NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-token-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--set-password|-r] [--token-pin|-P name] --config|-c name --token|-t name (propertyname=value)*
Use this command to enable or disable the SSL tokens for the server. You can also use this command to save the token-pin in the server.xml file, which will facilitate unsupervised server startup. The property that you can edit is as follows:
enabled - Indicates whether the SSL token is enabled at runtime.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
If you specify this option, you are prompted for the SSL token pin that can be set or reset and saved in the server.xml file.
Specify the Personal Identification Number (PIN) required to initialize the token. You can also define the token-pin in the password file.
Specify the name of the configuration.
Specify the name of the PKCS #11 token that contains the certificates.
wadm set-token-prop --user=admin --password-file=../admin.pwd --host=serverhost --port=8989 --config=config1 --token=internal |
The following exit values are returned:
command executed successfully
error in executing the command
