Sun Management Center 3.5 Installation and Configuration Guide
Preparing a T3 Storage Device
Before you install and set up the Sun Management Center T3 Add-on, you must modify the /etc/hosts and /etc/ethers files on the system where the Sun Management Center add-on Monitoring and Management of A5x00 and T3 Devices is to be installed.
The following procedure assumes that you have installed and configured the T3 storage device as described by the Sun StorEdge T3 Disk Tray Installation, Operation, and Service Manual.
When the /etc/hosts and /etc/ethers files have been updated on the machine where the Sun Management Center add-on Monitoring and Management of A5X00 and T3 Devices will be installed, you can proceed with installing and setting up the T3 add-on.
To Prepare a T3 Storage Device
  1. Determine the IP address and ethernet address for each T3 storage device.
    Open a terminal window and type the command arp t3-device-name where t3-device-name is the name of the T3 storage device. For example:
    # arp T3-001
    T3-001 (10.100.20.300) at 1:2:30:ab:ba:45 permanent published
    In the above example, 10.100.20.300 is the IP address, and 1:2:30:ab:ba:45 is the Ethernet address of the T3 storage device T3-001.
  2. Repeat Step 1 for each T3 device on your network.
    When you have recorded the IP address, Ethernet address, and name for each T3, go to the next step.
  3. Log in as root on the machine where you will install the Sun Management Center add-on Monitoring and Management of A5X00 and T3 Devices.
    This machine can be either the machine where you install the Sun Management Center server or the machine that you have allocated as dedicated platform agent server.
  4. Record each T3 IP address and name in the /etc/hosts file.
    For example, assume that three T3 devices are attached to your network. Assume that you used the arp command to determine the IP address, and Ethernet address of each T3 device, and recorded the information as follows:
    storage-t3–1
    172.16.100.10
    0:20:f2:0:59:48
    storage-t3–2
    172.16.100.11
    0:20:f2:0:5f:40
    storage-t3–3
    172.16.100.12
    0:20:f2:0:7f:a8
    The entries in the server /etc/hosts file would then be as follows:
    172.16.100.10   storage-t3–1
    172.16.100.11   storage-t3–2
    172.16.100.12  storage-t3–3
  5. Record each T3 storage device Ethernet address and name in the /etc/ethers file.
    Create the /etc/ethers file if the file does not already exist.
    Using the example given in Step 4, the entries in the server /etc/ethers file would then be as follows:
    0:20:f2:0:59:48   storage-t3–1
    0:20:f2:0:5f:40   storage-t3–2
    0:20:f2:0:7f:a8  storage-t3–3
    Caution – Caution –
    If you include the domain name as part of the T3 device name, make sure the domain name is identical in both the /etc/hosts and /etc/ethers files. The entries are case sensitive.
    For example, assume that the /etc/hosts file contains:
    0:20:f2:0:59:48   storage-t3–1.sun.com
    Also assume that the /etc/ethers files contains
    0:20:f2:0:59:48   storage-t3–1.Sun.Com
    In this example, the T3 storage device cannot be set up using the Sun Management Center setup tools because the domain name case is different.
