Sun Master Index Configuration Reference
Blocking Query Offset Values
When upper and lower offset values are defined, the application searches for values that are greater than or equal to the field value plus the lower offset value (which is typically a negative number) and less than or equal to the field value plus the upper offset value. You do not need to define both an upper and a lower offset value.
Note –
For date fields, the method for adding the offsets is different for numeric than for date type fields. For numeric data types, the offset value is added to the actual number. For date data types, the offset value is added to the day portion of the date (for example, if the offsets were -5 and +5 and the date entered is 01/10/2005, then the upper and lower bounds would be 01/05/2005 and 01/15/2005).
Table 5 describes the queries formed for different exact or range offset search scenarios. Table 6 describes the query formed for combination exact and offset range search scenarios.
The following variables are used in these tables:
Table 5 Standard Offset Range Queries
Field Configuration in midm.xml
Resulting Fields on MIDM
Offset Configuration in query.xml
Fields Populated for Search
Where Clause
choice attribute set to “exact”
field_name
both upper and lower offsets defined
field_name
where field_name >= (value + lower) and field_name <= (value + upper)
field_name
only lower offset defined
field_name
field_name
only upper offset defined
field_name
where field_name <= (value + upper)
choice attribute set to “range”
field_name From
field_name To
upper, lower, or both offsets are defined
field_name From
field_name To
where field_name >= value_from and field_name <= value_to
field_name From
field_name To
field_name From
field_name From
field_name To
field_name To
where field_name <= value_to
In Table 6, the field configuration in midm.xml defines the field twice for searching, once with the choice attribute set to “exact” and once with it set to “range”.
In the following cases, when field_name is populated but not used in the WHERE clause, its value is used for weighting purposes. These cases are marked with an asterisk (*).
Table 6 Combination Offset Range Queries
Fields on MIDM
Query Result
both upper and lower bound offsets are defined
field_name
field_name From
field_name To
field_name
only a lower offset is defined
field_name
field_name From
field_name To
field_name
only an upper offset is defined
field_name
field_name From
field_name To
field_name
field_name
field_name From
field_name To
field_name From
field_name To
field_name
field_name From
field_name To
field_name From
field_name
field_name From
field_name To
field_name To
both upper and lower offsets are defined
field_name
field_name From
field_name To
field_name
field_name From
where field_name >= value_from and field_name <= (value + upper)
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name From
field_name
field_name From
field_name To
field_name
field_name To
where field_name <= value_to and field_name >= (value + lower)
field_name
field_name From
field_name To
field_name
field_name To
field_name
field_name From
field_name To
field_name
field_name To
both upper and lower offsets are defined*
field_name
field_name From
field_name To
field_name
field_name From
field_name To
