Sun Master Index Configuration Reference
Qualified Field Name Syntax
The syntax of a fully qualified field name is:
Enterprise.SystemSBR.parent_object.child_object.field_name
where parent_object refers to the name of the parent object in the index, child_object refers to the name of the child object that contains the field, and field_name is the full name of the field. If the parent object contains the field being defined, the child object is not required in the path.
The syntax of a qualified field name is:
