If you monitor and manage T3 storage devices using the Monitoring and Management of A5x00 and T3 Devices add-on, remove T3 device configuration information before you uninstall Sun Management Center 2.x or Sun Management Center 3.x. The es-uninst command does not remove T3 device configuration information.
Log in as root by typing su - root on the machine where the Sun Management Center 2.x or Sun Management Center 3.x server is installed.
Stop the Sun Management Center agent.
Type the command /opt/SUNWsymon/sbin/es-stop -a.
Run the pre-uninstall script to remove T3 device configuration information.
Type the command /opt/SUNWsymon/addons/storage/sbin/pre-uninst.sh.
You are asked if you want to stop the T3 from sending syslog messages. Type y. You are then prompted for the root password for the T3 device. Type the password.
You are notified that the T3 device has been removed from the T3 module.
If you do not run the pre-uninst.sh script before you install Sun Management Center 3.5, you will have to manually remove T3 configuration information before you can set up the new Sun Management Center 3.5 installation.
If you run the pre-uninst.sh script but then decide to keep your Sun Management Center 2.x or Sun Management Center 3.x installation, type /opt/SUNWsymon/es-setup -F to set up your T3 devices again.
