The graphical user interface wizard enables you to stop specific Sun Management Center components as described in the following procedure.
Log in as root on the machine on which you want to stop Sun Management Center components.
Go to the /opt/SUNWsymon/sbin directory.
Run the stop wizard by typing:
# ./es-guistop
The Select Components to Stop screen appears.
Depending on the components installed on the machine, you might have one or more of the following options to select:
Stop Server Components
Stop Sun Management Center Agent
Stop Default Platform Agent
Stop Instance of Platform Agent
Select the components that you want to stop and then click Next.
The Stopping Components screen appears. The status of each component is listed.
