPv1 community string that you provided in Step 5.
Provide the name of the Sun Management Center server machine.
When agent setup is finished, you are given the option to start the Sun Management Center agent. Start the agent.
Install the console on machine A as described in Installing Sun Management Center 3.5 on the Solaris Platform.
Select the console layer only.
Advanced System Monitoring includes console components and menus.
When the console installation is finished, you are given the option to run setup. Run setup.
When setup is finished, start the console by typing the command /opt/SUNWsymon/sbin/es-start -c.
In this example, the Sun Management Center 3.0 server, agent, and console are installed on three machines as follows:
The Sun Management Center 3.0 console is installed on machine A.
The Sun Management Center 3.0 server is installed on machine B.
The Sun Management Center 3.0 agent is installed on machine C.
The following procedure summarizes the steps required to upgrade the Sun Management Center 3.0 installation to Sun Management Center 3.5 on all three machines.
If your Sun Management Center 3.0 installation includes the Performance Reporting Manager, the upgrade process enables you to migrate the Sun Management Center data and your Performance Reporting Manager data. Make sure the machine on which the Performance Reporting Manager is installed has sufficient resources for the Sun Management Center 3.5 as described in Table 2–4.
Install the Sun Management Center 3.5 server on machine B as described in Upgrading the Server.
During the installation:
Uninstall the previous Sun Management Center version when prompted.
Choose whether to migrate the Sun Management Center version data.
Select migrate data to save your Sun Management Center 3.0 data and use the data in Sun Management Center 3.5.
Select discard data if you do not want to save your Sun Management Center 3.0 data.
Select the server layer only. The agent is automatically installed.
When server installation is finished, you are given the option to run setup. Run setup.
Set up the server on machine B.
During server setup:
The password must be the same password you provided when you set up Sun Management Center 3.0.
The security string must be the same security string you provided when you set up Sun Management Center 3.0.
If you chose to migrate the Sun Management Center 3.0 data to Sun Management Center 3.5, choose whether to restore the Sun Management Center 3.0 data.
If you provide a different password for security seed generation on the server than you provided forSun Management Center 3.0 , then you must use the new password to generate the same security seed when setting up the agents. If you do not upgrade a Sun Management Center 3.0 agent to Sun Management Center 3.5, you must regenerate the security key for the Sun Management Center 3.0 agent machine as described in Regenerating Security Keys.
When server setup is finished, you are given the option to start Sun Management Center components. Start all components.
Install the Sun Management Center 3.5 agent on machine C as described in Upgrading Agents.
During agent installation:
Choose whether to migrate the Sun Management Center version agent data.
Set up the agent on machine C.
During agent setup:
The password must be the same password you provided when you set up the Sun Management Center 3.5 server.
The security string must be the same security string you provided when you set up the Sun Management Center 3.5 server.
If you chose to migrate the Sun Management Center 3.0 agent data to Sun Management Center 3.5, choose whether to restore the Sun Management Center 3.0 data.
Install the Sun Management Center 3.5 console on machine A.
Type the command /opt/SUNWsymon/sbin/es-uninst to uninstall the Sun Management Center 3.0 console.
Install and set up the Sun Management Center 3.5 console as described in Installing Sun Management Center 3.5 on the Solaris Platform.
When the console setup is finished, start the console by typing the command /opt/SUNWsymon/sbin/es-start -c.
In this example, the Sun Management Center 2.1.1 server, agent, and console are installed on three machines as follows:
The Sun Management Center 2.1.1 console is installed on machine A.
The Sun Management Center 2.1.1 server is installed on machine B.
The Sun Management Center 2.1.1 agent is installed on machine C.
The following procedure summarizes the steps required to upgrade the Sun Management Center 2.1.1 installation to Sun Management Center 3.5 on all three machines.
Determine whether you will install Sun Management Center 3.5 from the CDs or from a CD image.
Upgrade the Sun Management Center 2.1.1 server on Machine B.
Download the migration utility from http://www.sun.com/sunmanagementcenter.
Run the migration utility and upgrade from Sun Management Center 2.1.1 to Sun Management Center 3.5.
During the Sun Management Center 3.5 installation stage of the upgrade process:
Choose whether to migrate the Sun Management Center 2.1.1 data.
Select migrate data to save your Sun Management Center 2.1.1 data and use the data in Sun Management Center 3.5.
Select discard data if you do not want to save your Sun Management Center 2.1.1 data.
During the Sun Management Center 3.5 setup stage of the upgrade process:
If you chose to migrate the Sun Management Center 2.1.1 data to Sun Management Center 3.5, choose whether to restore the Sun Management Center 2.1.1 data.
When server setup is finished, you are given the option to start the Sun Management Center components. Start all components.
Upgrade the Sun Management Center 2.1.1 agent on machine C.
Install the Sun Management Center 3.5 agent on machine C as described in Installing Sun Management Center 3.5 on the Solaris Platform.
Select Migrate Data if you want to save your the Sun Management Center 2.1.1 agent data and use the data in Sun Management Center 3.5.
During agent setup:
Provide the same security key password that you provided in Step 4.
Provide the same SNMPv1 community string that you provided in Step 4.
If you chose to migrate the Sun Management Center 2.1.1 agent data to Sun Management Center 3.5, choose whether to restore the Sun Management Center 2.1.1 data.
Uninstall the Sun Management Center 2.1.1 console as described in the Sun Management Center 2.1.1 Installation Guide.
When console setup is finished, start the console by typing the command /opt/SUNWsymon/sbin/es-start -c.
In this example, the systems in the network have Sun Management Center 3.5 and Sun Management Center 3.0 installed as follows:
The Sun Management Center 3.5 console and agent are installed on machine A.
The Sun Management Center 3.5 server and agent is installed on machine B.
The Sun Management Center 3.0 agent is installed on machines C through Z.
The following procedure summarizes the major steps required to upgrade machines C through Z to the Sun Management Center 3.5 agent.
Make sure the all Sun Management Center components on the Sun Management Center server machine B are running as described in Starting Components on the Solaris Platform.
Create an agent-update image as described in To Create an Agent-Update Image Using es-gui-imagetool.
Apply the agent-update image to machines C through Z as described in To Install or Update Agents From an Agent-Update Image Using agent-update.bin.
While applying the agent-update image on each machine:
The password must be the same password you provided when you set up Sun Management Center 3.5 server.
The security string must be the same security string you provided when you set up Sun Management Center 3.5.
The Performance Reporting Manager has server, agent, and console layer components.
The server layer component should be installed on the same machine as the Sun Management Center server. Performance Reporting Manager version 3.5 provides three configurations:
Small - requires 5 Gbytes of free disk space
Medium - requires 12 Gbytes of free disk space
Large - requires 24 Gbytes of free disk space
Make sure that the Sun Management Center server machine has sufficient resources as described in Table 2–4.
The agent component must be installed on machines for which you want to collect performance, package, patch and hardware configuration data.
Make sure that each Sun Management Center agent machine has sufficient resources as described in Table 2–4.
The console component must be installed on each console machine. The console component updates menus and selections in the Sun Management Center console to support the Performance Reporting Manager.
To collect hardware configuration data, the agent and server machines should have the hardware-specific module installed.
The Performance Reporting Manager can be installed on each machine as follows:
If you are upgrading machines from Sun Management Center 3.0 to Sun Management Center 3.5, follow the instructions in Upgrading the Server. The Sun Management Center 3.5 upgrade process enables you to migrate the Sun Management Center data and your Performance Reporting Manager data.
Make sure you select the Performance Reporting Manager add-on Sun Management Center 3.5 during the installation process.
If you are performing a fresh install of Sun Management Center 3.5, make sure you select the Performance Reporting Manager add-on of Sun Management Center 3.5 during the installation process.
If you have already installed and set up Sun Management Center 3.5 on each of your machines, install and set up the Performance Reporting Manager as directed in Performance Reporting Manager Installation and Setup in the Sun Management Center 3.5 Performance Reporting Manager User's Guide.
During Sun Management Center 3.5 setup on the Sun Management Center server, you are prompted to enter the paths to three different directories for the configuration you have chosen. If possible, specify directories on three different file systems. This separation of directories reduces disk contention and improves performance.
If a previous Sun Management Center console version is installed on the Microsoft Windows machine, uninstall the console as described in Uninstalling Sun Management Center From the Microsoft Windows Platform.
To install the Sun Management Center 3.5 console, install the console as described in Installing Sun Management Center 3.5 on Microsoft Windows.
