Whereas password protection grants all-or-nothing access, context checking enables the agent application to filter each management request individually. Context checking can be associated with password protection to provide multiple levels of security.
All management requests that arrive through a connector or HTML protocol adaptor are inspected by the agent application to determine if they are authorized. The management application filters requests based on the type of request, the MBean for which they are intended, or the values that are provided in the operation.
For example, context checking could allow an agent to implement a read-only policy that refuses attribute set operations, all operation invocation, and does not allow MBean registration or unregistration. A more selective filter could just ensure that the agent cannot be disconnected: it would disallow MBean unregistrations, stop operations, and invocations that contain null parameters, but only when applied to connector servers or protocol adaptor MBeans.
In addition, requests through connector clients can be filtered by an operation context field, which could be a password or any other identifying data. The context object is provided by the management application, and it will be sent to the connector server along with each request. The agent can verify this context and potentially reject the request if the context is considered invalid or inappropriate for the operation.
To make this context checking possible, the agent provides:
Stackable MBean server objects – You can insert your own code to perform context checking and filtering between the communication component and the MBean server.
Thread contexts – Your code can retrieve the remote application's context object that is stored in the thread object that handles the request. The context is an arbitrary object that your code can use to determine whether or not to allow the request.
In Figure 2–6, a context checker object has been inserted between the connector and the MBean server. Because a context checker object implements the MBeanServer interface, the connector interacts with it in exactly the same way as it did with the MBean server. This stacked object retains a reference to the real MBean server, to which it forwards all requests that are allowed. The context checker can also perform any other action, such as log all filtered requests and trigger a notification when an invalid request is received.
For security reasons, only the agent application can insert or remove stackable MBean server objects. This operation is not exposed to management applications, which cannot even detect whether requests are being filtered. However, the context checker might respond with an exception message that explains why a request was denied.
