If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
In the Containers view, select the name of the container.
If the container is part of a group, select the group from the navigation window to display the containers in the right pane.
Select the Hosts tab in the right pane.
The Hosts Associated with this Container Definition table appears. All hosts that the selected container is currently associated with are listed in the table.
Click the Associate Host to Container button.
The Associate Host to Container wizard appears.
Follow the wizard instructions for typing a host name or finding an appropriate host.
