NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-lifecycle-module <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--no-enabled|-n] [--load-order|-d order] [--no-failure-fatal|-f] [--class-path|-l path] [--description|-D text] --config|-c name --class|-C class name
Use this command to create a lifecycle module. Java Server Lifecycle Modules are Java classes that listen for server lifecycle events to perform certain tasks whenever the server reaches its various life cycle stages.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify this option to disable the lifecycle module at runtime.
If you specify this option, the server will not treat exceptions thrown during lifecycle module initialization as fatal.
Specify the class path for the lifecycle module.
Specify the order in which the lifecycle module is loaded. You can choose a load-order value that is greater than or equal to 100 to avoid conflicts with internal lifecycle modules.
Enter a description of the lifecycle module.
Specify the name of the configuration for which you want to create the lifecycle module.
Specify the name of the class that implements the lifecycle module.
wadm create-lifecycle-module --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --class=LifeCycleModuleImpl lifecycle_module1 |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), set-lifecycle-module-prop(1), delete-lifecycle-module(1), get-lifecycle-module-prop(1), list-lifecycle-modules(1), create-lifecycle-module-userprop(1), delete-lifecycle-module-userprop(1), list-lifecycle-module-userprops(1)
