Sun Management Center 3.5 Installation and Configuration Guide
Default Ports
The default ports used by Sun Management Center components might be used by other processes already installed on the system. If you install Sun Management Center using the default port assignments, you might encounter port conflicts and be unable to start Sun Management Center. The Sun Management Center setup process checks the ports for each component. The process prompts you to either assign an alternate port or use the default port.
The following table lists the Sun Management Center components and the default port for each component. See To Determine Whether a Port Is Used to find out how to check whether a port is in use.
Table 9–3 Sun Management Center Default Port Addresses
Layer
Component
Default Port Number
Agent
Agent
161
Server
Trap handler
162
Server
Event manager
163
Server
Topology manager
164
Server
Configuration manager
165
Server
Platform
166
Advanced System Monitoring Add-on
System event and configuration tracking component cstservice
167
Server
Agent information caching component Metadata
168
Server
Server RMI
2099
Server
Database
2521
Server
Grouping
5600
Tomcat
Web server
8006
Server
Web server default port
8080
Server
Web server secure port
8443
    In a terminal window, type /bin/netstat -an | grep portnumber where portnumber is the port number that you want to query. For example:
    # /bin/netstat -an | grep 8443
    • If the port is not in use, only the command-line prompt is returned as shown above.
    • If the port is in reserved or in use, the status of the port is returned. For example:
      # /bin/netstat -an | grep 1161
      #       *.1161                                Idle
      # /bin/netstat -an | grep 8080
      # 172.16.0.0.8080         *.*                0      0 24576      0 LISTEN
      where 172.16.0.0 is the IP address of the machine on which you entered the netstat command.
