HBA Specifications
This appendix contains the specifications for
the HBA.
This appendix contains the following topics:
Physical Dimensions
The HBA card size is as follows:
Height: 94.31mm (2.731 inches)
Length: 167.64mm (6.6 inches)
HBA Card Layout
The HBA controls eight internal SAS/SATA ports through two
SFF-8087 x4 internal mini SAS connectors. HBA Card Layout shows the jumpers and
connectors on the HBA.
Figure A-1 HBA Card Layout
HBA Jumpers and Connectors
HBA Jumpers and Connectors describes the jumpers
and the connectors on the HBA.
Table A-1 HBA Jumpers and Connectors
JT3B1 |
Battery Backup connector |
20-pin connector
Connects the LSIiBBU08 intelligent Battery Backup Unit directly
to the RAID controller. |
JT5A1 |
x4 SAS Ports 0–3 Mini SAS 4i connector |
Mini SAS 4x connector
Connects the cables from the controller to SAS drives or SATA II drives, or to a SAS
expander. |
JT5B1 |
x4 SAS Ports 4–7 Mini SAS 4i connector |
II drives, or to a SAS expander. |
JT5B2 |
Universal Asynchronous Receiver/Transmitter (UART) debugging |
4-pin connector
Reserved for Oracle use. |
JT5B3 |
Set Factory Defaults connector |
2-pin connector
Returns the board settings to the defaults set in the factory. |
JT6B1 |
LSI Test header |
2-pin connector
JT6B2 |
Global Drive Fault LED header |
2-pin connector
Connects to an LED that indicates whether a drive is in a fault condition. |
JT6B3 |
SAS Activity LED
header |
2-pin connector
Connects to an LED that indicates drive activity. |
Environmental Specifications
The HBA environmental requirements are listed in HBA Environmental Specifications.
Table A-2 HBA Environmental Specifications
Temperature |
Humidity |
5% to 90% RH, noncondensing, 40˚C
max, 27˚C max wet bulb, 16 hour dwells at extreme |
93% RH, noncondensing, 40˚C
max, 120 hours |
Altitude |
3200m at 40˚C, 4 hour dwell |
12,200m at 0˚C, 4 hour dwell |
Vibration |
0.25G in all axes swept for 5-500-5 Hz,
5 sweeps in all at 1 octave/min |
1.2G in all axes swept for 5-500-5 Hz,
Shock |
5.5G, 11 ms half-sine, 10 shocks in x-, y-, and z-axes |
33G, 11 ms half-sine, 3 shocks in x-, y-, and z-axes |
Airflow |
At least 200 linear feet per minute (LFPM) |
Fault Tolerance
Fault Tolerance Features lists the fault tolerance
features for the HBA.
Table A-3 Fault Tolerance Features
Support for SMART The Self Monitoring Analysis and
Reporting Technology (SMART) detects up to 70 percent of all predictable drive
failures. In a-ddition, SMART m-onitors the internal p-erformance
of all motors, heads, and drive el-ectronics. |
Yes |
Optional battery backup for cache memory |
LSIiBBU08 battery backup. <3.7V/1350mAH
battery pack; up to 48 hours of data retention for 512 Mbytes |
Drive failure detection |
Automatic |
Drive rebuild using hot spares |
Automatic |
Parity generation and checking |
Yes |
Electrical Characteristics
All power is supplied to the HBA through the PCI Express 3.3V
rails and the 12V rail. Onboard switching regulator circuitry operating
from the 3.3V rails and the 12V rail provide the necessary voltages.
The following states determine the typical current consumption of
the controller:
State 1: During a hard reset
State 2: During a disk stress test
State 3: While sitting idle at the DOS prompt
The supply voltages are 12V 8 percent (from PCI edge connector only) and 3.3V 9 percent
(from PCI edge connector only). Power Supply for the HBA lists the power supply
information for the controller for each of the three states at the different
voltages.
Table A-4 Power Supply for the HBA
PCI Edge Connector |
State 1 |
State 2 |
State 3 |
3.3V supply |
330mA |
330mA |
330mA |
+12V supply |
1.00A |
1.81A |
1.53A |
3.3V auxiliary supply |
30mA |
30mA |
30mA |
+12V is used in the charging circuitry for the battery pack
on the optional iBBU battery-backed daughter card. If the iBBU daughter
card is mounted, the following power consumption figures apply:
During fast charging of the battery pack: 230mA in +12V current
