Getting Started with the Java Dynamic Management Kit 5.0
Error Messages
If any of the preceding checks fail, one of the following errors will be generated:
unknownUser
Unregistered user
unknownEngineID
Unregistered SNMP entity
encryptionFailed
Encryption error
unsupportedSecurityLevel
Unsupported security level
authentificationFailed
Password error
notInTimeWindow
Timeliness error
Note –
You can optionally implement alternative authentication and encryption algorithms. You cannot, however, plug in customized security or access control models in Java Dynamic Management Kit 5.0, although this will be possible in future versions.
