Both CPU and memory resource utilization reports are available per host, container, resource pool. Before trying to view a report, be sure to set the browser's cache to refresh every time. For a list of the six types of reports available, see About Reports. Reports for CPU and memory resources used are available for the following intervals:
Daily – Shows data for the last 24 hours, one point per hour
Weekly – Shows data for the last 7 days, one point per day
Monthly – Shows data for the last 30 days, one point per day
Real Time - Shows data every 30 seconds per graph point. Available for active projects only.
You must wait two hours after installation of the Performance Reporting Manager software for the daily graph reports to become available. Data first must be collected and stored in the database from which the report can be drawn. You can also view CPU and memory resource utilization reports for inactive containers and containers that are based on historical data.
Real time reports for CPU and memory resources being used are available for active projects only.
Use this procedure if you want to obtain a daily, weekly, or monthly report for a host.
Set the browser's cache to refresh every time.
In the Hosts view, select the host from the navigation window.
Select the Utilization tab.
The CPU usage and memory usage of the host for the last 24 hours are displayed.
(On Solaris 10) The CPU usage, memory usage, and bandwidth usage are displayed.
Click the Graph Properties link.
Choose whether to generate a report for the entire host or only for a resource object in the host.
The resource object for a host might be a resource pool or a project.
(On Solaris 10) The resource object for a host might be a resource pool, zone, or a project.
To generate a report for the entire host, select the Total Utilization option.
Select the appropriate time interval from the Time Interval list.
Click the Update Graph button.
The CPU and memory resource utilization graphs appear.
To generate a report for a resource object in the host, select the Cumulative Utilization by Object option.
Select the appropriate resource object.
The CPU and memory resource utilization graphs appear for a maximum of 5 resource objects that have high utilization.
(Optional) To export the last 24 hours of data to a CSV file, click the Export Data button.
You must wait at least 2 hours after installation of the Performance Reporting Manager software for a CSV report to be available. Data must first be collected and stored in the database from which the report can be drawn. You cannot preview this data in a graph.
Data exported contains the hourly data for the container for the last 24 hours. Therefore, it is not identical to the data obtained from a daily graph.
Use this procedure if you want to obtain a daily, weekly, monthly, or real time report for an active project.
Select the Projects tab in the right pane.
A list of projects on this host appears.
Select the active project for which you need a report.
The CPU usage and memory usage of the active project for the last 24 hours are displayed.
Select the Total Utilization option.
You can also obtain a real time report for an active project.
Use this procedure to request CPU and memory utilization reports for a container. The data is based on historical data and is an average of the resources used by active containers that are based on the container.
In the Containers view, select the container.
The CPU usage and memory usage of the container for the last 24 hours are displayed.
Choose whether to generate a report for the entire container or for a resource object in the container.
The resource object for a container is a host.
To generate a report for the entire container, select the Total Utilization option.
To generate a report for a resource object in the container, select the Cumulative Utilization by Object option.
Use this procedure if you want to obtain a daily, weekly, or monthly report for a resource pool.
In the Hosts view, select the host to which the resource pool is bound.
A list of all resource pools bound to this host appears in the Resource Pools table in the right pane.
Select the name of the resource pool in the table.
A table listing all containers that are bound to this resource pool appears.
The CPU usage and memory usage of the resource pool for the last 24 hours are displayed.
Choose whether to generate a report for the entire resource pool or for a resource object in the resource pool.
The resource object for a resource pool is a project.
(On Solaris 10) The resource object for a resource pool might be a zone or a project.
To generate a report for the entire resource pool, select the Total Utilization option.
To generate a report for a resource object in the resource pool, select the Cumulative Utilization by Object option.
You must wait at least 2 hours after installation of the Performance Reporting Manager software for a CSV report to be available. Data must first be collected and stored in the database from which the report can draw from. You cannot preview this data in a graph.
Use this procedure if you want to obtain a daily, weekly, or monthly report for a zone.
In the Hosts view, select the Solaris 10 host from the navigation window.
Select the Zones tab.
A list of zones on this host appears.
Select a zone for which you need a report.
The CPU usage, memory usage, and bandwidth usage of the zone for the last 24 hours are displayed.
Choose whether to generate a report for the entire zone or only for a resource object in the zone.
The resource object for a zone is a project.
To generate a report for the entire zone, select the Total Utilization option.
To generate a report for a resource object in the zone, select the Cumulative Utilization by Object option.
Select Projects in the list.
