The Installing and Administering Solaris Container Manager 1.1 guide describes how to use Container Manager to create, use, and manage containers.
The 1.0 version of this product was called N1TM Grid Console - Container Manager.
The SolarisTM 10 release supports systems that use the SPARC® and x86 families of processor architectures: UltraSPARC®, SPARC64, AMD64, Pentium, and Xeon EM64T. The supported systems appear in the Solaris 10 Hardware Compatibility List at http://www.sun.com/bigadmin/hcl. This document cites any implementation differences between the platform types.
In this document the term “x86” refers to 64-bit and 32-bit systems manufactured using processors compatible with the AMD64 or Intel Xeon/Pentium product families. For supported systems, see the Solaris 10 Hardware Compatibility List.
The document is intended for users familiar with the SunTM Management Center product. Therefore, many terms and concepts related to the Sun Management Center are not explained here. For more information about Sun Management Center, refer to Sun Management Center 3.5 Installation and Configuration Guide and Sun Management Center 3.5 User’s Guide.
This document describes how to install and use the Container Manager software.
Chapter 1, Introduction to Solaris Container Manager 1.1 introduces Container Manager.
Chapter 2, Container Manager Installation and Setup provides instructions for installation and setup.
Chapter 3, About Containers and Starting the Product describes the container model and explains how to start the product.
Chapter 4, Managing Projects provides instructions for creating, using, and managing projects.
Chapter 5, Managing Resource Pools describes how to create, use, and manage resource pools.
Chapter 6, Managing Zones describes how to create, use, and manage zones.
Chapter 7, Managing Alarms describes how to use alarms.
Chapter 8, Creating Reports and Using Extended Accounting Data describes how to create reports.
Appendix A, Installing At the Command Line provides instructions for installation and setup by using the command line.
Glossary is a list of words and phrases found in this book and their definitions.
The following documents provide information about concepts that are useful when using the Container Manager software.
System Administration Guide: Solaris Containers-Resource Management and Solaris Zones.
Sun Blueprints book, Consolidation in the Data Center, by David Hornby and Ken Pepple.
Sun white paper Consolidating Oracle RDBMS Instances Using Solaris Resource Manager Software.
The latest information about Sun Management Center software and add-on products is available at http://www.sun.com/solaris/sunmanagementcenter.
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
Sun Microsystems offers select product documentation in print. For a list of documents and how to order them, see “Buy printed documentation” at http://docs.sun.com.
The following table describes the typographic changes that are used in this book.
Table P–1 Typographic Conventions| Typeface or Symbol | Meaning | Example |
| AaBbCc123 | The names of commands, files, and directories, and onscreen computer output | Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
| AaBbCc123 | What you type, contrasted with onscreen computer output | machine_name% su Password: |
| AaBbCc123 | Command-line placeholder: replace with a real name or value | The command to remove a file is rm filename. |
| AaBbCc123 | Book titles, new terms, and terms to be emphasized | Read Chapter 6 in the User's Guide. Perform a patch analysis. Do not save the file. [Note that some emphasized items appear bold online.] |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts| Shell | Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
