Sun Master Index Configuration Reference
Basic Query Range Searching
Range searching for basic queries is configured in the search page section of midm.xml by tagging the field with a “choice” attribute. When you specify a field for range searching, two corresponding fields appear on the MIDM with “From” and “To” appended to the name (for example, a field named “Date of Birth” would display two fields: “Date of Birth From” and Date of Birth To”). You can also define a field for both exact and range searching by defining the field twice for the search page, once with the choice attribute set to “exact” and once with it set to “range”. In this case, three fields appear on the MIDM: one with the given field name, one with “From” appended to the name, and one with “To” appended to the name.
Table 3 describes the queries formed for different exact or range search scenarios. Table 4 describes the queries formed for combination exact and range search scenarios.
The following variables are used in these tables:
Table 3 Standard Range Queries
Field Configuration in midm.xml
Resulting Fields on MIDM
Fields Populated for Search
Where Clause
field_name
field_name
where field_name = value
choice attribute set to “range”
field_name From
field_name To
field_name From
field_name To
where field_name >= value_from and field_name <= value_to
field_name From
field_name To
field_name From
field_name From
field_name To
field_name To
where field_name <= value_to
In the following table, when field_name is populated but not used in the WHERE clause, its value is used for weighting purposes. These cases are marked with an asterisk (*).
Table 4 Combination Exact and Range Queries
Where Clause
field defined once with choice attribute set to “exact” and once with it set to “range”
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
field defined once with choice attribute set to “exact” and once with it set to “range” *
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name To
field_name
field_name From
field_name To
field_name
field_name From
field_name To
