Getting Started with the Java Dynamic Management Kit 5.0
SNMPv3 Security
The main addition to Java DMK 5.0 provided by SNMPv3 is the possibility of secure SNMP operation. The SNMPv3 security in Java Dynamic Management Kit 5.0 implements the following SNMP RFCs:
RFC 2571
Architecture
RFC 2572
Message Processing and Dispatching
RFC 2574
USM
The SNMPv3 protocol implementation provides:
Despite the differences between the previous versions of SNMP and SNMPv3, agents in Java DMK 5.0 can respond to requests from any version if the SNMPv3 protocol adaptor is used. SNMP v1 and v2 requests have greater security constraints than v3 requests in an agent compatible with SNMPv3.
The USM MIB is accessible remotely and is not registered to the SNMPv3 adaptor by default.
The USM MIB can be registered in an MBean server, thus making it accessible through the HTML adaptor. This is particularly useful when debugging, although it does create a security risk. Exposing the USM MIB through SNMP without the MBean server, however, is not insecure.
Users can also be configured into an agent by means of an ASCII text file that acts as an initial configuration template for all agents created.
SNMPv3 Authentication and Privacy
Inside SNMP domains, every SNMP entity is issued a unique identifier, the engine ID. Java DMK 5.0 provide a set of classes to allow you to generate engine IDs based on, amongst other identifiers, host names, internet protocol (IP) addresses, port numbers and Internet assigned numbers authority (IANA) numbers.
There are two types of SNMP entity:
Authoritative agent entities receive get, set, getnext, and getbulk requests and send traps. Nonauthoritative agents send informs.
Authoritative manager entities receive informs. Nonauthoritative managers send get, set, getnext and getbulk requests and informs, and receive traps. The engine ID and the number of times the engine has booted can be stored and persisted in the SNMPv3 security file, so that the timeliness of the incoming requests can be verified.
Under SNMPv3 there are three levels of security:
Managers and agents are both configured with a username, allowing the manager specific access to that agent. The username has an associated password. Both the agent and the manager sides must be configured according to the desired security policy. For requests to be authenticated, the manager and the agent must share knowledge of the authentication password associated with the username. For requests to be encrypted, the manager and the agent must additionally share knowledge of the privacy password associated with the username.
Unsecured SNMP Requests
When an agent receives a request from a manager, it checks its LCD. If the user is found in the LCD, the request is granted. No timeliness checking is performed, and the content of the request is not encrypted.
Authenticated Requests
The agent checks the identity of the originator of the request as previously described and then checks the timeliness of the request to ensure that it has not been delayed or intercepted for improper purposes. To monitor the timeliness of the arrival of requests, both manager and agent maintain synchronized clocks, and the manager's local notion of the authoritative engine's time of sending is included in the request. If the difference between the time of sending included in the request and the time of receipt recorded by the agent exceeds 150 seconds, then the request is not considered timely and is rejected.
Once the timeliness of the request has been confirmed, the request is authenticated using either of the HMAC-MD5 or HMAC-SHA protocols. These protocols check that the message digest included in the message matches the one computed locally in the receiving agent.
Authenticated and Encrypted Requests
If privacy has been activated, the content of the request is encrypted, using the DES encryption protocol provided by the Java cryptography extension (JCE) from JDK 1.4. The secure hash algorithm (SHA) and MD5 encryption protocols provided in JDK 1.2 are also used. The requests are decrypted and forwarded once the identity of the sender and the timeliness of the request have been established.
Error Messages
If any of the preceding checks fail, one of the following errors will be generated:
unknownUser
Unregistered user
unknownEngineID
Unregistered SNMP entity
encryptionFailed
Encryption error
unsupportedSecurityLevel
Unsupported security level
authentificationFailed
Password error
notInTimeWindow
Timeliness error
Note –
You can optionally implement alternative authentication and encryption algorithms. You cannot, however, plug in customized security or access control models in Java Dynamic Management Kit 5.0, although this will be possible in future versions.
SNMPv3 Access Control
SNMPv3 access control differs from the access control defined by versions 1 and 2, in that it is based on contexts and user names, rather than on IP addresses and community strings. The configuration for SNMPv3 access control is located in a text file, called the user ACL file. See the Java Dynamic Management Kit 5.0 Tutorial for information about the user ACL file and how to configure it.
When managers send a requests to an agent, the agent authenticates and, if necessary, decrypts the request, as explained earlier. It then passes the request through SNMP context-checking filters to determine whether it is authorized.
SNMPv3 Security Configuration
The configuration for SNMPv3 user-based security is located in a text file, called the security file. Each SNMP engine has its own security file. See the Java Dynamic Management Kit 5.0 Tutorial for information about the user security file and how to configure it.
You can view examples of security files at:
installDir/SUNWjdmk/jdmk5.0/examples/Snmp
