Sun Master Index Configuration Reference
Blocking Query Range Searching
Blocking queries are configured in query.xml, and, if the blocking query is used on the MIDM, in midm.xml. In order for the fields defined for range searching in the blocking query to appear on the MIDM, the fields must be configured correctly in midm.xml.
In addition to the standard range searching (described under Basic Query Range Searching), blocking queries support constant and offset range searches, allowing you to specify default upper and lower offset values or to specify upper and lower constant limits. Using offsets adds the specified values to the actual field value to determine the range on which to search. Note that this means the lower offset value should be a negative number and the upper offset value should be a positive number in order to create a valid range. You can also define a combination of a constant upper limit with lower offset value or a constant lower limit with an upper offset value.
Blocking Query Offset Values
When upper and lower offset values are defined, the application searches for values that are greater than or equal to the field value plus the lower offset value (which is typically a negative number) and less than or equal to the field value plus the upper offset value. You do not need to define both an upper and a lower offset value.
Note –
For date fields, the method for adding the offsets is different for numeric than for date type fields. For numeric data types, the offset value is added to the actual number. For date data types, the offset value is added to the day portion of the date (for example, if the offsets were -5 and +5 and the date entered is 01/10/2005, then the upper and lower bounds would be 01/05/2005 and 01/15/2005).
Table 5 describes the queries formed for different exact or range offset search scenarios. Table 6 describes the query formed for combination exact and offset range search scenarios.
The following variables are used in these tables:
Table 5 Standard Offset Range Queries
Field Configuration in midm.xml
Resulting Fields on MIDM
Offset Configuration in query.xml
Fields Populated for Search
Where Clause
choice attribute set to “exact”
field_name
both upper and lower offsets defined
field_name
where field_name >= (value + lower) and field_name <= (value + upper)
field_name
only lower offset defined
field_name
field_name
only upper offset defined
field_name
where field_name <= (value + upper)
choice attribute set to “range”
field_name From
field_name To
upper, lower, or both offsets are defined
field_name From
field_name To
where field_name >= value_from and field_name <= value_to
field_name From
field_name To
field_name From
field_name From
field_name To
field_name To
where field_name <= value_to
In Table 6, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
In the following cases, when field_name is populated but not used in the WHERE clause, its value is used for weighting purposes. These cases are marked with an asterisk (*).
Table 6 Combination Offset Range Queries
Fields on MIDM
Query Result
both upper and lower bound offsets are defined
field_name
field_name From
field_name To
field_name
only a lower offset is defined
field_name
field_name From
field_name To
field_name
only an upper offset is defined
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
both upper and lower offsets are defined
field_name
field_name From
field_name To
field_name
field_name From
where field_name >= value_from and field_name <= (value + upper)
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name To
where field_name <= value_to and field_name >= (value + lower)
field_name
field_name From
field_name To
field_name
field_name To
field_name
field_name From
field_name To
field_name
field_name To
both upper and lower offsets are defined*
field_name
field_name From
field_name To
field_name
field_name From
field_name To
Blocking Query Constants
When you define upper and lower constants for a field, these values are used for the WHERE clause of the query if no data is passed in as search criteria for that field. They are also used when only one of the “from” or “to” fields is populated. You do not need to define both an upper and a lower constant value. If you define only an upper constant value, only a “less than or equals” clause is used in the query; if you define only a lower constant value, only a “greater than or equals” clause is used in the query.
Note –
For numeric type fields, the constant must be defined as all digits, with one decimal point allowed. For date type fields, the constant must be in the standard SQL format of yyyy-mm-dd.
Table 7 describes the queries formed for different exact or range constant search scenarios. Table 8 describes the query formed for combination exact and range search scenarios.
Table 7 Standard Constant Range Queries
Where Clause
field_name
field_name
where field_name = value
field_name From
field_name To
field_name From
field_name To
field_name From
field_name To
field_name From
where field_name >= value_from and field_name <= upper
field_name From
field_name To
field_name To
where field_name <= value_to and field_name >= lower
In Table 8, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
Table 8 Combination Constant Range Queries
Fields on MIDM
Query Result
upper, lower, or both constants are defined
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
either upper or both constants are defined
field_name
field_name From
field_name To
field_name From
lower constant is defined
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name
field_name From
lower constant is defined *
field_name
field_name From
field_name To
field_name
field_name From
either lower or both constants are defined
field_name
field_name From
field_name To
field_name To
upper constant is defined
field_name
field_name From
field_name To
field_name To
field_name
field_name From
field_name To
field_name
field_name To
upper constant is defined *
field_name
field_name From
field_name To
field_name
field_name To
upper, lower, or both constants are defined *
field_name
field_name From
field_name To
field_name
field_name From
field_name To
Blocking Query Offset and Constant Combinations
You can use a combination of offset and constant values to define range searching for a field. Table 9 describes the query formed for combination offset and constant search scenarios.
In Table 9, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
Table 9 Combination Constant and Offset Range Queries
Fields on MIDM
Query Result
upper offset and lower constant are defined
field_name
field_name From
field_name To
field_name
where field_name >= lower and field_name <= (value + upper)
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
field_name
field_name From
field_name To
field_name
field_name From
where field_name <= (value + upper) and field_name >= value_from
field_name
field_name From
field_name To
field_name
field_name To
upper offset and lower constant are defined *
field_name
field_name From
field_name To
field_name
field_name From
field_name To
upper constant and lower offset are defined
field_name
field_name From
field_name To
field_name
where field_name <= upper and field_name >= (value + lower)
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
upper constant and lower offset are defined *
field_name
field_name From
field_name To
field_name
field_name From
where field_name <= upper and field_name >= value_from
field_name
field_name From
field_name To
field_name
field_name To
upper constant and lower offset are defined +
field_name
field_name From
field_name To
field_name
field_name From
field_name To
