The es-stop command-line script enables you to stop specific Sun Management Center components. The syntax of the es-stop command is as follows:
es-stop -ahlAS [-y instance-name]The following table describes the es-stop command parameters.
Table 8–2 es-stop Options|
Option |
Modifying Options |
Definition |
-a |
Stop the Sun Management Center agent |
-h |
List the options for es-stop |
-l |
Stop the platform agent |
-y |
instance-name |
Stop the platform agent instance named instance-name |
-A |
Stop all Sun Management Center components |
-S |
Stop all Sun Management Center components except for the Sun Management Center agent |
The following examples show how to use es-stop and its parameters..
To stop all Sun Management Center processes, type:
# /opt/SUNWsymon/sbin/es-stop -A |
To stop all Sun Management Center processes except the agent, type:
# /opt/SUNWsymon/sbin/es-stop -S |
