NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
delete-lifecycle-module-userprop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c name --module|-m name (propertyname)+
Use this command to delete a lifecycle module property.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the name of the life cycle module.
wadm delete-lifecycle-module-userprop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --module=LifecycleMod info |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), create-lifecycle-module-userprop(1), list-lifecycle-module-userprops(1), create-lifecycle-module(1), set-lifecycle-module-prop(1), delete-lifecycle-module(1), get-lifecycle-module-prop(1), list-lifecycle-modules(1)
