The following table lists typical hardware configurations and the corresponding number of platform agents that can be deployed on the dedicated host system.
Table C–7 Dedicated Host: Sun Fire Platform Agent Capacity|
Representative Hardware Configurations |
Maximum Number of Platform Agents |
Netra X1, Netra T1 or Sun Blade 100 with a single 500 MHz UltraSPARC IIe CPU, 1 Gbyte of RAM and 1 Gbyte of swap |
5 to 7 |
Sun Enterprise 420R or Ultra 60 with dual 450 MHz UltraSPARC II CPUs, 1 Gbyte of RAM, and 1 Gbyte of swap |
11 to 15 |
Sun Fire 280R, Netra T4, or Sun Blade 1000 with dual 750 MHz UltraSPARC III CPUs, 1 Gbyte of RAM, and 1 Gbyte of swap |
14 to 20 |
Because platform agent resource use can vary, the limits shown in the table represent a range of acceptable values that leave sufficient capacity to ensure that operational peaks do not exhaust system capacity. Larger Sun Fire platforms require greater platform agent resources, with the result that fewer platform agents can be run on a single host. Conversely, smaller Sun Fire platforms require fewer platform agent resources, so more platform agents can be run on a single host.
