The es-start command-line script enables you to start specific Sun Management Center components. The syntax of the es-start command is as follows:
es-start -achlAS [-y instance-name] [ -- args... ]The following table describes the es-start command parameters.
Table 8–1 es-start Options
Option |
Modifying Options |
Definition |
-a |
Start the agent |
-c |
Start the console |
-c |
--- -XmxNNm |
Start the console with a heap size of NN Mbytes |
-c |
--- -p port-number |
Start the console and override the default port with port-number |
-h |
List the options for es-start |
-l |
Start the platform agent |
-y |
instance-name |
Start a new instance of the platform agent where instance-name is the name of the platform instance you provide |
-A |
Start all components except the console |
-S |
Start the server and all the server subcomponents |
-S |
--- -XmxNNm |
Start the server and all server subcomponents with a heap size of NN Mbytes
The following examples show how to use es-start and its parameters.
To start all Sun Management Center processes, type:
# /opt/SUNWsymon/sbin/es-start -A |
To start the console, the server, and the agent, type:
# /opt/SUNWsymon/sbin/es-start -Ac |
To specify the maximum console heap size when starting the console, use the es-start -c and -X parameters.
# /opt/SUNWsymon/sbin/es-start -c -- -Xmx100m |
To specify a specific port when starting the console, use the es-start -c and -p parameters.
# /opt/SUNWsymon/sbin/es-start -c -- -p 2090 |
To specify the maximum server heap size when starting the server, use the es-start -s and -X parameters.
# es-start -S -- -Xmx100m |
