The graphical user interface wizard enables you to start specific Sun Management Center components as described by the following procedure.
Log in as root on the machine on which you want to start Sun Management Center components.
Go to the /opt/SUNWsymon/sbin directory.
Run the start wizard by typing:
# ./es-guistart
The Select Components to Start screen appears.
Depending on the components installed on the machine, you might have one or more of the following options to select:
Start Server Components
Start Sun Management Center Agent
Start Default Platform Agent
Start Instance of Platform Agent
Select the components that you want to start and then click Next.
The Starting Components screen appears. The status of each component is listed.
