The graphical es-guiuninst wizard can be used either to uninstall all of a Sun Management Center 3.5 installation, or to uninstall only specific add-on products. es-guiuninst also provides the option to back up the Sun Management Center 3.5 configuration data from the previous 3.5 version. If you chose to back up the configuration data, the Sun Management Center 3.5 installation process detects the backup and asks whether you want to apply the data to the new installation.
You can uninstall specific Sun Management Center 3.5 add-on products by using either the graphical es-guiuninst wizard as described below, or by using the es-uninst command-line script as described in Uninstalling Sun Management Center.
The Sun Management Center 3.5 installation process detects an existing Sun Management Center 3.0 or Sun Management Center 3.5 installation. If Sun Management Center 3.0 or Sun Management Center 3.5 is detected, the Sun Management Center 3.5 installation process runs the uninstall process of the previous version, and optionally migrates the configuration data from the previous version to the new Sun Management Center 3.5 installation.
If you choose this method to update a machine running the Sun Management Center 3.0 server, the machine must be running at least Solaris version 8.
Open a terminal window, then type the command xhost + in the terminal window.
Also, make sure that the DISPLAY environment variable is set to your machine's display.
Log in as root on the machine where the Sun Management Center 3.5 software is installed.
Remove T3 device configuration information if T3 devices are present.
If you have not installed and set up the add-on Monitoring and Management of A5x00 and T3 Devices, skip this step. Go to Step 4.
If you monitor and manage T3 storage devices using the Monitoring and Management of A5x00 and T3 Devices add-on, remove T3 device configuration information before you uninstall Sun Management Center. For instructions, see Removing T3 Device Configuration If Present in Chapter 4, Preparing Systems for Sun Management Center Upgrade and Installation.
Type the following command:
# /opt/SUNWsymon/sbin/es-guiuninst |
The Welcome screen appears.
Click Next.
The Product Selection for Uninstall screen appears.
Select the products to uninstall.
You are given the choice to uninstall the entire Sun Management Center installation, or to uninstall specific add-on products.
To uninstall all of Sun Management Center, select Entire Product Agent, Server, All Add-on Products, and then click Next. The Save Configuration Data screen appears. Go to Step 7.
To uninstall specific add-on products, select Add-on Products Only.
The list of add-on products becomes active. Select the add-on products that you want to uninstall and click Next.
Determine whether to save configuration data.
If you do not save the configuration data, your current Sun Management Center packages are uninstalled and the contents of /var/opt/SUNWsymon are removed. In addition, your security keys are overwritten and you must set up all agents again for the agents to work properly. Select Save Data if you want to retain your administrative domain configuration and custom alarm settings in /var/opt/SUNWsymon for subsequent installations or upgrades.
If you want to save the configuration data for the selected product or products, select Save Data and click Next.
If you do not want to save the configuration data, click Next.
The Product Removal Confirmation screen appears.
Confirm your selections for uninstall.
The selections that you made are listed.
If the selections are incorrect, click Back to return to the Product Selection for Uninstall screen and make different selections. Then confirm the new selections.
Click Next to accept and uninstall the selections.
The Uninstall Progress screen appears.
When the selected products have been uninstalled, the Uninstall Summary screen appears.
Click Close to exit the uninstall wizard.
Ensure that all components have been uninstalled.
Type the following command to list all Sun Management Center packages:
# pkginfo -c symon |
If any packages are listed, uninstall each package using the pkgrm command. For example:
# pkginfo -c symon SUNWesse # pkgrm SUNWesse |
