Getting Started with the Java Dynamic Management Kit 5.0
Password Protection
Password-based protection restricts client access to agent applications. All HTTP-based communication provides login- and password- based authentication, as does the SNMP protocol adaptor.
Password protection can be used to associate managers with a set of privileges that determine access right to agents. The user is free to implement whatever access policy is needed on top of the password authentication mechanism. The SNMP protocols also provide password protection to agent applications. See SNMPv1 and SNMPv2 Security and SNMPv3 Security.
HTTP Connectors
Both HTTP and HTTPS connectors provide login and password-based authentication. The server component contains the list of allowed login identifiers and their passwords. Management applications must specify the login and password information in the address object when establishing a connection.
If the list of recognized clients is empty, the default behavior is to perform no authentication and grant access to all clients.
HTML Protocol Adaptor
Because the HTML protocol adaptor relies on HTTP messaging, it also implements password protection. The agent application specifies the list of allowed login identifiers and their passwords when creating the HTML adaptor. When password protection is enabled in HTML, the web browser usually displays a dialog box for users to enter their login and passwords.
In general, the security mechanisms of a protocol adaptor depend on the security features of the underlying protocol. The ability to use security mechanisms also depends on the functionality of the management console. If your web browser does not support the password dialog, you cannot access a password-protected HTML adaptor.
