NAME | Synopsis | Description | Options | Examples | Exit Status | See Also
set-token-pin <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--token-pin|-P name] [--new-token-pin|-o name] [--save-pin|-a (true|false)] --token|-t name --config|-c name
Use this command to set or reset the SSL token pin for the server.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the Personal Identification Number (PIN) required to initialize the token. You can also define the token-pin in the password file.
Specify a new token pin when changing the token password. You can also define the new-token-pin in the password file.
If you specify this option, token element is added in configuration's server.xml file with the given pin (password).
Specify the name of the PKCS #11 token.
Specify the name of the configuration.
wadm set-token-pin --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --token=internal |
The following exit values are returned:
command executed successfully
error in executing the command
