NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-ha-store
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host  host]
[--port port] [--secure| -s ] [ --user  admin_user]
[--passwordfile filename] [--help]
 [ --haagentport  port_number]
 [--haadminpassword password] [--haadminpasswordfilefilename]
 [--hostshadb_host_list] [--storeuser username]
 [--storepassword password] [--dbsystempassword dbpassword]
 database_name
This command requires the HADB software. This command is available only in domains that are configured to support clusters, such as domains that are created with the cluster profile or the enterprise profile. For information about profiles, see Usage Profiles in Sun Java System Application Server 9.1 Administration Guide.
This command creates tables in the HADB used by the HA cluster. You only need to use this command if you have previously used clear-ha-store. The configure-ha-storecommand also creates tables in the HADB. Use fully qualified hostnames when specifying the hostlist interfaces explicitly for hosts with multiple network interfaces. create-ha-store was named create-session-store in the Sun Java System Application Server 7.1. Create-session-store has been deprecated.
This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
The name of the HA agent port. If not specified, the default port number is 1862.
The actual HADBM administation password. Using this option with the hadbm createdomain or hadbm create command requires that the password is entered each time any hadbm command is used.
The haadminpassword is different from the hadbm dbpassword command. You must use both passwords when using the following commands: hadbm create, hadbm addnodes, hadbm refragment.
The file containing the HADBM administration password, storepassword, and dbsystempassword. These passwords must be defined in the following form: HADBM_ADMINPASSWORD=password, HADBM_DBPASSWORD=storepassword, HADBM_SYSTEMPASSWORD=dbsystempassword. Where password is the actual administrator password.
A comma-separated list of all the hosts that are part of the Management Agent.
This option specifies the username associated with the administrative instance.
The domain application server password associated with the administrative instance.
The database password associated with the administrative instance.
asadmin> create-ha-store --user admin --passwordfile passwords.txt --haagentport 1860 hadatabase1 The create-ha-store command executed successfully  |
